    Zprobe not responding
    556
    • mrenz999undefined
      mrenz999
      I am using this probe I have as a backup. Other one broke and waiting for a replacement to come.
      https://www.amazon.com/dp/B07V6GR72Q/ref=cm_sw_em_r_mt_dp_o8r7Fb4BMTP14
      Duet 3 mainboard. Connected to io 3. Hot is connected to the 5v pin, Blue wire is connected to the In pin, black connected to ground.
      M558 P5 C"io3.in" H5 F300 T6000
      I have tried with an exclamation point in front of it and without. It shows at 1000 with the exclamation point and zero without. When I
      tap it either way no changes or acknowledgement of that happening.
      Where am I going wrong ?
      lol
      Thanks
      mrenz999undefined 1 Reply Last reply Reply Quote 0
      • mrenz999undefined
        mrenz999 @mrenz999
        @mrenz999
        I guess I should mention firmware 3.4b7
        • mrenz999undefined
          mrenz999 @mrenz999
          @mrenz999
          Also, m119 gives this respons.
          m119
          Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
            Use without !
            Try P8 instead of P5
            What is your G31 line?
            What are the 3 wires for the PCB marked as?
            What does the potentiometer do?
            • mrenz999undefined
              mrenz999 @Phaedrux
              @phaedrux
              G31 P50 X16.795 Y25.4 Z.43
              Tried P8 and P5
              VCC DO AO are the three wires Red, Black, Blue in that order
              I put them on the board Red to 5v Black to Ground Blue to In.
              My assumption is the potentiometer changes the how sensitive
              it is.
                mini or 6hc?
                • mrenz999undefined
                  mrenz999 @Phaedrux
                  @phaedrux
                  6hc
                    If you change the potentiometer are you able to get it to display a change in probe status in DWC when you tap it?
                    @mrenz999 said in Zprobe not responding:
                    Since the probe is attached to the nozzle the XY offset should be 0,0.
                    • mrenz999undefined
                      mrenz999 @Phaedrux
                      @phaedrux
                      I will make that change.
                      Thank you
