    Configure multiple bed heaters
    496
    • Bart1992undefined
      Bart1992
      I'm trying to configure a multiple bed heaters setup, however i'm not succeeding in getting the bed heaters to show up in the DWC and Paneldue.
      My specific heater config looks like :
      ; Heaters___________________________________________________________
      ; Bed1 parameters
      M140 P0 H0
      M305 P3 S"Bed1" X150 T"J"  ; Set thermocouple heater 0 = bed 1 thermocouple = J type
      M143 H0 S125 ; Set temperature limit for heater 0 to 125C
      ; Bed2 parameters
      M140 P3 H6
      M305 P3 S"Bed2" X151 T"J"  ; Set thermocouple heater 0 = bed 1 thermocouple = J type
      M307 H6 B1 S1.00
      M143 H6 S125 ; Set temperature limit for heater 0 to 125C
      ; Bed3 parameters
      M140 P4 H7
      M305 P3 S"Bed3" X152 T"J"  ; Set thermocouple heater 0 = bed 1 thermocouple = J type
      M307 H6 B1 S1.00
      ;E0_________________________________________________________________
      M305 P1 T100000 B4725 C7.060000e-8 R4700                     	    ; Set thermistor + ADC parameters for heater 1
      M143 H1 S285                                                        ; Set temperature limit for heater 1 to 285C
      ;E1_________________________________________________________________
      M305 P2 T100000 B4725 C7.060000e-8 R4700                       	    ; Set thermistor + ADC parameters for heater 2
      M143 H2 S285                                                        ; Set temperature limit for heater 2 to 285C
      and for completion, the complete config looks like :
      ; General preferences_______________________________________________
      G90                                          				; Send absolute coordinates...
      M83                                         				; ...but relative extruder moves
      M111 S0 													; Debug off
      M555 P2 													; Set output to look like Marlin
      M575 P1 B57600 S1											; Set auxiliary serial port baud rate and require checksum (for PanelDu
      ; Network________________________________________________________ֹֹֹֹֹ___
      M550 P"Big Meter - Kverneland Group"                          							; Set machine name
      ;M551 P"MODIX3D"               										; Set password (optional)
      M552 S1                                 							; Enable network
      ;M552 P0.0.0.0														; Uncomment this command for using Duet Ethernet board
      M586 P0 S1                                							; Enable HTTP
      M586 P1 S0                               					    	; Disable FTP
      M586 P2 S0                                							; Disable Telnet
      ;Main board______________________________________________________________________
      M569 P0 S0                                                     		; Physical drive 0 . X1
      M569 P1 S1                                                       	; Physical drive 1 . X2
      M569 P2 R-1                                                        	; Physical drive 2 . Canceled
      M569 P3 S1                                                       	; Physical drive 3 . Main Extruder
      M569 P4 S0                                                       	; Physical drive 4 . Secondery Extruder
      ;Duex5 board_____________________________________________________________________
      M569 P5 S0                                                       	; Physical drive 5 . Y
      M569 P6 S0                                                       	; Physical drive 6 . Z1 (0,1000)
      M569 P7 S0                                                       	; Physical drive 7 . Z2 (0,0)
      M569 P8 S0                                                       	; Physical drive 8 . Z3 (1000,0)
      M569 P9 S0                                                       	; Physical drive 9 . Z4 (1000,1000)
      ;___________________________________________________________________
      M584 X0:1 Y5 Z6:7:8:9 U1 E3:4 P3									; Driver mapping
      M671 X-181:-181:1049:1049 Y1066:-58:-58:1066 S10    			  	; Anticlockwise
      M350 X16 Y16 Z16 E16:16 U16 I1                                		; Configure microstepping with interpolation
      M92 X100.00 Y100.00 Z2000.00 E440.530:418.500 U100.00      			; Set steps per mm
      M566 X240 Y360 Z30.00 E120.00:120.00 U240 P1                    	; Set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z200.00 E1200.00:1200.00 U9000.00    		; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z120.00 E250.00:250.00 U1000             			; Set accelerations (mm/s^2)
      M204 P500                                      						; Set print and travel accelerations  (mm/s^2)
      M906 X1800 Y1800.00 E1000.00:1000.00 U1800 I40 						; Set motor currents (mA) and motor idle factor in per cent
      M906 Z1800.00 I50 													; Set motor currents (mA) and motor idle factor in per cent
      M84 S60 X Y U E0 E1                                                 ; Set idle timeout - one minute
      ; Axis Limits_______________________________________________________
      M208 X0:1000 Y0:1000 Z0:1000 U0:1000		                        ; Set axis minima and maxima
      ; Endstops__________________________________________________________
      M574 X1 Y2 U1 S1                                            		; Set active low and disabled endstops
      ; Z-Probe___________________________________________________________
      M574 Z2 S2                                                     		; Set endstops controlled by probe
      M307 H7 A-1 C-1 D-1                                     			; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T9000 A1 R0.7            			       			; Set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-14 Y21 Z1.284  	                    		     		; Set Z probe trigger value, offset and trigger height(Z-Offset)
      M557 X-14:974 Y21:1009 S52 		                        			; Define mesh grid. 400 Points
      M376 H30			                    							; Height (mm) over which to taper off the bed compensation
      ;M140 H-1                                                            ; Disable heated bed
      ;M307 H0 A-1 C-1 D-1												 ; Disable heater on PWM channel
      ; Bed1 parameters
      M140 P0 H0
      ; Bed2 parameters
      M140 P3 H6
      M307 H6 B1 S1.00
      ; Bed3 parameters
      M140 P4 H7
      M305 P4 S"Bed3" X152 T"J"  ; Set thermocouple heater 0 = bed 1 thermocouple = J type
      M307 H6 B1 S1.00
      ;M307 H1 A# C# D# V# S1.0 B0                            			; PID calibration
      ;M307 H2 A# C# D# V# S1.0 B0                             	   		; PID calibration
      ; Fans______________________________________________________________
      M106 P0 S0 I0 F500 H-1 C"E0 BlowerFan"                       	    ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S0 I0 F500 H-1 C"E1 BlowerFan"                              ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P5 T46 H1 							    						; Set fan 5. Thermostatic control is turned on
      M106 P6 T46 H2 							   							; Set fan 6. Thermostatic control is turned on
      M106 P2 I-1                                                         ; LED (optional)
      M106 P3 I-1                                                         ; LED (optional)
      M106 P4 I-1                                                         ; LED (optional)
      M106 P7 I-1                                                         ; Main LED
      M106 P8 I-1                                                         ; LED (optional)
      ;T0_________________________________________________________________
      M563 P0 S"E0 Primary" D0 H1 F0                      				; Define tool 0
      G10 P0 X0 Y0 Z0                                   					; Set tool 0 axis offsets
      G10 P0 R0 S210                                		  				; Set initial tool 0 active and standby temperatures to 0C
      ;T1_________________________________________________________________
      M563 P1 S"E1 Secondary" D1 H2 F1                     			    ; Define tool 1
      G10 P1 X0 Y49 Z0                             			    		 ; Set tool 1 axis offsets
      G10 P1 R0 S210                               		     	 		; Set initial tool 1 active and standby temperatures to 0C
      ; Automatic power saving____________________________________________
      M911 S22.5 R29.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"              ; Set voltage thresholds and actions to run on power loss. Power Failure Pause
      ; Custom settings___________________________________________________
      M591 D0:1 P1 C4 S1		   			       	    					; Regular filament sensor for E0 and E1
      ;M564 H0 S0                                                	    	; Negative movements are allowed
      Bed heater 2 and 3 don't appear in the DWC and Paneldue( bed heater H0 does ).
      Looking at the diagnostics ( M122 ), the heaters seem to be correctly defined
      === Bed heaters = 0 -1 6 7
      What am i doing wrong? Why are they not displayed? Giving them a name ( as noted in the docs M305 S parameter ) does not seem to help unfortunately.
        What firmware version on the duet, paneldue? What DWC version?
        Can you send M122 and M98 P"config.g" and post the results here?
        Bart1992undefined 1 Reply Last reply Reply Quote 0
        • Bart1992undefined
          Bart1992 @Phaedrux
          This post is deleted!
          • Bart1992undefined
            Bart1992
            @phaedrux Thanks for your response
            As requested :
            Duet firmware version : 2.05
            DWC version : 2.07
            M122 output :
            ( had to do it like this, otherwise it's marked as spam? )
            m122output.txt
            M98 P"config.g" output :
            M98 P"config.g"
            HTTP is enabled on port 80 FTP is disabled TELNET is disabled Warning: Heater 6 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C. Error: M106: Fan 2 is disabled Error: M106: Fan 3 is disabled Error: M106: Fan 4 is disabled Error: M106: Fan 7 is disabled Error: M106: Fan 8 is disabled
              I think to have the additional bed heaters show up correctly you'd need to upgrade your firmware to RRF3, including the PanelDue.
              • Bart1992undefined
                Bart1992 @Phaedrux
                @phaedrux
                Unfortunately we are unable to upgrade to RRF3 yet.
                But I think it must be possible to configure RRF2 using multiple bed heaters to show up in the DWC and Paneldue?
                According to this post, is must be possible : https://forum.duet3d.com/topic/3516/using-multiple-bed-heaters/21
                dc42undefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                  dc42 administrators @Bart1992
                  @bart1992 you should be able to configure them in RRF 2.05 and you may get them to show up in DWC, but they certainly won't show up in PanelDueFirmware 1.x.
                    jay_s_uk @Bart1992
                    @bart1992 whats stopping you upgrading to RRF3?
                    • Bart1992undefined
                      Bart1992 @dc42
                      Thank you for responding.
                      Can you explain how I should let them show up in the DWC?
                      Currently only bed1 is shown ( see attachment )!
                        @bart1992 I guess DWC 2.0.7 doesn't support multiple bed heaters. Probably that's because the status report that DWC 2 and earlier use doesn't have multiple values for bed heaters. DWC 3 uses the RRF3 object mode instead and does support multiple bed heaters.
