    Using a 12 volt fan on 6HC board with vin 24 volts
    555
    • Weevilundefined
      Weevil
      I have a 12-volt fan I want to use on Out 7. The 6HC board has 24 volts for Vin. Could I just connect one lead of the fan to the dedicated 12V pin and connect the other lead to ground on V_OUTC2 on Out 7? Wouldn't that make it controllable?
      • Gixxerfastundefined
        Gixxerfast
        Do you have other 24V units already connected to out8 and out9 so you don't want to jumper the voltage to 12V?
        Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
        Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
        Ender 3 Pro with BTT SKR-2 + RRF
        Weevilundefined 1 Reply Last reply Reply Quote 0
        • Weevilundefined
          Weevil @Gixxerfast
          @gixxerfast Yes, there is another fan. I suppose I could move one of the fans to Out 4.
          Gixxerfastundefined dc42undefined 2 Replies Last reply Reply Quote 0
            Gixxerfast @Weevil
            @weevil You could of course keep V- (fan gnd wire) connected to out7 pin and steal the V+ (12V) from any other free 12V pin. It's just a tiny bit more messy 🙂
            • Weevilundefined
              Weevil @Gixxerfast
              @gixxerfast I just looked at the wiring diagram. It has this warning:
              "Note: These outputs are protected by a flyback diode connected to V_OUT_LC_2. Do not mix loads connected to V_OUT_LC_2 with the jumper set to 12V and loads connected to V_FUSED on the same bank."
              deckingmanundefined 1 Reply Last reply Reply Quote 2
              • deckingmanundefined
                deckingman @Weevil
                @weevil How many fans do you currently have in total, and where ae they connected?
                • Weevilundefined
                  Weevil @deckingman
                  @deckingman I have 2 fans, one for the hotend and one for part cooling. I have decided to just stick with my 24v fans, much simpler.
                    dc42 administrators @Weevil
                    @weevil said in Using a 12 volt fan on 6HC board with vin 24 volts:
                    That's the obvious solution, then you can set one of the two banks of outputs to 12V and the other one to VIN.
                      deckingman @Weevil
                      @weevil To expand on what @DC42 has said, set jumper on out 4-6 to fit between 12V and V_outC1, set jumper on out 7-9 to fit between V_fused and V_OutC2, connect the 12V fan to any of out 4 to 6, connect the 24V fan to any of out 7 to 9.
                      • Weevilundefined
                        Weevil @dc42
                        @dc42 Thanks!
                        • Weevilundefined
                          Weevil @deckingman
                          @deckingman Thanks
