    probe for tool offset
    • bastundefined
      bast
      hey duet comminity
      I would like to automatise my offset tool on my tool changer
      i see this video
      https://www.youtube.com/watch?v=fshmEMWxBHY&t=324s
      i would like to do same thing but with this probe for offset Z (i have a probe for mesh leveling )
      https://us.misumi-ec.com/vona2/detail/221005216470/?
      I connect Brown(+) wire on io3.in and blue (-)wire on ground
      config
      ;toolchange Zprobe offset
      M558 K1 P8 C"io3.in" f60 h5
      but it s not working ,have you some information for probe working
      thank
      bastien
      • bastundefined
        bast
        I can back after some test
        I made a new assembly for the connection as shown in the drawing with 20K resistance
        The led on the sensor is on and when I press it, it turns off.
        I checked the current on the sensor by plugging
        the "-" on the GND and the "+" on the io3.in
        normally the current is 1.69V and when I press it it goes to 4.92V
        it still doesn't work but if you have any tips I'm interested
        thanks a lot
        • bastundefined
          bast
          https://forum-duet3d-com.translate.goog/topic/9714/need-help-wiring-end-stop-switches/5?_x_tr_sl=en&_x_tr_tl=fr&_x_tr_hl=fr&_x_tr_pto=wapp
          There was a topic on this before but the answer is not clear to me.
          • bastundefined
            bast
            hey duet community ,
            I have attached the new diagram for connecting a Metrol LED switch
            I added a K0 for my bed probe and a K1 for the Z offset tool probe
            config.g for Probe tool offset
            M558 K1 P8 C"io3.in"H5 F60 L0 T6000
            G31 K1 P500 X-20 Y422
            The triggering of the sensor is visible in "status" at the bottom right, I now have 2 probes displayed
            For the metrol when I press it goes to 1000 in red and goes back to 0 once I depress it
            I think this is good
            now I'm going to go routine using macros
            • bastundefined
              bast
              Can i find Z probe status (trigger or not) in object model ?
              In endstop/Probe section in objet model i have Two probe
              but I dont find status
                jay_s_uk @bast
                @bast use the trigger value and compare against the P value you specified in G31
