    Hotend FAN1 stops running when Print starts
    426
    • Topengaundefined
      Topenga
      Since some hours try to figgure out what the faliure is i made 😵
      I'm using Cura and RFF3
      Here my Config...may someone can help me because I'm out of ideas.
      Thanks a lot
      ; Heatbed
      M143 H0 S110 ; set temperature limit for heater 0 to 110C
      ; Hotend
      M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
      M308 S1 P"e1temp" Y"thermistor" T100000 B4100 ; define E0 temperature sensor
      M950 H1 C"e1heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S0.85 ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S351 ; set temperature limit for heater 1 to 300°C
      M106 P0 C"PartCooling" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned on
      M106 P1 C"HotendSink" S0.95 H-1 ; set fan 1 name and value. Thermostatic control is turned off
      M106 P2 C"Elect" S0.85 H1 T30 ; set fan 2 name and value. Thermostatic control is turned on
      jay_s_ukundefined jumpedwithbothfeetundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Topenga
        @topenga post your M563 line from your config
        • jumpedwithbothfeetundefined
          jumpedwithbothfeet @Topenga
          @topenga Best include your entire config.g, what do you have listed under M563? have you checked your wiring?
          6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
          Topengaundefined 1 Reply Last reply Reply Quote 0
          • Topengaundefined
            Topenga @jumpedwithbothfeet
            @jumpedwithbothfeet
            Thanks for that fast replay......hmmmm M563 is i guess the key?!?
            ; Configuration file for Duet WiFi (firmware version 3.3)
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 30 2021 05:49:28 GMT+0100 (Mitteleuropäische Normalzeit)
            M550 P"Dan's WonderMachine" ; set printer name
            M551 P"1945" ; set password
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 D2 S1 ; physical drive 1 goes forwards
            M569 P1 D2 S1 ; physical drive 2 goes forwards
            M569 P2 D2 S1 ; physical drive 3 goes forwards
            M569 P3 D2 S0 ; physical drive 3 goes forwards
            M350 X64 Y64 Z256 I1 ; configure microstepping wit interpolation
            M350 E16 I0 ; configure microstepping wit interpolation
            M92 X320.00 Y320.00 Z6400.00 E693.69435 ;set steps per mm
            M566 X700.00 Y500.00 Z100.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X12000.00 Y12000.00 Z1000.00 E3600.00 ; set maximum speeds (mm/min)
            M201 X900.00 Y800.00 Z700.00 E600.00 ; set accelerations (mm/s^2)
            M906 X2000 Y2000 Z600 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X305 Y305 Z360 S0 ; set axis maxima
            M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
            M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
            M574 Z1 S2 ; configure Z-probe endstop for low end on Z
            ; BLTouch
            M950 S0 C"exp.heater3"
            M558 P9 C"^zprobe.in" H2.5 F500:100 T12000 ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X0 Y0 Z3.35 P25 ; set Z probe trigger value, offset and trigger height
            M557 X5:295 Y50:300 S29:25 ; define mesh grid
            ; Heatbed
            ; Hotend
            M563 P0 S"0.4er Nozzle" D0 H1 F0:1 ; define tool 0
            T0 ; select first tool7
              jay_s_uk @Topenga
              @topenga and can you confirm that fans 0 and 1 are part cooling fans and fan 2 is your heatsink fan?
              • Topengaundefined
                Topenga @jay_s_uk
                @jay_s_uk
                Auch ..... No..... part cooling FAN0, Hotend FAN1: and electronic FAN2
                  jay_s_uk @Topenga
                  @topenga then you have both your fans and M563 setup incorrectly.
                  You should have
                  M308 S2 Y"mcu-temp" A"MCU" ; configure sensor 2 as on-chip MCU temperature sensor
                  That monitors the MCU-Temp for the electronics fan. You could use something else for the electronics fan but thats a good shout.
                  M106 P1 C"HotendSink" S0.95 H1 T45 ; set fan 1 name and value. Thermostatic control is turned off
                  M106 P2 C"Elect" S0.85 H2 T30 ; set fan 2 name and value. Thermostatic control is turned on
                  That sets fan1 to come on when the heater comes on and fan2 to come on if the MCU temp is above 30 degrees (you may need to increase that value)
                  And then change
                  M563 P0 S"0.4er Nozzle" D0 H1 F0 ; define tool 0
                  i.e. remove the :1 from F0 as you only map non thermostatically controlled fans to a tool
                  • Topengaundefined
                    Topenga
                    Thanks a lot... Will fix this afternoon and have feedback
                    Best wishes
                    Danijel
                    • Topengaundefined
                      Topenga @jay_s_uk
                      @jay_s_uk said in Hotend FAN1 stops running when Print starts:
                      Hello jay_s_uk said,
                      thanks a lot....it works....I wonder how long it will take until I'm relly fit due to configuration knowledge!
                      Great Forum dute to very kind and supportive member!
                      Danijel
