    DWC displaying text only
    835
    • brianundefined
      brian
      My duet has been working ok. The first time turning it on this morning it wouldnt connect. I connect Panel Due and it connects and uses same ip address as i expected. After restarting Duet several times and my web browers it finally connected to pc but only in text format.
        Are you able to ping the IP address that the Duet thinks it has?
        Have you tried clearing your browser cache?
        Have you tried from a different computer and browser?
        Do you have a new SD card to test with?
        What version of firmware are you using?
        You may need to replace the DWC files with fresh ones in case something has been corrupted.
        brianundefined 1 Reply Last reply Reply Quote 0
        • brianundefined
          brian @Phaedrux
          @phaedrux
          ping; yes it returns some data, which i dont understand
          browsers; yes tried all those i have
          firmware; v2.02 wifi 1.02
          suggestions; will try new sd card
          thx
          • brianundefined
            brian @brian
            @brian clearing browser cache, no change
            • brianundefined
              brian @brian
              @brian are the number of replies limited??
              • brianundefined
                brian @brian
                @brian Ok, i replaced all the www files on the sd card, but this has not made a difference. (that is on the new sd card)
                  Can you connect via USB terminal like YAT and send M122 and share the results here?
                  • brianundefined
                    brian @Phaedrux
                    @phaedrux It doesnt seem to connect via yat. When checking Device Manager by pressing Windows Key + R and type devmgmt.msc, i dont see Duet listed, i've tried all usb port on the pc and none effect device manager. I have followed instructions in Getting Connected to your Duet but still no response when sending commands in yat.
                    • brianundefined
                      brian @brian
                      @brian have now succeeded in connecting to yat. will advise progress.
                      • brianundefined
                        brian @brian
                        @brian M112 results
                        Emergency Stop! Reset the controller to continue.ok
                        RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.02(RTOS) dated 2018-12-24b1
                        Executing config.g...Error: Bad command: ++
                        HTTP is enabled on port 80
                        FTP is disabled
                        TELNET is disabled
                        Done!
                        RepRapFirmware for Duet 2 WiFi/Ethernet is up and running.
                        WiFi module started
                        WiFi module is connected to access point TELUS008
                        jay_s_ukundefined brianundefined 2 Replies Last reply Reply Quote 0
                          jay_s_uk @brian
                          @brian M122 not M112
                          • brianundefined
                            brian @brian
                            @brian Final result after completing the connecting instructions, and still cant get DWC on pc.
                            M112<CR>
                            M112
                            M112
                            FTP is disabled
                            TELNET is disabled
                            Done!
                            WiFi module started
                            M115 S-1
                            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
                            ok
                            M552 S-0
                            ok
                            WiFi module is idle
                            M552 S-0
                            ok
                            M552
                            WiFi module is idle
                            ok
                            M587 S"TELUSxx87" P"5n6w6xxxcc"
                            ok
                            M552 S1
                            ok
                            WiFi module is connected to access point TELUS0087, IP address 192.168.1.66
                              Send M122 please.
                              And can you share your config.g?
                              • brianundefined
                                brian @Phaedrux
                                @phaedrux yes
                                ++;MY update june 16 2018 for pellet extruder
                                ; Configuration file for Duet WiFi (firmware version 2.0) Wifi not working, z endstop not working
                                ; generated by RepRapFirmware Configuration Tool on Tue Jun 20 2017 17:30:36 GMT-0700 (Pacific Daylight Time)
                                ; General preferences***********************
                                M111 S0 ; Debugging off
                                G21 ; Work in millimetres
                                M208 X420 Y430 Z650 S0 ; Set axis maxima
                                M564 H0 ; must be here to allow movements before homing ...wtf
                                ; Endstops -my not working model******************
                                ;M574 X1 Y1 S1 ; Define active high microswitches took out Z1 maybe cant have both-nope
                                ;M558 P1 X0 Y0 Z1 H-3 F320 T5000 R0 ; smart IR Z probe, used for homing Z axis only, dive height 3mm, probe speed 200mm/min, travel speed ;5000mm/min, no recovery time
                                ;M557 X25:175 Y25:175 S25 ; Define mesh grid
                                ;G31 P500 X0 Y0 Z not here; Set Z probe trigger value, offset and trigger height HIGHER numbers moves bed CLOSER to nozzle-well it used to, nothing
                                ;G30 ;does move bed up to trigger height* try z-2 or something-didnt home didnt go up
                                ; Endstops -T3P3Tony****************************
                                ; Set Z height from build plate*********************
                                M574 X1 Y1 S1 ; try remove Z0-didnt help, try Y2 flipped wires and work, now x not working trying X2
                                M558 P1 H3 F200 T1000 ;smart IR Z probe, (H)dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min travel speed was 5000 testing at 1000
                                G31 X0 Y0 Z0.4 P500 ; *****1.20 for 0.4 nozzle 2.0 for 0.9 HIGHER num puts bed CLOSER to nozzle! 1/1/21
                                ;setting z height, command bed up to nozzle, run G92 Z0, set z to 0 in above line, repeat then run M114 to get offset
                                ; Drives*********************************************
                                M569 P3 S1 ; Drive 3 goes forwards; **below set microstepping to 64 from 128 now next line reduce steps by half x1272 y1284 z 6400-which worked!!!!
                                M350 X32 Y32 Z16 E32 I0 ; Configure microstepping without interpolation---below line was Z3200 Z3500=10% too much
                                by measuring 100mm with yardstick 3150 appears exactly correct!
                                ; STEPS **************************************
                                M92 X322.5 Y322.5 Z1307.8 E1300 ; ** (247 recreus E w/1.8 stepper, 500 for 0.9 stepper)(x636 642-1.8 steppers) 1360-dyze pro E-steps per mm trying y645 to correct printed(Z 3200 for 1,8 steppers try 5100 for 0.9 z,sy 2020 added 30 to 5100 to try reduce nozzle drag) 642 change for x y 5130 z (e1143 worked good for 1.0 LH), (e4000 good for 0.4LH) and (e1250 try 1750 too much for 0.6 LH) (try 700 for 0,9 Nozzle
                                M566 X100 Y100 Z100 E50 ; Set maximum instantaneous speed changes (mm/min); I changed from 900 x y (@12 prints very slowly)june 1 2018 120 z400 original ju27 2021 reduced E60 to E50
                                M203 X4800 Y4800 Z200 E1000 ; Set maximum speeds (mm/min)
                                M201 X600 Y600 Z100 E100 ; Set accelerations (mm/s^2) ; I changed from 1000 x y to 300 and now 200 and now lets try 300 june1 2018 Oct 600 xy 600
                                ;POWER ******************
                                M906 X855 Y855 Z1800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent *** tried 2000 works great but gets really hot 1800 hot, 1700 skips
                                M84 S30 ; Set idle timeout
                                M143 S300 ; Set maximum heater temperature to 300C
                                M140 H-1 ; Disable heated bed
                                ;M305 P1 X201 ; (board v0.4)
                                M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                                M305 P2 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 2
                                M307 H1 A350 C500 D50 B1; I added this line for pellet extruder C500 gives more timeout time; re-ativated as too many timeouts
                                M563 P0 D0 H1 ; Define tool 0
                                M550 PBRIAN'S Build 2 ; Set machine name
                                M552 S1 ; Enable network
                                ; Access point is configured manually via M587 by the user
                                M586 P0 S1 ; Enable HTTP
                                M586 P1 S0 ; Disable FTP
                                M586 P2 S0 ; Disable Telnet
                                ; Fans changed p1 and p2 to S0 from S1 to see if they will work
                                M106 P1 S0 I0 F500 H1 T50 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                M106 P1 S0 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                M106 P2 S0 I0 F500 H1 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                T0 ; Select first tool
                                  Phaedrux Moderator @brian
                                  @brian said in DWC displaying text only:
                                  You've got a ++ before the ; for the comment which is causing that bad command error.
                                  What version of DWC files did you use? You'd need to match the files to your firmware version.
                                  It looks like you're on 2.02 which is quite old now.
                                  • brianundefined
                                    brian @Phaedrux
                                    @phaedrux said in DWC displaying text only:
                                    Have deleted the ++ in config.g
                                    Version of DWC files; not sure version, but dated 2018, i think from when i installed the firmware, should be same install
                                    Is 3.3 the latest and can i update just by copying files to sdcard?
                                      For firmware 2.02 I think you'd want to use these DWC files.
                                      https://github.com/Duet3D/RepRapFirmware/releases/download/2.02/DuetWebControl-1.22.6.zip
                                      Updating to 3.3 would take a bit more doing. Let's see if we can resolve the DWC displaying correctly first.
                                      Can you send M122 and post the results? Not M112.
                                      • brianundefined
                                        brian @Phaedrux
                                        @phaedrux agree, fix this first.
                                        M122 Diagnostic RepRepFirmware for duet 2
                                        WiFi/Ethernet version 2.20(RTOS)running on Duet
                                        WiFi 1.02 or later Board ID: then the id number
                                        brianundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                        • brianundefined
                                          brian @brian
                                          @brian updated www files from your link. no change
                                            That's all that comes with it? There should be a longer diagnostic report.
