    e3d v6 config.g values needed
    • Sardiundefined
      Sardi
      Hi all.
      I have an Ormerod 2 printer and will be switching the standard Ormerod hot end for the E3D V6.
      The only M305 command I have in my config.g for the hot end is this
      M305 P1 R4700 ; Set the hot end thermistor series resistor to 4K7
      Im aware I need to add a B parameter at least, but what value should I set?
      And are there any other parameters besides the B that I should add?
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @Sardi
        @sardi
        I don't use an E3D V6 hotend, but THIS page talks about the thermistor values.
        I hope that helps.
        Sardiundefined 1 Reply Last reply Reply Quote 2
        • Sardiundefined
          Sardi @alankilian
          @alankilian it indeed does, my problem is solved. Thank you 🙂
          alankilianundefined 1 Reply Last reply Reply Quote 1
            alankilian @Sardi
            @sardi YEAH!
