How can I start a part program again after it is finished
CNC
340
  • undefined
    martin7404
    So I built a custom machine for automated drilling of ALU profile
    with 2 AXIS , Z, and X.
    On my CNC mills and lathe machines, I can put M99 at the end of a file and it will run it again and again until some condition or with M00 and switch on the controls keyboard.
    Generally, I want to loop the part program (job) endless
    Dduet wifi , RPF2 with duet brackout board and external drivers
    How to do this with DUET
    Muldex IDEX Duet2+Duex5
    Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
    Sapphire Pro with Duet2, with closed-loop motors
    custom high temp E3D tool changer with Duet2+Duex
    undefined 1 Reply Last reply 7 Feb 2022, 19:21 Reply Quote 0
    • undefined
      oliof @martin7404
      @martin7404 you can do this with metacommands
      I would write a helper macro, "Loop.g" that looks roughly like this:
      while globals.Loop
      M98 P{params.X}
      A Macro "EnableLoop"
      if exists(global.Loop)
      set global.Loop = true
      else
      global Loop = true
      And a Macro "StopLoop"
      if exists(globals.Loop)
      set globals.Loop = false
      else
      global Loop = false
      Then you can set up your system to Loop by running EnableLoop
      and call your looping gcode running M98 P"Loop" X"FileToLoop"
      Note this is untested and probably misses some nuance. You will need to make sure that in case of error globals.Loop is unset for example
      undefined 1 Reply Last reply 7 Feb 2022, 22:25 Reply Quote 2
      • undefined
        martin7404 @oliof
        @oliof thank you
        So I should move to RPF 3 then with this project
        undefined undefined 2 Replies Last reply 8 Feb 2022, 09:52 Reply Quote 0
        • undefined
          oliof @martin7404
          @martin7404 I would recommend that
          • undefined
            baird1fa @martin7404
            @martin7404 I'm running a duet 2 wifi with external drivers and using RRF3.4 the only issue I've seen is that when in CNC mode I have no DRO of any kind. They are supposedly fixing that when 3.4 becomes RC1 (not sure what that means)
            undefined 1 Reply Last reply 10 Feb 2022, 11:19 Reply Quote 0
            • undefined
              oliof @baird1fa
              @baird1fa excuse my ignorance, but what does DRO mean in this context and what is it used for?
              undefined 1 Reply Last reply 10 Feb 2022, 11:26 Reply Quote 0
              • undefined
                martin7404 @oliof
                @oliof Digital Read Out.
                i.e. No position tracking on panel DUE only in DWC
                undefined 1 Reply Last reply 10 Feb 2022, 11:31 Reply Quote 0
                • undefined
                  oliof @martin7404
                  @martin7404 PanelDue (and 12864 if configured to do so) do show current position (within limits), but I guess you are looking for either a real time display or position reporting from encoders etc.?
                  8 out of 8
