Programing issues
; homex.g ; called to home the X axis G91 ; relative positioning G1 H2 Z5 F6000 ; lower Z relative to current position G1 H1 X20 Y20 F1800 ; BACK OFF TO CLEAR STOP G1 H1 X-505 Y-540 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X5 Y10 F6000 ; go back a few mm G1 H1 X-505 Y-540 F500 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lift Z again G90 ; absolute positioning
Ok so tried this and y stays still as x homes but x hits endstop switch and keeps trying to move more.
@alankilian
It will not let me as axis is not homed already. -
I don't get it. I had x working decent but y would still move some. Also had y moving decent but x would still move some. Even had Y staying still and was able to home x. then all of a sudden it all went haywire again. I even did M669 K1 to make sure was still in corexy mode. Back to moving and crashing
You can do M564 to allow movements without homing.
Please post your complete config.g
The one your posted earlier has your machine configured in Cartesian mode which would cause all these problems.
; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Jan 14 2022 15:32:45 GMT-0800 (Pacific Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Thor" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X1500 Y1500 Z1500 E1500 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X330 Y330 Z350 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop M574 Z2 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"exp.heater7" ; Duet 2 WiFi/Ethernet M558 P31 C"^zprobe.in" H5 F120 T6000 A10 R0.5 S0.005 B0 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X35 Y0 Z0.26 ; set Z probe trigger value, offset and trigger height M557 X10:300 Y20:310 S50 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
Ok here is complete config.g file with what I have setup right now. I believe it is setup for corexy but am not sure how to check to see. I also believe that this could be one of the main problems (possibly could be reverting back to cartesian on its own) If it is reverting back how do I get it to stay in corexy.
@tinkerworksgarage said in Programing issues:
That is not enough to insure that XY motions are correct.
Did you read the docs on how to get your steppers configured and wired correctly?
You must have Cartesian checked in the Reprap Configuration Tool.
Your config.g is NOT set for corexy. If it was it would have an M669 K1 near the top.HERE is the document that tells you step-by-step how to configure it and get the motor-direction descriptions right. (Thanks @fcwilt)
@alankilian
I had selected corexy when setting it up in reprap configurator. Thats why I think something keeps resetting back and not keeping changes. -
That's not really something that happens.
- Run the RRF configurator
- Download the zip file
- Unzip the zip file
- Post the config.g from the unzipped folder
We'll then be able to see the Kinematic configuration
- Upload the WHOLE ZIP file to your Duet and update it.
- Power-cycle your printer
- Download the config.g from your printer
- Post that config.g
We'll THEN see if your printer updated appropriately.
Thank you all so much for all the help. It has been a long process for me as I am used to Marlin. I RRF Config tool again and double & triple checked everything. I then got a different sd card and reloaded firmware on new card. Things seem to be working now, not perfect but some setting and I should be good. If i have any more question or problems I will ask as you all have been a huge help.
Thank you all again
