    Programing issues
    507
    • engikeneerundefined
      engikeneer @Tinkerworksgarage
      @tinkerworksgarage okay. When you say x and y move backwards a little, do you mean they both move away from the endstops (by about 5mm)? If so then your x and y directions are correct.
      Your z direction is incorrect (the bed moves up when it should move down) so change
      To
      M569 P2 S0 ; physical drive 2 goes backwards
      Next onto your homing. It should like your x and y endstops are already triggered so as soon as it starts the homing move, it thinks it's at the endstops
      G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
      This is the long homing move to xmin (where your endstop is). It doesn't do this move because the endstop is already triggered.
      So you need to test your endstops and reconfigure them. Send M119 and it will report the current state of the endstops. Try this with and without the endstops pressed.
      My guess is you will need to invert both x and y endstops by adding an exclamation mark to the pin name. E.g. change
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      To
      M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop and invert
      Let us know how you get on from there
      Not sure if you've found all the Duet documentation but all this should be covered there. A couple of good ones to read through are:
      https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
      https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter
      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39 (granted this one is a different printer/board but the steps to take are all the same)
      Edit: corrected my mistake on M569. Thanks @jay_s_uk 😊
      i3 clone with a bunch of mods
        jay_s_uk @engikeneer
        @engikeneer said in Programing issues:
        M569 P2 S2 ; physical drive 2 goes backwards
        S2 isn't valid. It's S0 or S1
          jay_s_uk @Tinkerworksgarage
          @tinkerworksgarage said in Programing issues:
          M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
          you also don't have a servo defined so the BLTouch will never deploy
          • JoergS5undefined
            JoergS5 @Tinkerworksgarage
            The BLTouch should be setup with M558 P9, and the position in reference to the nozzle of X and Y must be defined in G31 (otherwise the mesh compensation is at a wrong place later), please check both in
            https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
            If you are in front of the printer, a positive X means the BLTouch is right to the nozzle, and a positive Y means it is behind the nozzle, values being mm.
            • Tinkerworksgarageundefined
              Tinkerworksgarage
              Thank you all for the help!!!!!!!!!!! Finally getting it figured out some. Next issue is when homing x the y will hit end and just keep trying to move. same when home y the x will hit end and just keep trying to move. How do I cure it so when homing either the other will move relatively so not to crash?
                Tinkerworksgarage
                I am also in testing so not everything is mounted or mounted permanent like hotend or bltouch. That is
                why I had no values as those will be entered later.
                  Tinkerworksgarage
                  ; homex.g
                  ; called to home the X axis
                  ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Jan 14 2022 15:32:45 GMT-0800 (Pacific Standard Time)
                  G91               ; relative positioning
                  G1 H2 Z5 F6000    ; lower Z relative to current position
                  G1 H1 X20 F1800
                  G1 H1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass)
                  G1 H2 X5 F6000    ; go back a few mm
                  G1 H1 X-505 F500  ; move slowly to X axis endstop once more (second pass)
                  G1 H2 Z-5 F6000   ; lift Z again
                  G90               ; absolute positioning
                    Tinkerworksgarage
                    ; homex.g
                    G1 H1 X20 F1800   ; BACK OFF TO CLEAR STOP
                    G1 H1 Y-20 F1800  ;MOVE Y BACK SAME AS X MOVES TO HOLD POSITION
                    G1 H1 Y505 F1800   ;MOVE Y BACK SAME AS X TO HOLD POSITION
                    G1 H1 Y505 F500    ;MOVE Y BACK SAME AS X TO HOLD POSITION
                    Would to this work to hold position for y as x moves to home. same would be done for x as y homes?
                    • alankilianundefined
                      alankilian @Tinkerworksgarage
                      I don't quite understand why your Y axis would move when you command a move in the X axis.
                      Can you try entering G1 X moves one way and the other and verify that the Y axis does not move at all? It shouldn't.
                      G1 X20 F1800
                      G1 X-20 F1800
                      Entering these should move ONLY the X-axis right 20mm and then left 20mm
                      Tinkerworksgarageundefined 1 Reply Last reply Reply Quote 0
                        Tinkerworksgarage
                        ; homex.g
                        G1 H1 X20 Y20 F1800   ; BACK OFF TO CLEAR STOP
                        G1 H1 X-505 Y-540 F1800 ; move quickly to X axis endstop and stop there (first pass)
                        G1 H2 X5 Y10 F6000    ; go back a few mm
                        G1 H1 X-505 Y-540 F500  ; move slowly to X axis endstop once more (second pass)
                        Ok so tried this and y stays still as x homes but x hits endstop switch and keeps trying to move more.
                          Tinkerworksgarage @alankilian
                          @alankilian
                          It will not let me as axis is not homed already.
                            Tinkerworksgarage
                            I don't get it. I had x working decent but y would still move some. Also had y moving decent but x would still move some. Even had Y staying still and was able to home x. then all of a sudden it all went haywire again. I even did M669 K1 to make sure was still in corexy mode. Back to moving and crashing
                            alankilianundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                              @tinkerworksgarage
                              You can do M564 to allow movements without homing.
                              Please post your complete config.g
                              The one your posted earlier has your machine configured in Cartesian mode which would cause all these problems.
                                Tinkerworksgarage
                                ; Configuration file for Duet WiFi (firmware version 3.3)
                                G90                                            ; send absolute coordinates...
                                M83                                            ; ...but relative extruder moves
                                M550 P"Thor"                             ; set printer name
                                M552 S1                                        ; enable network
                                M586 P0 S1                                     ; enable HTTP
                                M586 P1 S0                                     ; disable FTP
                                M586 P2 S0                                     ; disable Telnet
                                M569 P0 S1                                     ; physical drive 0 goes forwards
                                M569 P1 S0                                     ; physical drive 1 goes forwards
                                M569 P2 S0                                     ; physical drive 2 goes forwards
                                M569 P3 S1                                     ; physical drive 3 goes forwards
                                M584 X0 Y1 Z2 E3                               ; set drive mapping
                                M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                                M92 X80.00 Y80.00 Z400.00 E420.00              ; set steps per mm
                                M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
                                M203 X6000.00 Y6000.00 Z180.00 E1200.00        ; set maximum speeds (mm/min)
                                M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
                                M906 X1500 Y1500 Z1500 E1500 I30                   ; set motor currents (mA) and motor idle factor in per cent
                                M84 S30                                        ; Set idle timeout
                                M208 X0 Y0 Z0 S1                               ; set axis minima
                                M208 X330 Y330 Z350 S0                         ; set axis maxima
                                M574 Y1 S1 P"!ystop"                            ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                                M574 Z2 S2                                     ; configure Z-probe endstop for low end on Z
                                M950 S0 C"exp.heater7"                          ; Duet 2 WiFi/Ethernet
                                M558 P31 C"^zprobe.in" H5 F120 T6000 A10 R0.5 S0.005 B0           ; set Z probe type to unmodulated and the dive height + speeds
                                G31 P500 X35 Y0 Z0.26                            ; set Z probe trigger value, offset and trigger height
                                M557 X10:300 Y20:310 S50                       ; define mesh grid
                                M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                                M307 H0 B0 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
                                M140 H0                                        ; map heated bed to heater 0
                                M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                                M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
                                M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                                M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                                M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
                                M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                                M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                                M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                                M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                                M563 P0 D0 H1 F0                               ; define tool 0
                                G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                                G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                                Ok here is complete config.g file with what I have setup right now. I believe it is setup for corexy but am not sure how to check to see. I also believe that this could be one of the main problems (possibly could be reverting back to cartesian on its own) If it is reverting back how do I get it to stay in corexy.
                                • fcwiltundefined
                                  fcwilt @Tinkerworksgarage
                                  That is not enough to insure that XY motions are correct.
                                  Did you read the docs on how to get your steppers configured and wired correctly?
                                    You must have Cartesian checked in the Reprap Configuration Tool.
                                    Your config.g is NOT set for corexy. If it was it would have an M669 K1 near the top.
                                    HERE is the document that tells you step-by-step how to configure it and get the motor-direction descriptions right. (Thanks @fcwilt)
                                      @alankilian
                                      I had selected corexy when setting it up in reprap configurator. Thats why I think something keeps resetting back and not keeping changes.
                                        @tinkerworksgarage
                                        That's not really something that happens.
                                        • Run the RRF configurator
                                        • Download the zip file
                                        • Unzip the zip file
                                        • Post the config.g from the unzipped folder
                                        We'll then be able to see the Kinematic configuration
                                        • Upload the WHOLE ZIP file to your Duet and update it.
                                        • Power-cycle your printer
                                        • Download the config.g from your printer
                                        • Post that config.g
                                        We'll THEN see if your printer updated appropriately.
                                          Tinkerworksgarage
                                          Thank you all so much for all the help. It has been a long process for me as I am used to Marlin. I RRF Config tool again and double & triple checked everything. I then got a different sd card and reloaded firmware on new card. Things seem to be working now, not perfect but some setting and I should be good. If i have any more question or problems I will ask as you all have been a huge help.
                                          Thank you all again
