    Issue with print quality which I can't explain
    462
    • SIamundefined
      SIam
      on the following picture you can see a print from today (printed with the latest rrf 3.4.0 b7+5)
      If I see the Bad blocks, I would say I have a big problem with vibrations, but when I see the good blocks, this can't be the Problem. And here starts my Problem, i have checked The printer for loose screws etc. and nothing found. If there were a problem, should it be everywhere...
      This Box was printed with fixed layer height 0.2mm
      Can someone point me in the right direction how I can fix this issue? I have no idea where i have to search at the moment 😞
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      tommybundefined 1 Reply Last reply Reply Quote 0
      • tommybundefined
        tommyb @SIam
        @siam try 20% slower out wall, then try outer before inner. Sometimes infill does funny things when % fill artifacts show up, try no infill.
        Which slicer?
          When in doubt, change up the slicer you're using.
          SIamundefined 1 Reply Last reply Reply Quote 0
          • SIamundefined
            SIam @Phaedrux
            @phaedrux Thanks for your feedback I will now test with idea maker the first try was made with prusaslicer
            • SIamundefined SIam has marked this topic as solved
            • SIamundefined
              SIam @SIam
              @siam The Problem is not really solved, but now I know that Prusaslicer is the Problem thanks for pointing me in this direction sometimes is the solution to easy that i can see them 😉
                dc42 administrators @SIam
                @siam one potential issue with PrusaSlicer is that by default it changes the printer speed, acceleration and jerk limits to its default values. To avoid this, in Printer Settings/Machine limits change How to apply time limits to Use for time estimate.
                • SIamundefined
                  SIam @dc42
                  @dc42 Thanks for that information, I will give it a try (on reprapfirmware this Menu is hidden i had first switch to marlin to get this setting)
                  dc42undefined 1 Reply Last reply Reply Quote 1
                    @siam it's possible that the version of PrusaSlicer you are using behaves differently from the unofficial build that I am using.
                    • SIamundefined
                      SIam @dc42
                      @dc42 you're right in the latest beta of prusaslicer the menu appears in reprap flavor
