    firmware 3.4 Rc1 Heater Fault
    696
    • massimilianocontiundefined
      massimilianoconti @T3P3Tony
      when I start tuning takes too long something in the algorithm must be changed. if I put 3 as hysteresis comes to completion for example. something needs to be changed in the tuning procedure. my hotend is geometrically excellent, it is designed to perform every temperature and material
      T3P3Tonyundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • T3P3Tonyundefined
        T3P3Tony administrators @massimilianoconti
        @massimilianoconti do me a favour and run the tuning and post the results here.
        www.duet3d.com
        massimilianocontiundefined 1 Reply Last reply Reply Quote 0
          10/2/2022, 13:29:16 Warning: heater behaviour was not consistent during tuning
          Auto tuning heater 1 completed after 3 idle and 50 tuning cycles in 2520 seconds. This heater needs the following M307 command:
          M307 H1 R2.558 K0.275:0.103 D6.31 E1.35 S1.00 B0 V23.9
          Send M500 to save this command in config-override.g
          10/2/2022, 13:05:33 Warning: heater behaviour was not consistent during tuning
          Auto tune starting phase 4, measuring with fan on
            Phaedrux Moderator @massimilianoconti
            @massimilianoconti said in firmware 3.4 Rc1 Heater Fault:
            Can you give us some details about it?
              massimilianoconti
              my hot end is Phaetus dragonfly bmsBMSÕ«×Õ+⵿íÕ×ï.stl BMS Wireframes (7).pdf
                That's a lovely hotend. What power is the heater? Are you using the sock? Do you have a part cooling fan and duct? Can you share an image of the temperature graph from the tuning?
                massimilianocontiundefined 2 Replies Last reply Reply Quote 0
                • amjm22undefined
                  amjm22
                  Have you tried bumping up the "deadtime" D6.31? I bumped mine up to D8.31 and the heat faults have gone away.
                    massimilianoconti @amjm22
                    I try thanks
                      massimilianoconti @Phaedrux
                      you have the silicone socks I'm reviewing everything as soon as I perform a new test I attach it
                      amjm22undefined 1 Reply Last reply Reply Quote 0
                        hello as soon as I have the data I attach them. I wanted to know what compiler you need to open the source code to change the firmware... from the asset I downloaded in zip the purge code but you need a compiler ...
                        • amjm22undefined
                          amjm22 @massimilianoconti
                          @massimilianoconti yes
