What's my problem?
@phaedrux Not at all, thank you. I've been there. Totally forgot about it
I did some investigation and so far have found that I have some temperamental linear rail blocks. I built an entirely new kinematics that is wider to sit on top of the existing frame and hold the e3d tool changer setup.
I had to buy new longer rails and it turns out that if the screws used to mount into the block are even a hair too long, the blocks actually bind on the rail.
The screws don't even impinge directly on the rail, so it must be deforming something inside the block.
@gnydick I printed the ringing tower again cycling through the algorithms every 5mm and decided based on that. For the bed slinger I did this on, mvz came out front.
Again: Check the belts.
"Tune" them, so the equal length long runs give the same note when you pluck them.The long runs on my CoreXY machine (520mm) ring at near the same pitch as the next to lowest string on a bass guitar, around 55Hz.
If they are significantly lower than that for a similar length, or very unequal, it will cause print accuracy problems.
I don't use input shaping, just very low pressure advance.
Thanks for the input, all. My belt path is quite long and it really needed tensioning. It wasn't tight enough to even resonate. That made a marked improvement.
I've done a bit more fiddling and things are a lot better now. The print head is heavy and the cross beam is just the mgn rail which twists quite easily, so I think I'm at the envelope of what I can expect without input shaping.
