    [3.4.0rc1] I think the bed heater is overheating?
    Beta Firmware
    786
    • Gixxerfastundefined
      Gixxerfast
      Started to heatsoak the V2.4 at 115 bed temp as usual and after a while it started smelling really really bad and couldn't figure out what it was until I looked at my extra corner bed thermistor which was at 116C.
      That never happens, I can heat as long as I like at target 115C and it will go to max 113C.
      Now, I don't know what has happened here as the printer hasn't printed anything after the upgrade to RC1.
      I just wanted to document it here until I can test some more as I'm going to cool it down and downgrade to beta7 and see what happens.
      I really hope I haven't burned the glue to the heater mat because it really stinks now.
      As you can see the extra corner bed thermistor shows higher temp than the actual mat thermistor.
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.2 on Mon Sep 13 2021 16:36:36 GMT+0200 (centraleuropeisk sommartid)
      ; Based on configuration by OC-Geek
      M111 S0                	; Debugging off
      G21                    	; Work in millimetres
      G90                     ; send absolute coordinates...
      M83                     ; ...but relative extruder moves
      M669 K1                 ; select CoreXY mode
      ; Limit axis
      M564 S1 H1             	; Forbid axis movements when not homed
      ; H1	Forbid movement of axes that have not been homed
      ; S1	Limit movement within axis boundaries
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      ; Fysetc 12864 display Color
      M918 P2 R6 C30 E4 F200000  	; Configure direct-connect display
      ; P2  	128x64 display using ST7567 display driver chip
      ; R6  	Display resistor ratio, in range 1 to 7. Only used with ST7567-based displays.
      ;		The default value of 6 is suitable for the Fysetc Mini 12864 display.
      ; C30	Display contrast, in range 0 to 100
      ; E4	The number of pulses generated by the rotary encoder per detent. Typical values are 2 and 4
      ; F...	SPI clock frequency in Hz, default 2000000 (i.e. 2MHz)
      M150 X2 R0 U255 B0 P200 S3   ; Set LED colours
      ; X2 		LED type: X0 (default) = DotStar, X1 = NeoPixel, X2 = Panel 12864
      ; R,U,B		Set the LED colour (note Fystec uses GRB space instead ... (Red and Green switched over)
      ; S3 		Number of individual LEDs to set to these colours
      ; NETWORK
      ; Need to set up WIFI
      ; M587 S"SSID" P"PWD"
      ; This needs to be as a first step via USB like when fw ver is checked
      ; It is permanently stored in the card after that
      ; https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet
      M550 P"voron2"          ; set printer name
      M552 S1                                          ; enable network
      M586 P0 S1                                       ; enable HTTP (for DWC)
      M586 P1 S1                                       ; enable FTP (for remote backups)
      M586 P2 S1                                       ; disable Telnet
      ; DRIVERS
      ; --- Z Drive map ---
      ;    B_______A
      ;    | 1 | 2 |
      ;    | 0 | 3 |
      ;      front
      ; (looking at the printer from the top)
      ; Driver directions
      ; M569: Set motor driver direction, enable polarity and step pulse timing
      ; This command has LOT of parameters ... e.g. stealthChop2 ...
      ; Pnnn 		Motor driver number
      ; Snnn		Direction of movement 0 = backwards, 1 = forwards (default 1)
      M569 P121.0 S1                                   ; E - physical drive 121.0 goes forwards
      M569 P0.0 S1 D2                                  ; A -> Y - physical drive 0.0 goes forwards
      M569 P0.1 S1 D2                                  ; B -> X - physical drive 0.1 goes forwards
      M569 P0.3 S1                                     ; Z0 - physical drive 0.3 goes forwards
      M569 P0.4 S0                                     ; Z1 - physical drive 0.4 goes backwards
      M569 P0.5 S1                                     ; Z2 - physical drive 0.5 goes forwards
      M569 P0.6 S0                                     ; Z3 - physical drive 0.6 goes backwards
      M584 X0.0 Y0.1 Z0.3:0.4:0.5:0.6 E121.0           ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                          ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E400.00                ; set steps per mm
      ; Accelerations and speed are set in separate macro
      M98 P"/macros/set_normal_speed.g"
      ; Stepper driver currents
      ; set motor currents (mA) and motor idle factor in per cent
      ; Drive currents
      M906 X1400 Y1400 Z1200 E500 I70 ; XYZ and E current
      M84 S120                        ; Idle timeout
      ; Xn,Yn endstop: 0 = none, 1 = low end, 2 = high end
      ; Snnn 	1 = switch-type (eg microswitch) endstop input
      ;		2 = Z probe (when used to home an axis other than Z)
      ;		3 = single motor load detection
      ;		4 = multiple motor load detection (see Notes)
      ; P"pin_name"
      M574 X2 S1 P"121.io0.in"                       ; configure active-high endstop for high end on X via pin 121.io0.in
      M574 Y2 S1 P"0.io1.in"                         ; configure active-high endstop for high end on Y via pin io1.in
      M574 Z0 p"nil"                                  ; No Z endstop
                                                      ; Extruder never stops :-)
      ; Axis travel limits                            ; Mind this is travel NOT print area
      M208 X-4:300 Y0:305 Z-5:265                       ; Set axis minima - negative X is to have 0,0 on bed corner
                                                      ; WARNING on Z not to hit the roof - this is set here
      ; Belt Locations
      M671 X-65:-65:365:365 Y0:395:395:0 S20      ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
      											; Position of the bed leadscrews.. 4 Coordinates
      											; Snn Maximum correction to apply to each leadscrew in mm (optional, default 1.0)
                                                  ; S20 - 20 mm spacing
      M557 X30:270 Y30:270 P7                     ; Define bed mesh grid (inductive probe, positions include the Y offset!)
      ; Bed heater
      M308 S0 A"Bed Heater" P"temp0" Y"thermistor" T100000 B3950     ; configure sensor 0 as thermistor on pin temp0
      ;M308 S0 P"temp1" Y"thermistor" T100000 B3950     ; configure sensor 0 as thermistor on pin temp1
      M950 H0 C"out0" Q10 T0                               ; create bed heater output on out0 and map it to sensor 0
      M307 H0 R0.620 K0.495:0.000 D0.91 E1.35 S1.00 B0
      ;M307 H0 B0 R0.637 C222.4 D0.95 S1.00 V24.0
      ;M307 H0 B0 R0.602 C315.3 D0.89 S1.00 V24.0
      ;M307 H0 B1 S1.00                                ; Enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                          ; map heated bed to heater 0
      M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
      M308 S2 A"Extra Bed Temp" P"temp1" Y"thermistor" T100000 B3950     ; configure sensor 2 as thermistor on pin temp0
      M143 H2 S130
      ; Hotend heater
      ;M308 S1 P"121.temp0" Y"thermistor" T100000 B4267 ; configure sensor 1 as thermistor on pin 121.temp0
      M308 S1 P"121.temp0" Y"pt1000"                   ; configure sensor 1 as pt1000 on pin 121.temp0
      M950 H1 C"121.out0" T1                           ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 R2.605 K0.363:0.000 D7.04 E1.35 S1.00 B0 V24.2
      ;M307 H1 B0 R2.638 C196.3 D6.34 S1.00 V24.2       ; NF Coated Copper nozzle 0.4
      ;M307 H1 B0 R2.406 C188.5 D6.38 S1.00 V24.2       ; HF CHT Nozzle 0.6
      ;M307 H1 R2.796 K0.530:0.000 D6.11 E1.35 S1.00 B0 V23.9
      ;M307 H1 R2.897 K0.551:0.000 D6.38 E1.35 S1.00 B0 V23.9
      ;M307 H1 B0 R2.518 C174.0 D6.14 S1.00 V23.8
      ;M307 H1 B0 R3.409 C154.0 D3.92 S1.00 V23.8
      ;M307 H1 B0 S1.00                                 ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                     ; set temperature limit for heater 1 to 280C
      ; SENSORS MISC
      ; Define MCU sensors which will be available in DWC Extra View
      M308 S3 A"MCU" Y"mcu-temp" 				; Officially NOT supported on Mini 3 5+ however seem to work
      M308 S4 A"Duet Drivers" Y"drivers" 		; This is not really working as it is just a threshold crossing
      ; CHAMBER SENSOR
      M308 S10 A"Chamber" P"0.temp2" Y"thermistor" T100000 B3950
      ; Z PROBES K0 (Klicky mag probe) and K1 (Microswitch Z0)
      ; M558: Set Z probe type
      	; P5/P8 	select a switch by default (normally closed) for bed probing between the In and Gnd pins of the Z-probe connector
      	; C			specifies the input pin and the optional modulation pin. This parameter is mandatory
      	; Tnnn 		Travel speed to and between probe points (mm/min)
      	; Fnnn 		Feed rate (i.e. probing speed, mm/min) e.g. 60 is one mm per second
      	; Hnnn 		Dive height (mm)
      	; Annn 		Maximum number of times to probe each point, default 1
      	; Snnn 		Tolerance when probing multiple times, default 0.03mm
      	; Rnnn 		Z probe recovery time before the probing move is started , default zero (seconds)
      	; B0		B1 Turn off all heaters while probing, default (B0) leaves heaters on.
      	; I0		Invert (I1) or do not invert (I0, default) the Z probe reading
      ; G31: Set Current Probe status
      	; K0		Z Probe Number
      	; Pnnn 		Trigger value
      	; Xnn Ynn 	Probe offset (from Noozle)
      	; Znnn 		Trigger Z height - Set the said Z when the probe triggers !!
      ; MAG PROBE (GND, IO)
      ; This is the Euclid probe with microswitch
      M558 K0 P8 C"121.io2.in" T18000 F180 H10 A10 S0.0025
      G31 K0 P500 X0 Y23.5 Z9 ;Z7.438
      ; Z-SWITCH
      ; This is the microswitch which is pressed by the Noozle
      M558 K1 P8 C"io5.in" T18000 F180 H3 A10 S0.0025 R0
      ; Omron micro switch
      G31 K1 P500 X0 Y0 Z1.20
      ; Part cooling fan
      M950 F0 C"121.out1"                              ; create fan 0 on pin 121.out1 and set its frequency
      M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
      ; Hotend fan
      M950 F1 C"121.out2"                              ; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
      ; MCU fan
      M950 F2 C"!0.out4+0.out4.tach" Q25000              ; create fan 2 on pin out4 and set its frequency
      M106 P2 H3:4 L0.2 X1.0 T30:50 C"Controller fan 1"  ; controlled by Sensor 3 - MCU
      ;M106 P2 H-1 C"Controller fan 1"
      ; Controller bay fan
      M950 F3 C"!0.out3+0.out3.tach" Q25000              ; create fan 3 on pin out3 and set its frequency
      M106 P3 H0 L0.2 X0.7 T60:120 C"Controller fan 2"
      ;M106 P3 H-1 C"Controller fan 2"
      ; Nevermore Filter fans
      M950 F4 C"0.out5"                                ; create fan 4 on pin 0.out5 and set its frequency
      M106 P4 H0 S0.65 T65 C"Nevermore fan"            ; set fan 4 value. Thermostatic control is turned on
      M563 P0 D0 H1                                    ; define tool 0
      G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
      G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
      M955 P121.0 I05
      ; Input shaper
      ;M593 P"mzv" F47
      ;M593 P"zvdd" F70 S0.1
      M593 P"mzv" F44
      ; Pressure advance
      M572 D0 S0.055
      ; defines global variables
      M98 P"/macros/define_global_vars.g"
      ; Load override parameters
      M501
      T0
      2022-02-15 20:59:10	m122
      RepRapFirmware for Duet 3 Mini 5+ version 3.4.0rc1 (2022-02-09 10:27:22) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: H1668-Y296U-D65J0-40KMA-KR03Z-RK6ZH
      Used output buffers: 3 of 40 (31 max)
      Static ram: 103652
      Dynamic ram: 116952 of which 12 recycled
      Never used RAM 17976, free system stack 152 words
      Tasks: NETWORK(ready,14.5%,206) HEAT(notifyWait,0.0%,315) Move(notifyWait,0.0%,268) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,337) TMC(notifyWait,1.2%,71) MAIN(running,83.4%,428) IDLE(ready,0.0%,29) AIN(delaying,0.8%,264), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:41:31 ago, cause: power up
      Last software reset at 2022-02-14 21:22, reason: User, GCodes spinning, available RAM 18104, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      MCU revision 3, ADC conversions started 2491216, completed 2491215, timed out 0, errs 0
      Step timer max interval 935
      MCU temperature: min 33.9, current 34.2, max 34.2
      Supply voltage: min 24.3, current 24.4, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/5, heap memory allocated/used/recyclable 2048/232/162, gc cycles 0
      Events: 1 queued, 1 completed
      Driver 0: pos 12800, standstill, SG min 0, read errors 0, write errors 0, ifcnt 19, reads 51320, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: pos 11200, standstill, SG min 2, read errors 0, write errors 0, ifcnt 19, reads 51320, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: pos 24000, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 51320, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: pos 0, standstill, SG min 2, read errors 0, write errors 0, ifcnt 16, reads 51320, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: pos 0, standstill, SG min 2, read errors 0, write errors 0, ifcnt 16, reads 51320, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: pos 0, standstill, SG min 2, read errors 0, write errors 0, ifcnt 16, reads 51320, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 6: pos 0, standstill, SG min 2, read errors 0, write errors 0, ifcnt 16, reads 51320, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Date/time: 2022-02-15 20:59:08
      Slowest loop: 4.75ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.3ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 11, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 27, completed 27, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.4
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 5081, received 11290, lost 0, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 264, free buffers 18 (min 18), ts 2823/2823/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 202.75ms; fastest: 0.06ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      Failed messages: pending 0, notready 0, noresp 1
      WiFi firmware version 1.26
      WiFi MAC address f0:08:d1:02:eb:c9
      WiFi Vcc 3.36, reset reason Power up
      WiFi flash size 2097152, free heap 24272
      WiFi IP address 192.168.1.191
      WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
      Ender 3 Pro with BTT SKR-2 + RRF
      Gixxerfastundefined 1 Reply Last reply Reply Quote 0
        Gixxerfast @Gixxerfast
        Actually the PEI sheet just loosened completely from the spring steel sheet.
          Did the main bed thermistor lose contact?
            Gixxerfast @Phaedrux
            @phaedrux I'll have a look as soon as it cools down enough to touch. I'll take the bed off and see.
            The graph looks fine otherwise though.
              Was the bed heater attached by 3M adhesive sheet or with RTV silicone?
              The 3M adhesive isn't a good option for high temps and will delaminate eventually.
                @phaedrux It's some higher speced 3M adhesive as recommended from Fermio Labs
                The mat and thermistor feels fine though, firm and set.
                I'm going to remount the bed and do some tests. Glad I had the extra thermistor.
                The PEI just rolled off.
                  Maybe so, but I'd still be more inclined to follow Keenovo's own recommendations.
                  edcf5a62-3a6a-41fb-8b45-2e4803a65975-User's-Manual-Keenovo-Flexible-Heaters.pdf User's-Manual-Keenovo-Flexible-Heaters.pdf
                  Gixxerfastundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                    @phaedrux Yes, I have no knowledge of that myself so I have installed as Fermio has recommended it. When asked they say that the Keenovo recommendation is for general purpose usage in wet areas for heater tanks and other places not as pristine as inside a printer.
                    There will be a few thousand Vorons failing soon if the 3M adhesive doesn't hold up. Usually the RTV is only placed around the edges as a precaution. It will not stop the mat from loosen from the aluminium bed and cause thermistor misreadings if the adhesive fails.
                    Anyhow, that's a different discussion.
                    However, without knowing of even having thought much about it, I think that if the thermistor and mat would have losened from the bed it would've read a higher value than the actual bed as the energy cannot be absorbed by the metal and the thermistor is attached on top of the mat. Now, it read a lower value.
                      Well, Haven't been able to recreate anything suspicious at all.
                      What happened was strange, as the overwhelming smell of overheating glue and the self peeling PEI plus the extra bed end thermistor reading a value much to high. Never measured more than the set temperature before. Always 5 - 10C lower.
                      Anyway, as I can't recreat this it's probably for the best to close this thread.
                      • zaptaundefined
                        zapta @Phaedrux
                        @phaedrux said in [3.4.0rc1] I think the bed heater is overheating?:
                        Is the high temp RTV method preferred over that 3M double sided sheet? I have 3M as the main adhesive and RTV around, heating the bed up to 110C nominal.
                          Phaedrux Moderator @zapta
                          @zapta said in [3.4.0rc1] I think the bed heater is overheating?:
                          It would be preferred for me. From the specs I've been able to find of the 3M sheet it's not really meant for long term high heat use or repeated heat cycling. Eventually it deteriorates. Adding RTV to the edges to seal them at least keeps them from peeling away, and perhaps through suction would keep the center from releasing.
                          Here the 3M has given way at the center of the mat. It's not a good design as there is no strain relief on the cabling and at temp the 3M has let go from the gentle pull of the cable.
                          There have been other cases where pockets have formed and the heater has burnt up from lack of contact causing hot spots.
                          Given the low cost of 500c RTV silicone ($10) why not?
                          zaptaundefined Gixxerfastundefined 2 Replies Last reply Reply Quote 0
                          • zaptaundefined
                            zapta @Phaedrux
                            Yes, it's sounds as the right thing to do. In my case I already have a bed with the 3M adhesive and RTV around the edges as you recommended in an old thread. Will add it to my TODO list. Not sure how easy it is to clean the existing RTV from the bed.
                            The reason I am looking into is is a thermal fuse blowout I had a few days ago. It's a 115C fuse with a bed I heat to 110C (originally I planned going only up to 100C). Everything looks good and I ordered a 135C thermal fuse but may go the full RTV route down the road.
                            Phaedruxundefined Velviaundefined 2 Replies Last reply Reply Quote 0
                              @phaedrux Yes, you are of course right. More safety is never wrong. In my case I bought the variant which goes right to the edge and only leaves < 5mm either side.
                              If you want to go full RTV one have to either remove the 3M glue from the heater or buy the version without 3M tape.
                              I have this idea of making a thinish clamp in aluminium. Sort of a skeleton frame which is hold to place by small spring loaded screws in the extra three holes which the Voron beds usually have to be compatible with the 1.8/Trident models. It wouldn't have any other purpose than give some peace of mind and maybe a stress relief for the heater/thermistor cables.
                              Well, we'll see. It's not stupid expensive to send out for laser cutting.
                                Not easy. The 3M tape can be dissolved with a citrus oil solvent, but the RTV silicone would need to be cut away with a blade. Not likely worth the effort.
                                zaptaundefined 1 Reply Last reply Reply Quote 0
                                • zaptaundefined
                                  zapta @Phaedrux
                                  I got a nice 250mm bed from a european vendors that doesn't ship anymore to the US. Will need to find another source. 😉
                                  • Velviaundefined
                                    Velvia @zapta
                                    @zapta Is it possible to attach a bed with only RTV? Why is this not the norm? The 3M adhesive kinda sucks for anything over 110 C. Does Keenovo deliver pads with no adhesive?
                                    Homegrown, grass fed and organically built 350mm delta
                                    Phaedruxundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                      Phaedrux Moderator @Velvia
                                      @Velvia said in [3.4.0rc1] I think the bed heater is overheating?:
                                      You can custom order from them.
                                      • zaptaundefined
                                        zapta @Velvia
                                        @Velvia, I read that this is the recommended way now, but I don't have any experience with it, my heater is attached with that 3M high temp adhesive. I just added RTF along the edges.
                                        • mrehorstdmdundefined
                                          mrehorstdmd
                                          The bed plate acts as a heat sink/heat spreader for the heater. If part of the heater separates from the bed, that part gets extra hot. Here's what happens to the heater when the 3M adhesive starts to let go:
