    Raise limits for "TRUE BED LEVELING"
    244
    • peirofundefined
      peirof
      on a CoreXY printer, with 3 independent Z motors, I am trying to use "TRUE BED LEVELING", but when I try, I get this error message.
      G32 Error: Some computed corrections exceed configured limit of 5.00mm: 1.912 -6.511 4.985
      I understand that it is because the limits for the "TRUE BED LEVELING" are exceeded
      Where those limits are increased? (5 mm seems a bit fair to me)
      fcwiltundefined 2 Replies Last reply Reply Quote 0
      • engikeneerundefined
        engikeneer
        You set the limits in your M671 command, using the S parameter
        https://duet3d.dozuki.com/Wiki/M671
        Default is 1.0mmm, so I;m guessing you've already modified that in your config?
        General reason for keeping your limit set low is because if there is an issue with the measurements (probe fails, or you have the Z motors mapped incorrectly), it could attempt to do a massive (but incorrect) correction and cause significant damage to your bed.
        Personally I set my limit at 2.0mm. I only ever exceed that if there is something mechanical I have done (e.g. messed with the Z steppers and moved them). I'd then power the machine back off and slowly hand rotate the steppers to get the bed more level, before powering it back on and trying G32 again. At -6.5mm & +4.9mm, your bed must be on a very big angle!
        i3 clone with a bunch of mods
        • fcwiltundefined
          fcwilt @peirof
          @peirof
          Increase the limit to see if you can avoid the error.
          Then verify that the bed is actually becoming more level.
          If the configuration for bed leveling is wrong the bed can become less level.
          peirofundefined 1 Reply Last reply Reply Quote 0
          • peirofundefined
            peirof @fcwilt
            @fcwilt the bed is very inclined, it is the first time that the printer is put into operation... if this parameter is so delicate, another thing that I can do is do, it is an approximate leveling "by hand", turning the leadscrew manually until is in the limits... and then execute the "TRUE BED LEVELING"
            • fcwiltundefined
              fcwilt @peirof
              @peirof
              Given the limits of bed leveling in coping with a seriously out of level bed you might consider adding Z endstop sensors to each Z axis.
              Doing this allows you to home Z using the endstops sensors instead of the Z probe. Then you can use bed leveling to fine tune the bed.
              Here is a quick-and-dirty video of my printer. I intentionally put the bed seriously out of level.
              Bed Leveling Video
              oliofundefined 1 Reply Last reply Reply Quote 1
              • oliofundefined
                oliof @fcwilt
                @fcwilt how is that configured? I'm intrigued and would like to know more.
                • fcwiltundefined
                  fcwilt @oliof
                  @oliof said in Raise limits for "TRUE BED LEVELING":
                  All you need is the following with the appropriate pin names for your hardware.
                  M574 Z1 S1 P"!duex.e2stop + !duex.e3stop + !duex.e4stop" ; configure three Z endstops
                  Also the order of the endstops has to match the order of the Z steppers as that determines which endstop is checked for a given Z stepper.
                  oliofundefined 1 Reply Last reply Reply Quote 2
                  • oliofundefined
                    oliof @fcwilt
                    @fcwilt Super nice and easy to set up, thanks for indulging me (-: I'll be building another triple Z setup where I will give this a go.
