    Basic Telnet Connection Help
    1.0k
    • btmclainundefined
      btmclain
      Hi all,
      I am hoping to read basic telnet messages sent through M118. I am running my Duet in standalone mode and it is directly connected to my pc. I am trying to use the socket library in python to listen for messages, but I am not having any luck. My basic config.g file contains the following:
      global g = 0
      M586 P2 S1 R23
      M553 P255.255.255.0
      M552 S1 P192.168.2.80
      I am using the following macro to try to test the telnet messages:
      set global.g = 0
      while global.g < 20
      	M118 P4 S"message"
      	set global.g = global.g + 1
      	G4 S3
      And I am trying to use the following super basic Python script to listen:
      import socket
      import sys
      sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
      server_address = ('localhost', 23)
      sock.bind(server_address)
      sock.listen(1)
      while True:
          print(sys.stderr)
          print('waiting for a connection')
          connection, client_address = sock.accept()
      If anybody could help me out I would definitely appreciate it. Thanks in advance!
      alankilianundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @btmclain
        @btmclain
        I don't get what you're trying to do.
        Where are you running the python script? On your PC?
        If so, it's listening, but there's nothing that is going to try to connect to your PC.
        Maybe you want to run a python script on your PC that connects to the Duet's telent port?
        btmclainundefined 2 Replies Last reply Reply Quote 0
        • btmclainundefined
          btmclain @alankilian
          @alankilian Hi thanks for the quick reply. To be honest I am not really sure what I am doing.
          Yes I am running the python script from my PC.
          I was under the impression that the Duet would send a message to the specified port on my pc. I am obviously mistaken. Let me try to connect to a telnet port on the duet and see how that goes.
          alankilianundefined 1 Reply Last reply Reply Quote 0
          • btmclainundefined
            @alankilian so I used the following line to try to connect to the machine:
            sock = socket.create_connection((duet_host, 23), timeout=10)
            I am getting this response: [WinError 10061] No connection could be made because the target machine actively refused it
            Is there a security setting within the duet that is causing this to happen?
              @btmclain
              Looking HERE
              I got this working:
              #!/usr/bin/env python3
              import socket
              HOST = '192.168.0.104'  # The server's hostname or IP address
              PORT = 23           # The port used by the server
              with socket.socket(socket.AF_INET, socket.SOCK_STREAM) as s:
                  s.connect((HOST, PORT))
                  data = s.recv(1024)
                  print('Received', repr(data))
                  data = s.recv(1024)
              192.168.0.104 is the IP address of my duet and I got several "message" printed from Python.
              I'm not a Python guy, but you might get farther with this.
              btmclainundefined Mastermarkundefined 2 Replies Last reply Reply Quote 1
              • btmclainundefined
                @alankilian That worked! Thank you very much for the help. I will run with it from here
                  @btmclain Excellent! Glad to be of service.
                    dc42 administrators @btmclain
                    @btmclain which Duet are you using, and which firmware version?
                    You can run a program such as Putty on the PC to test the Telnet connection.
                    • btmclainundefined
                      btmclain @dc42
                      @dc42 We are using a Duet 3 MB 6HC with the latest firmware, 3.3 I believe? Alan's answer was perfect, it is exactly what I was looking for.
                      • btmclainundefined
                        btmclain @dc42
                        This post is deleted!
                        • alankilianundefined alankilian referenced this topic
                        • Mastermarkundefined
                          Mastermark @alankilian
                          @alankilian i know this topic is old but ive been looking into the same thing im trying to grab the macros from the duet but ive had no joy so far using python
                          • stuartofmtundefined stuartofmt referenced this topic
