    Weird error message when calibrating nozzle heater....
    • peirof
      peirof last edited by
      hi,
      i have try to tunning nozzle heater temperature control.
      With this gcode
      M303 H1 S240
      and.... this error
      21/2/2022 10:38:35	Error: Heater 0 fault: monitor 0 was triggered
      21/2/2022 10:38:32	Auto tune starting phase 2, settling
      21/2/2022 10:37:17	Auto tune starting phase 1, heating up
      21/2/2022 10:37:12	M303 H1 S240
      Auto tuning heater 1 using target temperature 240.0°C and PWM 1.00 - do not leave printer unattended
      this bug is new. Implying?
      gloomyandy 1 Reply Last reply Reply Quote 0
        What firmware version?
        For tuning the hotend, try using M303 T0 S240 instead to try tuning as a tool instead of just a heater. This will use the fan to try and compensate for it's cooling effect.
        peirof 1 Reply Last reply Reply Quote 0
        • gloomyandy
          gloomyandy @peirof last edited by
          @peirof When you ran this test did you also have the bed heater turned on?
          • peirof
            peirof @gloomyandy last edited by
            @gloomyandy no...
            • peirof
              peirof @Phaedrux last edited by
              @phaedrux said in Weird error message when calibrating nozzle heater....:
              M303 T0 S240
              I have tried that gcode (M303 T0 S240), and the same error. But the Hotend fan does not turn... I thought that the fan was not working... but on the Status page, I made it turn manually... I am going to check if I have the temperature sensor configured correctly, maybe it's reading another temperature than the real one...
