FAN 0 & FAN 1 allways ON
@fcwilt I have connected this fan in the non PWM fan output
@phaedrux That's the problem. The extruder fan, NOT the part cooling fan is running full blast. Allways. Usually these fans turn on after T45celcius automatically
Sorry, can you clarify which fan is connected where?
What happens when you send M106 P1 S1 H-1 ?
@cozyp said in FAN 0 & FAN 1 allways ON:
Sorry but I don't understand what you mean by that.
I was wanting you to verify that whatever output you were using was still working.
Ok. First things first.
Phaedrux, I sent M106 on config file. Nothing changed. Fan stays ON no matter what. FAN 1 was added as option on DWC screen, but it cannot be controlled, which is correct, as the fan is connected in a non PWM output.
dcwilt, the extruder heater fan and the motherboard fan are connected in a NON PWM output, but they allways stay ON, full blast no matter what....
I wanted to turn them on via thermostat, as they should work. Am I missing something???; Fans
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
M106 M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned on
M950 F2 C"fan2" Q100 ; create fan 2 on pin fan2 and set its frequency
M106 P2 H10:11 T40:70 ; set fan 2 value -
M308 S10 Y"mcu-temp" A"MCU" ; defines sensor 10 as MCU temperature sensor
M308 S11 Y"drivers" A"Duet stepper drivers" ; defines sensor 11 as stepper driver temperature sensor; Fans
M106 M106 P1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
M106 P2 H10:11 T40:70 ; set fan 2 value; Tools
G10 P0 X-15 Y-15 Z0 ; set tool 0 axis offsets
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C -
Yes,
M106 P1 S1 H-1
will disable thermostatic control and turn the fan on. SendM106 P1 S0
to turn it off again.@cozyp said in FAN 0 & FAN 1 allways ON:
Fan1 port is indeed PWM controllable.
Fan0, Fan1, Fan2 are controllable. Plus two more always on fan ports.
Which are you actually plugged into?
Fan0 1 2 can be used as thermostatically controlled or by the slicer to set speed for part cooling.
The always on ports are... always on.
If you send M106 P1 S0 and the fan won't turn off, then either it's plugged into a different port than you are expecting, or the fan mosfet has been damaged and failed in the on position.
I wanted to turn them on via thermostat, as they should work. Am I missing something???It sounds like you are referring to the "always on" fan outputs - they are not controllable.
I have plugged those two fans on the allways ON ports.
So, after reading your comments, I assume that they cannot be thermostatically controlled??? -
So, after reading your comments, I assume that they cannot be thermostatically controlled???They cannot be controlled in any way. They provide power to the connected fans when power is supplied to the board.
