    M592 activation issue
    344
    • RomeoFox
      RomeoFox last edited by RomeoFox
      Right now I am trying to calibrate the dynamic nonlinear extrusion (M592).
      -> https://forum.duet3d.com/topic/6015/guide-for-finding-the-values-for-m592-non-linear-extrusion/5
      The result of the table from the thread is the following command: M592 D0 A-0.11 B0.04 L2
      => Should result in an effective correction of 4% at 11.6 mm/s.
      Whereby with L2 any limitation should be switched off.
      For test purposes, I have tried values up to 0.2 for M592 Bxxx and have the impression that nothing is happening at all.
      For testing I use the following command: G91 G1 X-100 E100 F700
      However, I cannot see any difference between
      G91 G1 X-100 E100 F700 (due to movement with correction) and G91 G1 E100 F700
      Does G592 need to be activated elsewhere?
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0rc1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-02-09 10:28:13
        Phaedrux Moderator @RomeoFox last edited by
        @romeofox said in M592 activation issue:
        How are you comparing? The effect should be quite subtle regardless.
        RomeoFox 1 Reply Last reply Reply Quote 1
        • RomeoFox
          RomeoFox @Phaedrux last edited by
          @phaedrux said in M592 activation issue:
          I measure the filament feed on the feed side of the extruder by marking the filament with a pencil and steel ruler and extruding 100mm. At speeds below 5mm/s, the feed is exactly 100mm. At 11.7mm/s =700mm/min 4% are missing = only 96mm are fed.
          I would have expected 4%/4mm to be easily compensated.
            What is the volumetric rate that you are trying to push? Non-linear extrusion tries to compensate, but it can't push unmelted plastic.
            • RomeoFox
              RomeoFox @Phaedrux last edited by RomeoFox
              At 1.75mm filament, that's 28.2mm³ per second with a Dragon High Flow Hotend and ABS+.
              The extruder starts to slip through individual teeth between 900 and 1000 mm/min. Therefore, I assume that the 4% should actually still be possible at 700mm/min.
                As a simple test, does increasing the hotend temp allow for more expected results?
                RomeoFox 1 Reply Last reply Reply Quote 0
                • RomeoFox
                  @phaedrux
                  I tried today (+30°C) same behavior. From the answers I understand that it should have worked with the command M592 D0 A-0.11 B0.04 L2 alone, right?
                  Phaedrux dc42 2 Replies Last reply Reply Quote 0
                    I can't say that for certain.
                    If you use this technique for finding your volumetric flow rate, what do you get?
                    https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s177
                      dc42 administrators @RomeoFox last edited by
                      @romeofox to test that M592 is working I suggest you disconnect the hot end from the extruder so that there is no significant back pressure, and then measure amount extruded vs. speed.
                      timschneider 1 Reply Last reply Reply Quote 0
                      • timschneider
                        timschneider @dc42 last edited by
                        @dc42 said in M592 activation issue:
                        Sorry for recycling this thread but I discovered the same behaviour since 3.4.
                        Our method to calibrate nonlinear extrusion was
                        1. heat up the nozzole to working temperature
                        2. mark filament at 120mm
                        3. extrude with G1 E100 F30 (same as e-step calibration) and mesaure
                        4. repeat steps 2. and 3. for F60,90,120,150,180
                        5. calculate A and B
                        6. set A and B values
                        7. check result with mark 120mm, extrude G91 G1 X100 E100 F30 - F180 measure and compare
                        8. if not ok adapt A and B and re-run steps 6. - 8.
                        But since 3.4 step 7. is not working anymore - there is no difference in the values measured in step 3. - 4. and 7 - they are just about the same. upto 3.2.2 we had a difference upto 10%. We cannot use 3.3 because it will flood us with errors.
                        I looked at the code and found that you @dc42 did alot of work in that area (InputShaping).
                        We use an CoreXY with Duet2 an RRF 3.4.
                        dc42 1 Reply Last reply Reply Quote 1
                          dc42 administrators @timschneider last edited by dc42
                          @RomeoFox @timschneider I confirm that this is a bug in RRF 3.4. I will fix it in RRF 3.4.1.
                          Temporary workaround: for Duet 3 multiply the nonlinear extrusion A coefficient by 750000 and the B coefficient by (750000)^2. For Duet 2 use 937500 in place of 750000.
                          Thanks @timschneider for identifying the change that introduced the bug.
