    Hictop thermistors?
    • peirofundefined
      peirof
      Someone knows how config this thermistors
      [Hictop thermistor t](HICTOP Sensor/temperatura 5 x 100K ohmios NTC termistores para la impresora 3D Reprap https://www.amazon.es/dp/B015PX62F8/ref=cm_sw_r_apan_glt_i_RC0EWRHW2R3EY1XF5NNZ?_encoding=UTF8&psc=1)
      Thx
        It's likely a basic 100K B3950 thermistor.
        peirofundefined 1 Reply Last reply Reply Quote 1
        • peirofundefined
          peirof @Phaedrux
          @phaedrux these thermistors.... Are water resistant? Its for heat them in a liquid (oíl) for obtain resistence
          zaptaundefined 1 Reply Last reply Reply Quote 0
          • zaptaundefined
            zapta @peirof
            @peirof said in Hictop thermistors?:
            I am not an expert but they don't seem to be sealed. However, if the oil is isolating enough, it may work. You can try dipping them in oil at room temperature and measure if their resistance changes significantly.
              dc42 administrators @peirof
              @peirof it's difficult to recommendation settings without having a resistance vs temperature table for that thermistor.
              If it's for a bed heater then you can use R100000 B3950 C0 and get reasonable temperature accuracy up to at least 100C.
              If it's for a hot end heater then you really need to do better. Preferably, get a resistance-temperature table for that thermistor from the supplier of the thermistor.
