    ADVREF pin location on Duex 5 Expansion board
    • code7undefined
      code7
      I'm adding a Duex 5 Expansion board to my Duet 2 wifi controller setup and moving over the thermistors (3 through 7) to the expansion board. I have a setup similar to the one linked below by @Sphyloid. Can someone tell me where I need to move the wire that I currently have connected to the ADVREF pin on the Duet 2 to on the Duex 5 Expansion Board?
      https://forum.duet3d.com/topic/22581/duet-wifi-2-exp-thermistor-usage?loggedin=true
      Delta Printer Using a Duet 2 Wifi v1.04c, FW3.4.0beta2, Duet WiFi sever 1.26, Duet Web Control 3.3.0
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @code7
        @code7
        Can't you just connect the thermister to the Duex-5 connector?
        According to the schematic, the Duex5 has the 4.7K pullups already connected to ADVREF.
        code7undefined 1 Reply Last reply Reply Quote 1
        • code7undefined
          code7 @alankilian
          @alankilian
          Perfect - Thanks
