    Unreliable Homing in one Axis
    637
    • Superbrain8undefined
      Superbrain8
      Good Day,
      I have a bit of issues with the Homing of the X Axis on my printer using a Duet 3 Mini5+
      Homing Y and Z works as expected, Homing X is kinda unreliable, sometimes it moves a few mm towards the Endstop and just sets the current position as X home without triggering the endstop.
      config.g
      homex.g
      M122 Dump.txt
      M115 Output:
      FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.4.0rc2 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2022-02-22 17:07:35
      there is a Toolboard attached to the Printer, but the endstop is wired directly to the mainboard.
        Superbrain8
        probably should add that the endstop is functional, moving the axis into the endstop and calling M119 shows the endstop as triggered
        Stephen6309undefined 1 Reply Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt @Superbrain8
          @superbrain8 said in Unreliable Homing in one Axis:
          Have you tried it at full current? There is generally no reason to reduce it during homing.
          Also please get in the habit of copy-and-pasting your files using the </> tag, one tag per file. It saves folks the trouble of downloading them.
          Superbrain8undefined 2 Replies Last reply Reply Quote 0
          • Stephen6309undefined
            Stephen6309 @Superbrain8
            @superbrain8 Does X endstop show NOT triggered when the endstop is not depressed?
            Superbrain8undefined 1 Reply Last reply Reply Quote 0
              Superbrain8 @Stephen6309
              @stephen6309 shows as not triggered
                Superbrain8 @fcwilt
                @fcwilt will try
                  Superbrain8 @fcwilt
                  @fcwilt didnt worked out, behavior persists.
                  • fcwiltundefined
                    fcwilt @Superbrain8
                    OK.
                    What sort of endstop sensors are you using?
                      Superbrain8 @fcwilt
                      @fcwilt Inductive endstops that come with the Artillery Sidewinder.
                      • fcwiltundefined
                        fcwilt @Superbrain8
                        OK.
                        Since it appears to be a intermittent problem I would next see if the leads of the sensor are running close to the leads to a stepper motor.
                        It might be noise induced into the sensor leads.
                          Superbrain8 @fcwilt
                          @fcwilt probably is the issue, replaced the ribbon cable itself with individual wires, but i guess i have to optimize this more
                          (issue was present with the stock ribbon cable connecting the axis to the base, from there to the mainboard)
                          the thing is this issue was not present while running Marlin and klipper
                          • fcwiltundefined
                            fcwilt @Superbrain8
                            Possibly the Duet firmware has a quicker response time OR the other firmware has "de-bounce code" which can also help with ignoring transients.
                            Only @dc42 would know.
                              Superbrain8 @fcwilt
                              @fcwilt ok thanks,
                              will look into rerouting some of the wire and see if it will improve the situation.
                              • Superbrain8undefined Superbrain8 marked this topic as a question
                              • Superbrain8undefined Superbrain8 has marked this topic as solved
                                jay_s_uk @Superbrain8
                                @superbrain8 we've had a number of users with the sidewinder where endstops have been an issue as well as the wagster mod for the bltouch causing the pin to randomly deploy. its definitely the dodgy ribbon used for wiring.
                                  Superbrain8 @jay_s_uk
                                  @jay_s_uk this solves another issue, thanks for the reply.
                                  yea the ribbon sucks, replaced it with individual wires, but i have to tweak this a bit, rn there is to much crosstalk. will have to change some stuff, but im looking forward towards this.
                                    @superbrain8 does the ribbon cable carry motor wires as well as the endstop wires?
                                      jay_s_uk @dc42
                                      @dc42 yes it does
                                        dc42 administrators @jay_s_uk
                                        @jay_s_uk said in Unreliable Homing in one Axis:
                                        @dc42 yes it does
                                        Bad idea! Might possibly be workable if there are some ground conductors between the motor wires and the endstop wires.
                                        Maybe he could split the ribbon cable between the motor conductors and the endstop conductors, then keep the two parts of the ribbon cable separate.
                                          Superbrain8 @dc42
                                          @dc42 will be a non issue for me in the future, im working on replacing the entire ribbon cable due to its limitations.
                                          will run individual wires, just have to seperate them properly so they wont be close to stepper motor or other higher current wires.
