PT1000 on toolboard showing 2000c
I have a Duet3 6HC and a Toolboard1LC. I am using a PT1000 thermistor in my hotend and its been working great. Recently I got a temp reading that my hotend is at 2000 degrees (meaning no connection) so I ordered another PT1000 and installed it, and got the same reading. I remapped my thermistor from "P"20.temp0" to "P"20.temp1". Same issue. I remapped it and connected it to my 6HC "P"0.temp1" and it works fine and is showing correct temp. Does anyone have a suggestion to what it may be? Any help would be much appreciated.
Currently running
- Duet TOOL1LC firmware version 3.3
- Duet Web Control 3.3.0
When and where did you purchase the toolboard?
Can you share your config.g and the results of M98 P"config.g" and M122?
@phaedrux
Purchase Date of Toolboard1LC = April 28,2021 (filastruder.com)
Keep gettings errors when trying to add config.g and M122 -
One other issue that I found after I remapped the PT1000 to the Duet36HC was that the actual heater did not heat. I remapped it to the duet36hc also and its working fine. So looks like it might be a bad toolboard
@practac you can't use a thermistor on a different board to the one the heater is on
@jay_s_uk
okay. I moved the heater to the 6HC so its working. -
@jay_s_uk I disagree. I have my hotend heater connected to my Duet 3 and my thermistor connected to my tool board and it works fine.
@dhusolo it was a restriction in 3.3.0
@jay_s_uk said in PT1000 on toolboard showing 2000c:
To expand on that, it is a restriction on all "3"series firmware versions up to and including 3.3.0 and affects all expansion boards, not just tool boards.
I understand that but what I'm saying is that I'm running 3.3.0 and I have my hotend heater on my Duet 3 and the hotend thermistor is on the toolboard.
M308 S0 P"0.temp0" Y"thermistor" A"Bed" T100000 B4725 C0.0000000706 ; configure sensor 0 as thermistor on pin temp0 M308 S1 P"20.temp0" Y"thermistor" A"Hotend" T100000 B4680 C6.455513e-8 ; configure sensor 1 as thermistor on pin temp1-Matrix M950 H0 C"0.out1" T0 ; create bed heater output on out0 and map it to sensor 0 M950 H1 C"0.out2" T1 ; create nozzle heater output on out1 and map it to sensor 1
@dhusolo https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
According to the above, it's a permanent limitation for safety reasons. Maybe the rationale has changed but the documentation hasn't caught up?
@deckingman The documentation on the limitation says:
A heater on an expansion or tool board can only be controlled by a temperature sensor on the same expansion board. This is a safety precaution.
So it's the other way around from the firmware limitation, and (apparently) works.
Soooo.....Should I create another post so we can get back on topic?
I have my heater and my PT1000 currently attached and mapped to my Duet36HC, so they are working, when I have attached to my toolboard1LC:
P1000:
Connected and Mapped to Toolboard1LC Temp0 - Does not work
Connected and Mapped to Toolboard1LC Temp1 - Does not workHotend:
Connected and Mapped to Toolboard1LC Out0 - Does not workFan 1:
Connected and Mapped to Toolboard1LC Out1 PH4 - Does not workFan 2:
Connected and Mapped to Toolboard1LC Out2 PH3 - Does not workBLTOUCH:
Connected and Mapped to Toolboard1LC IO0 PH4 - WorksExtruder:
Connected and Mapped to Toolboard1LC Driver0 PH4 - WorksX Endstop:
Connected and Mapped to Toolboard1LC IO2 PH3 - Works -
@practac can you post your current config and an output of
M122 B20
@jay_s_uk that was sent yesterday along with another M122 . Here is the output from the M122 B20
M122 B20
Diagnostics for board 20:
Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
Never used RAM 3660, free system stack 2789 words
Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.0%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) TMC(delaying,2.8%,57) MAIN(running,92.2%,424) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
Last reset 00:01:01 ago, cause: power up
Last software reset time unknown, reason: AssertionFailed, available RAM 3392, slot 2
Software reset code 0x0120 ICSR 0x00000000 SP 0x2000415c Task Freestk 129 bad marker
Stack: 00000544 00022ffc 00019b65 20003134 00016cff 20003134 000163d1 20000ed0 00000000 00000001 00008275 200071c8 200071c8 200071e0 00000000 20000f50 00011647 000223b8 00022474 00021ac8 00019b05 200071c8 200071c8 20000f50 000083ed 200071d8 000009c7
Driver 0: position 0, 675.3 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 30754, writes 12, timeouts 0, DMA errors 0, steps req 0 done 0
Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
Peak sync jitter 0/5, peak Rx sync delay 195, resyncs 0/0, no step interrupt scheduled
VIN: 24.3V
MCU temperature: min 17.5C, current 22.8C, max 22.8C
Ticks since heat task active 64, ADC conversions started 61558, completed 61557, timed out 0, errs 0
Last sensors broadcast 0x00000000 found 0 69 ticks ago, loop time 0
CAN messages queued 182, send timeouts 0, received 470, lost 0, free buffers 37, min 37, error reg 110000
dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
Accelerometer detected: no
I2C bus errors 0, naks 3, other errors 0 -
@practac your config yesterday doesn't reference the toolboard for the PT1000. so can you confirm that thats definitely the one you're using?
@jay_s_uk yes sir it it the same toolboard.
This post is deleted!
