PT1000 on toolboard showing 2000c
@practac no, I meant is the config you posted yesterday definitely the version you are trying to use? Because if it is I'm not surprised it doesn't work. I'm asking because you've mentioned changing things to try and get it to work
This post is deleted! -
@practac said in PT1000 on toolboard showing 2000c:
M308 S1 P"0.temp1" Y"pt1000" A"Hotend" T100000 B4680 C6.455513e-8 ; configure sensor 1 as pt1000 on pin 20.temp0
You should leave off the T, B and C parameters for a PT1000. Although I doubt whether it will help. This may be a case of ESD damage to the series resistor on the toolboard.
Can you reconfigure your setup to use the PT1000 on the toolboard with those parameters removed?
@phaedrux
remapped temp probe to this:M308 S1 P"20.temp0" Y"pt1000" A"Hotend" ; configure sensor 1 as pt1000 on pin 20.temp0
Still showing Hotend at 2000c
Tried the other temp port on the toolboard with this:
M308 S1 P"20.temp1" Y"pt1000" A"Hotend" ; configure sensor 1 as pt1000 on pin 20.temp0Same results
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@phaedrux said in PT1000 on toolboard showing 2000c:
Done. Thank you and thank you to all the others that assisted.
