    Low voltage on Duet3 6CH IO pins
    duet3 6hc voltage
    • e4dundefined
      e4d
      I have Duet3 6CH and only have 2.41V on IO pins when I put them "high". If I understand correctly I should have 3.3V. The pin is wired to an SSR relay and the voltage is too low to turn it on. I checked the voltage at the input of the relay.
      Here's my config for this part :
      M950 S0 C"0.io7.out" Q1000
      M42 P0 S1
      Do you have any idea why I have such low voltage ?
      jay_s_ukundefined Gixxerfastundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @e4d
        @e4d what pins are you wiring between?
        e4dundefined 1 Reply Last reply Reply Quote 0
        • e4dundefined
          e4d @jay_s_uk
          @jay_s_uk I use the io7.out and GND pins of IO_7 connector
            jay_s_uk @e4d
            @e4d looking at the schematic the output ports are fed directly from the MCU so there may not be enough current to switch a relay (I believe typically only 3-5ma).
            You'd be better off using a fan output.
            Take 3.3v from and IO port and feed it through the relay to the out pin on a fan
            dc42undefined e4dundefined 2 Replies Last reply Reply Quote 0
              dc42 administrators @jay_s_uk
              @jay_s_uk said in Low voltage on Duet3 6CH IO pins:
              Most SSRs work with from 3 to 32V input, so for those types a fan output set to either VIN (which I assume is 24V) or 12V would be suitable. However, there are other alternatives:
              • If you are not using the Laser/VFD port you can use that. It provides a 5V signal level. Note, it is shared with OUT9.
              • The PS_ON output is an open-drain mosfet, so if you are not using it to control a power supply then you could connect the SSR - control terminal to it and the + control terminal to e.g. +5V from an IO connector. It's also likely that it would work with the + control terminal connected to the 5V_EXT_INPUT pin on the PS_ON/5V_EXT connector. However, PS_ON does not support PWM.
              • Gixxerfastundefined
                Gixxerfast @e4d
                @e4d May I ask which SSR you are using as many, for example, Omrons are speced to at least 5V to switch.
                Example: e761b1a4-6586-4eae-bd17-37842205a73c-image.png
                Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                Ender 3 Pro with BTT SKR-2 + RRF
                • e4dundefined
                  e4d @jay_s_uk
                  @jay_s_uk I had success with your proposition, thank you !
