    Solved How changes in config.g permanent?
    176
    • peirof
      peirof last edited by
      i am fine tunning extruder steps....
      and when i change M92 EXXX (in config.g, not by console), save config.g, delete config.g.back, and restart.... after restart i send M92 by console, and steps are not changed.
      What i have to do, for the change in config.g are permanent?
      fcwilt Phaedrux Nuramori 3 Replies Last reply Reply Quote 0
      • fcwilt
        fcwilt @peirof last edited by
        @peirof said in How changes in config.g permanent?:
        That should do what you wish so something is not right.
        Please copy-and-paste your config.g file using </> tag.
          Phaedrux Moderator @peirof last edited by
          Why are you deleting config.bak?
          Do you have a second M92 in config.g later in the file that is overriding?
          peirof 2 Replies Last reply Reply Quote 0
          • Nuramori
            Nuramori @peirof last edited by
            @peirof
            If you have a config-override file it may be negating your config changes.
              Phaedrux Moderator @Nuramori last edited by
              @nuramori said in How changes in config.g permanent?:
              @peirof
              M92 is not saved to config-override.g so unless he added it manually it should not be there.
              peirof 1 Reply Last reply Reply Quote 1
              • peirof
                peirof @Phaedrux last edited by
                This post is deleted!
                • peirof
                  @phaedrux said in How changes in config.g permanent?:
                  Not sure, I will check after... I suppose that no...
                  • peirof
                    @phaedrux
                    I find the mistake.... At the end of config.g, there was another M92 Exx...
                    Thx
                    • Topic has been marked as a question  Phaedrux Phaedrux
                    • Topic has been marked as solved  Phaedrux Phaedrux
