    MFM 0: tooLittleMovement
    Filament Monitor
    806
    • Idodgeadsundefined
      Idodgeads
      Hello, I bought a magnetic filament monitor at the first of this year, printed the housing and installed the monitor above the extruder on an aluminum mount. It was working with only the occasional error. In the last two weeks or so, the sensor seems to have gone bonkers. I can't get through a print now without multiple errors. I've read as much as I could find on this subject so as to try to fix the problem but I have run out of ideas.
      What I've tried.
      Checked for smooth filament movement and any debris in the housing/extruder gears.
      Adjusted extruder tension in both directions to eliminate the possibility of slippage/binding.
      Printed and installed the oldsalty3d idler mod.
      Checked to insure the magnet hasn't come loose from the shaft.
      Installed plastic shims under the circuit board to bring agc value from 54 to 81.
      Widened the sensitivity settings in config.
      Added A0 to config to only check forward movements.
      I did update the duet wifi firmware from 3.3 to 3.4rc1 prior to these problems, I don't know if that is a factor. The printer prints fine with sensor deactivated in config.
      I have not tried to isolate or shield the wiring to the sensor or roll back the firmware.
      I am not good with software/firmware so if anyone could offer me some guidance I would really like this sensor to work, it's the best option for my setup.
      Thank you,
      Nurgelrotundefined 1 Reply Last reply Reply Quote 0
      • Nurgelrotundefined
        Nurgelrot @Idodgeads
        @idodgeads I had a similar issue. Was working great for months and then just started randomly failing. Next time it fails run a M591 D0 and see if it still reporting agc values after the failure - or gives you any other oddness. Mine turned out to be a faulty signal wire that I must have not crimped good enough and it had come intermittently loose over time.
          What is the oldsalty3d idler mod?
          Rolling back to 3.3 to see if the behaviour changes would be helpful.
          Also updating to 3.4 RC2.
          Can you share your config.g so we can see the full configuration line for the sensor?
          Also send M591 D0 and post the results.
          Does the wiring run next to a heater or motor?
            Idodgeads
            Trying to post my reply, getting an error...?
              Idodgeads
              Trying again. So I checked my wire crimps, they look good. I could solder them but I don't think there's a problem there. Here's a link to the filament monitor mod. https://www.thingiverse.com/thing:4605070
              I started a print that gave me alot of problems a week ago and it didn't make it through the first layer before tripping the error.
              I would rather update to 3.4rc2 than roll back, but if it's necessary...
              My wires don't run next to a motor or heater. I can post a pic of the print head setup if you would like.
              M591 d0
              Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 24.80mm/rev, allow 50% to 140%, check printing moves every 5.0mm, version 3, mag129 agc 79, measured sensitivity 33.72mm/rev, min 49% max 127% over 15.3mm
                Idodgeads
                Here's config
                ; generated by RepRapFirmware Configuration Tool v3.2.2 on Mon Feb 08 2021 18:44:59 GMT-0500 (Eastern Standard Time)
                M550 P"My Printer" ; set printer name
                M669 K1 ; select CoreXY mode
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P0 S0 ; physical drive 0 goes backwards
                M569 P3 S0 ; physical drive 3 goes backwards
                M350 Z16 I0 ; configure microstepping without interpolation
                M350 X16 Y16 E16 I1 ; configure microstepping with interpolation
                M92 X160.00 Y160.00 Z1600 E833.00 ; set steps per mm
                M566 X850.00 Y850.00 Z80.00 E2000.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X9000.00 Y9000.00 Z900.00 E3800.00 ; set maximum speeds (mm/min)
                M201 X1850.00 Y1850.00 Z120.00 E3800.00 ; set accelerations (mm/s^2)
                M906 X1370 Y1370 Z1350 E1350 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X223 Y208 Z308 S0 ; set axis maxima
                M574 X1 S1 P"xstop" ; set active high endstops on low end of x travel
                M574 Y2 S1 P"ystop" ; set active high endstop on high end of y travel
                M574 Z1 S2 ; set endstops controlled by probe
                M307 H3 A-1 C-1 D-1 ; disable heater 3 on PWM channel for BLTouch
                M950 H3 C"nil"
                M558 P9 C"^zprobe.in" H8 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                G31 P25 X-33.33 Y-39.87 Z1.200 ; set Z probe trigger value, offset and trigger height
                M557 X5:215 Y5:195 S20 ; define mesh grid
                ;*** Thermistors
                ;* Bed
                M308 S0 P"bedtemp" Y"thermistor" T100000 R4700 B4138
                M950 H0 C"bedheat" Q10 T0
                M307 H0 R0.379 C322.8 D1.81 S1.00 V24.1 B0 ; disable bang-bang mode for the bed heater and set PWM limit
                ;M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
                M140 H0 ;Map heater control to GUI
                M143 H0 S110 ; set temperature limit for heater 0 to 110C
                ;* Hotend
                M308 S1 P"e0temp" Y"thermistor" T100000 R4700 B4725 C7.06e-8
                M950 H1 C"e0heat" T1
                M307 H1 R1.594 C336.7 D5.87 S1.00 V23.8 B0 ;disable bang-bang mode for the hotend and set PWM limit
                ;M305 P1 T100000 B4725 C7.06e-8 R4700 ; set thermistor + ADC parameters for heater 1
                M950 F0 C"Fan0" Q500
                M106 P0 S0 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                M950 F1 C"Fan1" Q500
                M106 P1 S1 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M950 F2 C"Fan2" Q500
                M106 P2 S1 H1 T35 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M950 F3 C"Fan" Q500
                M106 P3 S1 H1 T45 ; set fan 3 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M950 F4 C"Fan" Q500
                M106 P4 S1 H1 T45 ; set fan 4 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M950 F5 C"Fan" Q500
                M106 P5 S1 H1 T45 ; set fan 5 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M591 D0 P3 C"e0_stop" S1 R50:140 L24.8 E5.0 A0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0
                ; endstop input,enabled, sensitivity 24.8mm.rev, 50% to 140% tolerance, 5mm
                ; detect length
                  Idodgeads
                  Anyone have any ideas? Is there something obvious I'm not seeing? Thanks to you all that have chimed in so far, I do appreciate the help.
                  • Lo-Fiundefined
                    Lo-Fi
                    @idodgeads
                    I'd guess at this being a mechanical issue. It certainly seems to have been with mine. I redesigned the case, re-printed and it's been perfect so far.
                    I've just posted my updated design over here in another thread if you're interested in trying it out. I don't have a resin printer, so put a bit of work into getting it tweaked for FDM. STL if you want 'em.
                    My recent thread here:
                    https://forum.duet3d.com/topic/27515/automated-error-state-checking-help-me-think-this-through?_=1647278275938
                    For what it's worth, 3.4RC2 cured the "sensor error" stops I was getting, but not the movement ones. The updated housing is going strong and the sensor has been flawless. Had a few "sensor error" drops from crimps that had lost some spring early on, but fresh ones did nothing to solve the "too little movement".
                    My current M591 D0
                    Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.67mm/rev, allow 70% to 130%, check printing moves every 6.0mm, version 3, mag 131 agc 69, measured sensitivity 26.57mm/rev, min 98% max 103% over 10401.0mm
                    That's on a print with 2800 x 6.5mm retracts!
                    Idodgeadsundefined 1 Reply Last reply Reply Quote 1
                      Idodgeads @Lo-Fi
                      @lo-fi
                      Thanks for your reply. I'm eager to see what you changed in the housing design that made the difference. I was thinking my problem may be the springs tension on the bearing starting to weaken as my sensor was working pretty well. I'm going to devote time to this over the weekend, I'll report back what I find.
                      • Lo-Fiundefined
                        Lo-Fi
                        @idodgeads
                        My design goals:
                        • Keep the filament path clear of anything but the PTFE inserts, hob and idler.
                        • Align the PTFE so the filament is lightly pressed against the hobb even before the idler comes into play
                        • Add slightly more clearance for the hob and idler
                        • Add an indent to keep the idler spring in the correct position
                        • Achieve a tight fit for the plastic collets holding the PTFE
                        I used the official idler mounting, though I think I can tweak that a little too as the two halves required quite a bit of fettling to let the bearing spin freely but still hold it securely when glued together around it.
                        I think the key things that made the difference are keeping the filament path clear, stable and moving the hobb even without the idler. I don't think the idler spring is strong enough to do the job on its own if the filament enters or exits at a funny angle and wants to move away from the hobb.
                        Worth noting that I got the V1 magnetic assembly in my kit. I'd have to get my hands on the V2 (or get a good set of dimensions) to tweak the design for that.
                          Idodgeads
                          @lo-fi
                          You put a lot of thought and effort into this. I have the v2 assembly, I can't remember if the housings are compatible. I have a .3mm nozzle x I could use to get more resolution but i'm not sure that's necessary. What was your print settings for this? Did you go with solid infill? I would definitely like the stl if my v2 will work with this.
                            Idodgeads
                            Nope, guess I wasn't paying attention. v1 and v2 are too different. Would duet supply the drawing if we requested it?
                            • T3P3Tonyundefined
                              T3P3Tony administrators @Idodgeads
                              @idodgeads yes I have added a picture here:
                              https://docs.duet3d.com/en/Duet3D_hardware/Accessories/Rotating_Magnet_Filament_Monitor#hobbed-assembly
                              www.duet3d.com
                              • Phaedruxundefined Phaedrux referenced this topic
                              • Lo-Fiundefined
                                Lo-Fi
                                @t3p3tony that's brilliant, thanks for all the hard work on the new docs! Is there any way I can buy just the V2 hobbed assembly? I wouldn't mind trying it, just out of interest.
                                So just a 1mm difference in the placement of the top bearing and width of the hob. Not a problem. I've updated the models, @Idodgeads . I'm going to print to check before sending files over.
                                The 0.3mm nozzle might make a few details sharper, though I don't think anything critical either way. 0.1mm layer height will probably get better a result, but my 0.2 print seems to be doing OK.
                                T3P3Tonyundefined brotherchrisundefined 2 Replies Last reply Reply Quote 0
                                • T3P3Tonyundefined
                                  T3P3Tony administrators @Lo-Fi
                                  @lo-fi yes for the work you are doing on the housings, sure. drop a line to info@duet3d.com.
                                  Thanks should go mainly to @droftarts for the new docs!
                                  www.duet3d.com
                                    Idodgeads @T3P3Tony
                                    @t3p3tony
                                    Thanks for making this available. I just got two new build surfaces in this week so I'm ready
                                    to test print.
                                    • brotherchrisundefined
                                      brotherchris @Lo-Fi
                                      @lo-fi Super interested in trying your sensor housing when it's complete. I am having the same issues others appear to be having.
                                      Lo-Fiundefined 1 Reply Last reply Reply Quote 0
                                      • Lo-Fiundefined
                                        Lo-Fi @brotherchris
                                        @brotherchris I had two good test prints last night and have been in touch with T3P3Tony about getting a V2 rotating assembly, so hopefully won't be long and I can test out both variations.
                                        I'll throw you a heads-up when I'm happy with and have done a little testing myself 🙂
