    E0 starts heating when I power up my printer
    • Tim-C.
      Tim-C. last edited by Tim-C.
      Hello I got a Problem with my E0 heater. When I power up the printer the heater almost burn after a few seconds. It should be wired correctly. The only thing I did wrong was the fan connection. I connected them backwards. Can this lead to the heating error, or os this something else? Where can I sart searching?
      The Thermistor is showing room temp. btw when its powerd via USB.
      Best Regards Tim
      alankilian 1 Reply Last reply Reply Quote 0
      • alankilian
        alankilian @Tim-C. last edited by
        @tim-c
        • What board do you have?
        • What version of firmware are you using?
        • How is your heater connected? (Post photos of the wiring)
        • post your config.g
        • What hotend are you using?
        • What is your power-supply voltage?
        Tim-C. 1 Reply Last reply Reply Quote 1
        • Tim-C.
          Tim-C. @alankilian last edited by Tim-C.
          @alankilian At first thanks for youre reply. 🙂
          • Duet 2 Wifi V1.04
          • Firmware 3.3
          • Bondtech LGX - with copperhead, the heater is from the stock Sidewinder X1
          • Power-supply voltage = 240 V
          config: !
          ; Configuration file for Duet WiFi (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Mar 06 2022 15:28:51 GMT+0100 (Mitteleuropäische Normalzeit)
          M550 P"Siderwinder X1- V1" ; set printer name
          M92 X80.12 Y80.12 Z399.78 E400.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X800 Y800 Z800 E550 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X300 Y300 Z400 S0 ; set axis maxima
          M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
          M574 Z1 S2 ; configure Z-probe endstop for low end on Z
          G31 P500 X33 Y-47 Z2.5 ; set Z probe trigger value, offset and trigger height
          M557 X15:285 Y15:285 S67.5 ; define mesh grid
          M307 H0 R1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
          M106 P1 S1 H0 T45 ; set fan 1 value. Thermostatic control is turned on
            What happens if you remove the SD card and then power on the printer? Does the hotend heater still heat up? Check carefully. If it does, that would indicate that the E0 heater output mosfet has failed in the on position. Wiring a fan backwards may have caused some damage, but I'd be surprised if it caused this, unless there is some other issue as well.
            You can try using E1 heater output instead by moving the wiring and altering the config.g
            Tim-C. 1 Reply Last reply Reply Quote 0
            • Tim-C.
              Tim-C. @Phaedrux last edited by
              @phaedrux Thanks for youre reply the E1 heater works fine. I guess I damaged something on the way....
