    The Scara Road Runner
    My Duet controlled machine
    duet 2 wifi kinematics
    1.2k
    • 3DPotterundefined
      3DPotter
      https://www.youtube.com/watch?v=BnsA2Ix4CfQ
      Here is our teaser video for the Scara Road Runner. It will mainly be used for 3D printing cement with a 1in nozzle from a continuous flow system.
      It is using a Duet 2 WiFi, all motors are being run off the expansion pin slot.
      We will be printing with material soon, just a few more things to work out. The print area shape will be an elliptical oval that has straight edges on top and bottom of the oval from a top down view. It can do continuous 360 degree rotation.
      https://3dpotter.com/
      The only dedicated 3D ceramic printer using real clay.
      https://www.instagram.com/3dpotter/
      https://www.youtube.com/c/3dpotter/
      https://www.facebook.com/3dpotter/
      https://www.reddit.com/user/3D_Potterbot
      T3P3Tonyundefined 1 Reply Last reply Reply Quote 8
      • T3P3Tonyundefined
        T3P3Tony administrators @3DPotter
        @3dpotter Missed this when you posted it, Looking very cool!
        www.duet3d.com
        • 3DPotterundefined
          3DPotter
          Here it is in action!
          https://youtu.be/57DWYw5pkn4
          • 3DPotterundefined
            3DPotter
            It got bigger.
            https://youtube.com/shorts/kuDXX552dMU
            JoergS5undefined 1 Reply Last reply Reply Quote 5
            • JoergS5undefined
              JoergS5 @3DPotter
              @3dpotter looks great, like my next house by the lake 😉
              I am wondering which system you're using, from your homepage "Most clay printers use a pressurized system using compressed air, with a 3D Potterbot a high-pressure system is not needed." If it is not secret, you you tell me which technology are you using? Is it a peristaltic pump? If it's a tube, how do you refill?
              I'm asking because I think about building a 3D printer with stationary hotend and using recycled material as pellets instead of filament. I need an idea how to get a controlled flow of the melted material without a solid material on top, which pressures.
              • 00Hazeundefined
                00Haze
                The Sara Road Runner looks amazing! Well done!
                I have a question how did you set up the RepRapFirmware for the serial SCARA with the road runner style gantry? I have a serial scara 3d printer running it off a Duet 3 Mini 5+ the M669 code was quite simple to set up, but I would also like to add a road runner gantry as you have done, how do I manipulate the M669 code for a set up like this? Many thanks, Marc
                • o_lampeundefined
                  o_lampe @00Haze
                  @00Haze said in The Scara Road Runner:
                  You type "M669" in your DWC console. The answer will be the current kinematic matrix.
                  Now you have to add the linear axis of the roadrunner to it.
                  Example:
                  ; before
                  X1:0:0
                  ; adding axis U
                  X1:0:0:1
                  You have to keep the original X driver in the matrix, but you can set M92 X0 to take it out of the equation.
                  • 00Hazeundefined
                    00Haze
                    Thank you o_lampe. I will give that a whirl and report back!
