    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    25.1k
    • paolozampini1973undefined
      paolozampini1973 @droftarts
      @droftarts Listen to the 74hc I have to take it apart Because it gives me more problems it practically skips the steps at the entrance I have to give it three times and 8 and it doesn't skip my steps but if I give it 5 volts it skips my steps it practically gets worse
      I did as you told me but the axes move by themselves without command Both X and Y
        @droftarts I would like to leave V 011 but the Y x move without giving it the command so it is useless to talk about other problems there is to solve the first This is the problem Okay I'll wait when you get free I'll publish the config file thanks
        21/3/2022, 15:38:13 Error: short-to-ground reported by driver(s) 7 8
        Error: over temperature shutdown reported by driver(s) 7 8
        21/3/2022, 15:38:08 Error: short-to-ground reported by driver(s) 7 8
        21/3/2022, 15:38:04 Error: short-to-ground reported by driver(s) 7 8
        21/3/2022, 15:37:59 Error: short-to-ground reported by driver(s) 7 8
        21/3/2022, 15:37:55 Error: short-to-ground reported by driver(s) 7 8
        21/3/2022, 15:37:50 Error: short-to-ground reported by driver(s) 7 8
        21/3/2022, 15:37:49 M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
        Board ID: 0JD0M-9P6M2-NW4SN-6J1DD-3SJ6K-KAURK
        Used output buffers: 3 of 24 (20 max)
        Static ram: 23876
        Dynamic ram: 77448 of which 0 recycled
        Never used RAM 13092, free system stack 184 words
        Tasks: NETWORK(ready,10.4%,231) HEAT(delaying,0.1%,330) Move(notifyWait,0.1%,319) DUEX(notifyWait,0.0%,24) MAIN(running,86.5%,411) IDLE(ready,3.0%,29), total 100.0%
        Owned mutexes:
        Last reset 00:00:25 ago, cause: software
        Last software reset at 2022-03-21 15:37, reason: User, GCodes spinning, available RAM 13092, slot 1
        Error status: 0x00
        Aux0 errors 0,0,0
        Step timer max interval 0
        MCU temperature: min 29.3, current 30.0, max 30.3
        Supply voltage: min 25.6, current 25.7, max 25.8, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: position 0, standstill, SG min/max not available
        Driver 1: position 0, standstill, SG min/max not available
        Driver 2: position 0, standstill, SG min/max not available
        Driver 5: position 0, standstill, SG min/max not available
        Driver 6: position 0, standstill, SG min/max not available
        Driver 7: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
        Driver 8: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
        Driver 9: position 0, standstill, SG min/max not available
        Driver 10: position 0
        Driver 11: position 0
        Date/time: 2022-03-21 15:37:49
        Cache data hit count 981081507
        Slowest loop: 6.48ms; fastest: 0.19ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 1.0ms, write time 0.0ms, max retries 0
        === MainDDARing ===
        === AuxDDARing ===
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Filament sensors ===
        Extruder 0 sensor: no filament
        Extruder 1 sensor: ok
        Extruder 2 sensor: no filament
        Extruder 3 sensor: ok
        === DueX ===
        Read count 1, 2.36 reads/min
        === Network ===
        Slowest loop: 39.88ms; fastest: 0.00ms
        Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is active
          WiFi firmware version 1.26
          WiFi MAC address 40:f5:20:0d:6b:49
          WiFi Vcc 3.37, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 20888
          WiFi IP address 192.168.1.5
          WiFi signal strength -64dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
          Socket states: 0 4 0 0 0 0 0 0
          21/3/2022, 15:37:46 Error: short-to-ground reported by driver(s) 7 8
          21/3/2022, 15:37:41 Error: short-to-ground reported by driver(s) 7 8
          21/3/2022, 15:37:39 Connected to 192.168.1.5
          config (18).g
          droftarts administrators @paolozampini1973
          @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
          Is that in both DueX2 mode and DueX5 mode?
          paolozampini1973undefined 4 Replies Last reply Reply Quote 0
            @droftarts As you can see the errors alone are only when AND IN DUEX MODE 5 DRIVER 7+ DRIVER 8 ARE OFF IN DUEX 2 MODE IT DOESN'T GIVE SHORT-CIRCUIT ERRORS SO IT IS NOT NORMAL IN MY MEETING
              @droftarts No in DUEX2 MODE they do not move by themselves they move only with the command IN DUEX5 MODE THE MOVEMENT HAS BEEN ALONE WITHOUT COMMAND
              tekkydaveundefined 1 Reply Last reply Reply Quote 0
                @droftarts from my experience it tells me that this expansion has problems but I think they are more software problems and not hardware problems Tell me what you think
                Also because I'm sorry if I always repeat the same thing but I find myself with so many problems that I did not have Maybe some of these problems are not aware I will tell you more I tried to disconnect everything on the problem outputs it gives the same so on all the drivers I am disconnected disconnected nothing is connected and it still gives problems in duex 5 mode
                • tekkydaveundefined
                  tekkydave @paolozampini1973
                  @paolozampini1973 You need to run the Duex in Duex2 mode. In this way it will disable the internal drivers on 7,8,9 allowing you to have external drivers on 7 & 8 for your X & Y axes.
                  If you have it in Duex5 mode BOTH the internal and external drivers are connected which is causing the movement without commands.
                  ~ tekkydave ~
                  D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
                  FreeCAD, PrusaSlicer
                  paolozampini1973undefined 1 Reply Last reply Reply Quote 0
                    @droftarts Listen to me when I say something and before I say something I think about it I don't talk to Ugh the problem now that I still have to solve the problem But you have to understand you are a hardware problem or a software problem as I said before for me it is a software problem and obviously before I had a small problem now I have big problems so what I ask you and please please please at least try to understand if it is a hardware problem or a software problem because otherwise I am forced to upgrade to version 0.8
                    unless I could print with some pitch loss problem but at least I could print now I have practically the printer stopped
                      paolozampini1973 @tekkydave
                      @tekkydave Excuse me but if I do as you say or three motors that I cannot use then I still have a big problem So what is the advantage of having bought the 011 version because I have these problems that I have with the 011 I did not have them so explain to me you this solution that you recommend me maybe I don't understand Thanks very kind
                        @paolozampini1973 @droftarts has already given the solution:
                        Move the Z2 axis from output 9 on the Duex to either 0 or 2 on the Duet.
                        Put the Duex in Duex2 mode.
                        Make the changes to config.g that he will be giving to you.
                        Once that is done lets see what remaining problems there are.
                        ~ tekkydave ~
                        paolozampini1973undefined 1 Reply Last reply Reply Quote 1
                          @tekkydave my printer configuration:
                          Z is configured with two INDEPENDENT motors FOR SELF-LEVELING one on Driver 1 = Z one on the driver 9 = Z then X = DRIVER 7 EXSTERNAL DM860H Y = DRIVER 8 EXSTERNAL DM860H then I have 4 driver instructors 3 TMC2660 + driver 4 TMC2660 + driver 5 TMC2660 + driver 6 TMC2660
                          PROBLEMS WITH DUEX5 V0.11 IN DUEX5 OFF DRIVE MODE 7 AXIS X + DRIVER 8 AXIS Y WHY I NEED TO USE IT
                          are engaged or four independent extruders in total there are 8 motors Now I am sending you how I configured the printer and This is how it must be then the solution of You tell me how I can do it if I have 8 motors
                            @paolozampini1973
                            I'll do it by means of a table:
                            Driver      Axis
                            0           unused
                            1           Z1
                            2           Z2
                            3           E1
                            4           E2
                            5           E3
                            6           E4
                            7           X (external)
                            8           Y (external)
                            9           unused (external)
                            This is all 8 motors. The Duex is in Duex2 mode.
                            ~ tekkydave ~
                            paolozampini1973undefined 2 Replies Last reply Reply Quote 1
                              @tekkydave DRIVER 5 + DRIVER 6 in DUEX mode 2 they do not work they are disabled understood This is a test that I have already done they do not work only 7 8 and 9 works I think you don't know this thing you've never tried But they don't work
                                @tekkydave I repeat then this is not a solution this is to turn the problem because as I repeat with the 0.8 these problems I did not have the 0.11 HAS problems Then honestly buying a version that should solve some problems but instead you create other problems this is not normal what I mean understood I Thanks for your kind attention Thank you but in this way you do not solve the problem it turns it creating even more problems
                                  Correct - I haven't tried it. I only have a duex2 in my printer as I only have one extruder and 3 Z motors plus X & Y. I am simply repeating the information that others have already given days ago. Good luck solving your issues. Now I am convinced this thread is a Turing Test 🙂
                                  ~ tekkydave ~
                                    @tekkydave Please Unfortunately, this version has problems that in the design phase it can happen that one does not notice it But in fact I now take down the 0:11 you were Monterò from 08 However I do not recommend to buy the 011 Until proven otherwise it is that I now have 6 problems including 4 are very serious
                                      paolozampini1973 @paolozampini1973
                                      @dc42 my printer configuration:
                                      1. HOW DO POWER SUPPLY X + Y GO WITHOUT ANY DATA COMMAND
                                      2. HIGH TEMPERATURE M906 I TRIED TO PUT ALL AXES AT 0 MHA THE PROBLEM PERSISTS CONTINUOUSLY THE TEMPERATURE DRIVE TMC2660 AND 24 ° DEGREES
                                      3. I ALWAYS HAVE THE SAME STEP LOSS PROBLEM AS DUEX 5 V0.8
                                      4. THERMOCOUPLES REPORT 18 DEGREES LESS
                                        5)and then I have the problem that in two ex 5 it gives Short Circuit error only in DUEX 5 mode
                                        Vorrei lasciare V 011 ma la Y x si muove senza dargli il comando quindi è inutile parlare di altri problemi c'è da risolvere il primo Questo è il problema Va bene aspetterò quando ti libererai lo farò pubblica il file di configurazione grazie
                                      21/3/2022, 15:38:13 Errore: cortocircuito verso terra segnalato dai conducenti 7 8
                                      Errore: spegnimento per sovratemperatura segnalato dai conducenti 7 8
                                      21/3/2022, 15:38:08 Errore: cortocircuito verso terra segnalato dai conducenti 7 8
                                      21/3/2022, 15:38:04 Errore: cortocircuito verso terra segnalato dal conducente( s) 7 8
                                      21/3/2022, 15:37:59 Errore: cortocircuito verso terra segnalato dai conducenti 7 8
                                      Errore: spegnimento per sovratemperatura segnalato da driver(i) 7 8
                                      21/3/2022, 15:37:55 Errore: cortocircuito verso terra segnalato dal conducente(i) 7 8
                                      Errore: spegnimento per sovratemperatura segnalato dal conducente(i) 7 8
                                      21/3/2022 , 15:37:50 Errore: cortocircuito verso terra segnalato dai conducenti 7 8
                                      Errore: spegnimento per sovratemperatura segnalato dai driver 7 8
                                      === Diagnostica ===
                                      RepRapFirmware per Duet 2 WiFi/Ethernet versione 3.3 (2021-06-15 21:44 :54) in esecuzione su Duet WiFi 1.02 o successivo +
                                      ID scheda DueX5: 0JD0M-9P6M2-NW4SN-6J1DD-3SJ6K-KAURK
                                      Buffer di uscita utilizzati: 3 di 24 (20 max)
                                      Ram statico: 23876
                                      Ram dinamico : 77448 di cui 0 riciclato
                                      Mai usato RAM 13092, stack di sistema libero 184 parole
                                      Attività: NETWORK(ready,10.4%,231) HEAT(delaying,0.1%,330) Move(notifyWait,0.1%,319) DUEX(notifyWait,0.0 %,24) MAIN(in esecuzione,86.5%,411) IDLE(ready,3.0%,29), totale 100.0%
                                      Mutex di proprietà:
                                      === Piattaforma ===
                                      Ultimo ripristino 00:00:25 fa, causa: software
                                      Ultimo ripristino del software alle 15:37 del 21-03-2022, motivo: utente, rotazione di GCodes, RAM disponibile 13092, slot 1
                                      Codice di ripristino del software 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/MAIN status Freestk:
                                      Error 0x00
                                      Errori Aux0 0,0,0
                                      Intervallo max timer passo 0
                                      Temperatura MCU: min 29.3, corrente 30.0, max 30.3
                                      Tensione di alimentazione: min 25.6, corrente 25.7, max 25.8, eventi di sottotensione: 0, eventi di sovratensione: 0, alimentazione buona : si
                                      Heap OK, gestisce allocata/usata 0/0, memoria heap allocata/usata/riciclabile 0/0/0, cicli gc 0
                                      Driver 0: posizione 0, fermo, SG min/max non disponibile
                                      Driver 1: posizione 0, fermo , SG min/max non disponibile
                                      Pilota 2: posizione 0, fermo, SG min/max non disponibile
                                      Pilota 3: posizione 0, fermo, SG min/max non disponibile
                                      Pilota 4: posizione 0, fermo, SG min/max non disponibile
                                      Pilota 5: posizione 0, fermo, SG min/max non disponibile
                                      Driver 6: posizione 0, fermo, SG min/max non disponibile
                                      Driver 7: posizione 0, spegnimento temperatura! corto a terra, fermo, SG min/max non disponibile
                                      Driver 8: posizione 0, spegnimento della temperatura! da corto a terra, fermo, SG min/max non disponibile
                                      Pilota 9: posizione 0, fermo, SG min/max non disponibile
                                      Pilota 10: posizione 0
                                      Pilota 11: posizione 0
                                      Data/ora: 21-03-2022 15:37 :49
                                      Conteggio hit dati cache 981081507
                                      Ciclo più lento: 6,48 ms; più veloce: 0,19 ms Errori
                                      I2C nak 0, timeout di invio 0, timeout di ricezione 0, finishTimeouts 0, reset 0
                                      === Archiviazione ===
                                      Voci file libere: 10
                                      SD card 0 rilevate, velocità interfaccia: 20,0 MBytes/sec
                                      SD card letta più lunga tempo 1,0 ms, tempo di scrittura 0,0 ms, numero massimo di tentativi 0
                                      === Sposta ===
                                      DM creati 83, maxWait 0 ms, compensazione letto in uso: nessuno, offset comp 0,000
                                      === MainDDARing === Movimenti
                                      pianificati 0, movimenti completati 0 , singhiozzo 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], stato CDDA -1
                                      === AuxDDARing === Mosse
                                      pianificate 0, mosse completate 0, singhiozzo 0, stepErrors 0, LaErrors 0, Underruns [0 , 0, 0], stato CDDA -1
                                      === Calore ===
                                      Riscaldatori letto = 0 -1 -1 -1, riscaldatori a camera = -1 -1 -1 -1
                                      Riscaldatore 1 acceso, I-accum = 0.0
                                      Segmenti rimasti: 0
                                      Blocco movimento mantenuto da null
                                      HTTP è inattivo in stato(i) 0
                                      Telnet è inattivo in stato(i) 0
                                      Il file è inattivo in stato(i) 0
                                      USB è inattivo in stato(i) 0
                                      Aux è inattivo in stato(i) 0
                                      Trigger è inattivo in stato(i) 0
                                      La coda è inattiva nello stato(i) 0 Il
                                      display LCD è inattivo nello stato(i) 0
                                      Daemon è inattivo nello stato(i) 0
                                      La pausa automatica è inattiva nello stato(i) 0 La
                                      coda del codice è vuota.
                                      === Sensori filamento ===
                                      Sensore estrusore 0: nessun filamento
                                      Sensore estrusore 1: ok
                                      Sensore estrusore 2: nessun filamento
                                      Sensore estrusore 3: ok
                                      === DueX ===
                                      Conteggio letture 1, 2,36 letture/min
                                      === Rete ===
                                      Ciclo più lento: 39,88 ms; più veloce: 0,00 ms
                                      Stati del risponditore: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessioni Sessioni
                                      HTTP: 1 di 8
                                      WiFi -
                                      Lo stato della rete è attivo
                                      Il modulo WiFi è connesso al punto di accesso
                                      Messaggi di errore: in sospeso 0, non pronto 0, noresp 0
                                      Versione firmware WiFi 1.26
                                      Indirizzo MAC WiFi 40:f5:20:0d:6b:49
                                      WiFi Vcc 3.37, motivo ripristino Attivato per processore principale
                                      Dimensioni flash Wi-Fi 4194304, heap libero 20888
                                      Indirizzo IP Wi-Fi 192.168.1.5
                                      Potenza segnale Wi-Fi -64dBm, modalità 802.11n, riconnessioni 0, modalità sospensione modem
                                      Registro orologio 00002002
                                      Stati socket: 0 4 0 0 0 0 0 0
                                      21/3 /2022, 15:37:46 Errore: cortocircuito verso terra segnalato dai conducenti 7 8
                                      21/3/2022, 15:37:41 Errore: cortocircuito -a terra segnalato dal/dai conducente/i 7 8
                                      21/3/2022, 15:37:39 Connesso a 192.168.1.5config (18).g
                                        @dc42 I would like to know why you cannot pay attention to my problem it is a curiosity Thanks At least after one I will disturb more I have written to you many times
                                          @dc42 she lets me think about this by not answering I have a problem that technically in my experience is very serious in my opinion and she is aware of it
                                            @dc42 I want to thank you for all the attention you gave me even if you didn't even spend 10 seconds on more important things.
