    Max current on Duet 2 expansion header
    • chimaeragh
      chimaeragh last edited by
      What is the maximum current draw on the Duet 2 3.3v and 5v expansion header pins?
      Duet 2 Wifi, Ooznest Workbee CNC 1510
      droftarts infiniteloop 2 Replies Last reply Reply Quote 0
      • droftarts
        droftarts administrators @chimaeragh last edited by
        @chimaeragh See https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#operating-limits
        5V current limit: 2.0A total on 5V and 3.3v, including the internal current consumption (around 200-300mA), any PanelDue or other display, and any endstops/Z probes that draw significant power.
        • infiniteloop
          infiniteloop @chimaeragh last edited by
          @chimaeragh The expansion header pins are unbuffered, so you should not draw more than 10-20 mA from each.
          • droftarts
            droftarts administrators @infiniteloop last edited by
            @infiniteloop That's true for the I/O pins, but the 3.3V and 5V pins on the expansion header are direct to the voltage regulators. So it's the current the voltage regulators can support, once the draw of the rest of the system has been taken into account.
            infiniteloop chimaeragh 2 Replies Last reply Reply Quote 0
            • infiniteloop
              infiniteloop @droftarts last edited by
              @droftarts Thanks for clarification 👆
              • chimaeragh
                chimaeragh @droftarts last edited by
                @droftarts @infiniteloop Thanks for your help
