    1LC no CAN connection, no hard reset
    • apak
      apak last edited by apak
      Have a brand new Duet3 mini + 1LC
      CAN wired as docs instructed, no CAN communication at all....
      RepRapFirmware for Duet 3 Mini 5+ version 3.4.0 (2022-03-15 18:59:15) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: TU6AL-G296U-D65J0-40KML-2413Z-H5XZS
      Used output buffers: 3 of 40 (40 max)
      Static ram: 103684
      Dynamic ram: 110868 of which 0 recycled
      Never used RAM 24304, free system stack 196 words
      Tasks: NETWORK(ready,13.6%,249) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,351) TMC(delaying,0.7%,114) MAIN(running,84.8%,428) IDLE(ready,0.1%,29) AIN(delaying,0.8%,273), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:00:43 ago, cause: power up
      Last software reset at 2022-03-20 02:02, reason: User, GCodes spinning, available RAM 24304, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x04
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 44456, completed 44456, timed out 0, errs 0
      Step timer max interval 1399
      MCU temperature: min 27.6, current 27.9, max 28.3
      Supply voltage: min 24.5, current 24.6, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/18, heap memory allocated/used/recyclable 2048/220/52, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 276, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 277, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 277, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 277, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 276, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: not present
      Driver 6: not present
      Date/time: 2022-03-20 02:43:35
      Cache data hit count 53501027
      Slowest loop: 3.73ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 3.1ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is doing "G4 S10 " in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 48, received 0, lost 0, boc 86
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 27/0/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 200.66ms; fastest: 0.06ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      Failed messages: pending 0, notready 0, noresp 1
      WiFi firmware version 1.26
      WiFi MAC address f0:08:d1:03:80:d0
      WiFi Vcc 3.36, reset reason Power up
      WiFi flash size 2097152, free heap 24544
      WiFi IP address 192.168.0.51
      WiFi signal strength -40dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      Checked with two diffirent boards of each, I have 2 mini and 2 1LC boards, always status led flashing on red....
      Checked with new set of wires also
      Can´t figure it out, to set it working.
      Powered up with 2 buttons pressed, but no change. No comm, can´t upload fw either
      • Barracuda72
        Barracuda72 last edited by
        dont know if its solve your problem but you have the 120 Ohm terminating Resisitor twice. Once you have the extra Resistor on the CAN Plug ( only used with 1.1 Boards without distribution boards) and then you closed the Solder brigde on the Board( 1.2 boards and later. Remove the Cable resistorand leave the cables open. At least your CAN should connect then.
        apak 1 Reply Last reply Reply Quote 0
        • apak
          apak @Barracuda72 last edited by apak
          @barracuda72 there is no resistor, only the cables solderded.
          Just cutted wired and it worked, thanks
