    PanelDueFirmware file naming + splash screen
    PanelDue
    • floblerundefined
      flobler
      @mfs12 while trying to upgrade from PanelDueFirmware 3.3.0 to 3.4.0 we saw that the file naming has changed and it is not immediately clear which version should now be used for adding a custom splash screen. As far as I can see there is no nologo version anymore but the readme is still referencing it.
      Could you kindly confirm which file should be used?
      We are trying to automate our releases by pulling the correct file from your release and then adding our custom splash screen automatically which would benefit from consistent file naming. Are you expecting this to stay the same going forward?
      Thank you very much!
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @flobler
        @flobler The file with "logo" has a logo, and the file without it is the one you can add a logo to. It's never mentioned that they changed the naming. They need to update the doc site.
        floblerundefined 1 Reply Last reply Reply Quote 1
        • floblerundefined
          flobler @Stephen6309
          @stephen6309 Thank you, I appreciate that!
          • mfs12undefined
            mfs12
            @flobler it's as @Stephen6309 says.
            paneldue.bin - bare firmware
            paneldue-logo.bin - firmware + splash screen
            I thought this makes more sense as a list of things which are not can get quite extensive 😉
            @Stephen6309 can you point to the documentation inconsistency?
            Visit me on github at https://github.com/mfs12/
            • mfs12undefined mfs12 marked this topic as a question
            • mfs12undefined mfs12 has marked this topic as solved
            • mfs12undefined
              mfs12
              @Stephen6309 I updated the readme.md file in the project.
              jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                jay_s_uk @mfs12
                @mfs12 it needs updating on the docs site too
