    Heater 1 fault: monitor 0 was triggered
    Using Duet Controllers
    511
    • General_kaosundefined
      General_kaos
      I decided to treat my Railcore to an upgrade, and installed both a Toolboard 1.2 & Hemera Revo upgrade kit at the weekend. All seemed to go well, but I seem to have misconfigured something.
      No problem PID tuning the hotend, with a normal looking graph:
      PID Graph
      But the moment I tell it to heat it throws this error. I have tried re-tuning a few times, but I can't seem to get rid of it.
      I'd appreciate it if anyone can point out where I've gone wrong!
      Thanks,
      Kaos
      config.g:
      ; Configuration file for My Printer
      ; Communication and general
      M550 P"Duet 3"								; Machine name and Netbios name (can be anything you like)
      ;M551 XXXXX                      			; Machine password (used for FTP)
      G21                                 		; Work in millimetres
      G90                                			; Send absolute coordinates...
      M83                                 		; ...but relative extruder moves
      ; Axis and motor configuration
      M669 K1										;set CoreXY mode
      G4 S2 										; wait for expansion boards to start
      M584 X0 Y1 Z2:3:4 E121.0					; Map Z to drivers 2, 3, 4. X to 0, Y to 1 & E to expansion CAN 121.0
      M569 P0 S0                                 ; (X) physical drive 0 goes backwards
      M569 P1 S1                                 ; (Y) physical drive 1 goes forwards
      M569 P2 S1                                 ; (Z1) physical drive 2 goes forwards Front left
      M569 P3 S0                                 ; (Z2) physical drive 3 goes backwards Back left
      M569 P4 S0                                 ; (Z3) physical drive 4 goes backwards Right
      M569 P121.0 S0                             ; (E0) physical drive (on tool board) 5 goes backwards
      ;Leadscrew locations
      M671 X-60:-60:330  Y35:270:170 S7.5  		;Front left, Rear Left, Right  S7.5 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrew
      M350 X16 Y16 Z16 E16 I1	    				; set 16x microstepping for axes& extruder, with interpolation
      M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
      M92 X200.00 Y200.00 Z1600.00 E409.00         ; set steps per mm
      M566 X950.00 Y950.00 Z66.00 E1000.00         ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z540.00 E3600.00    ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z66.00 E1500.00       ; set accelerations (mm/s^2)
      M906 X1100 Y1100 Z1000 E900 I30              ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                      ; Set idle timeout
      M208 X0 Y0 Z0 S1                            ; set axis minima
      M208 X290 Y280 Z330 S0                      ; set axis maxima
      M574 X1 S1 P"io2.in"                       ; configure active-high endstop for low end on X via pin io2.in
      ;M574 Y1 S1 P"io1.in"                        ; configure active-high endstop for low end on Y via pin io1.in CHANGE TO TOOL BOARD!
      M574 Y1 S1 P"121.io1.in"					;configure active-high endstop for low end on X via pin io1.in on tool board B121
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" Q10 T0                       ; create bed heater output on out0 and map it to sensor 0 - added pwm frequency for bed 06032022
      M307 H0 B0 S1.00                             ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                      ; map heated bed to heater 0
      M143 H0 S115                                 ; set temperature limit for heater 0 to 115C
      ;M308 S1 P"spi.cs0" Y"rtd-max31865"           ; configure sensor 1 as (incorrect, but appears assigned tocorrect type)thermocouple via CS pin spi.cs0
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 ;T100000 B4138 ;thermistor on tool board
      M950 H1 C"121.out0" T1                           ; create nozzle heater output on toolboard and map it to sensor 1
      M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
      ;M307 H1 A366.5 C148.7 D3.2 S1.0 V24.0 B0			; values from PID tune 100% 24/10/2020 -needs repearing now new revo heater on toolboard 19mar22
      ;M307 H0 A357.2 C715.6 D15.6 V24.0 B0			; values from PID tune 70% fan 2/7/2020
       M307 H0 R0.350 K0.158:0.000 D31.25 E1.35 S1.00 B0 ;values from PID tune 21Mar22
      ;M307 H1 R4.923 K0.549:0.924 D1.22 E1.35 S1.00 B0 V23.8	;new PID tune 19Mar22, revo heater on toolboard
      ;M307 H1 R4.869 K0.552:0.850 D1.23 E1.35 S1.00 B0 V23.8 ;repeated 19mar22
      ;M307 H1 R4.863 K0.559:0.949 D1.15 E1.35 S1.00 B0 V23.8 ;repeated 0.5mm from tool 19mar22
       M307 H1 R4.800 K0.546:0.000 D1.38 E1.35 S1.00 B0 V23.8 ;repeated 21mar22
      M570 S360				; Hot end may be a little slow to heat up so allow it 180 seconds
      M570 H1 P4 T15 			; An anomaly on heater 1 must persist for 4 seconds, and must be greater or less than 15C from the setpoint, to raise a heater fault (added to try and stop faults 19mar22)
      M143 H1 S300									Set temp limit for heater 1
      ;electronics temperatures
      M308 S3 Y"drivers" A"DRIVERS"  ; configure sensor 3 as temperature warning and overheat flags on the TMC2660 on Duet
      M308 S4 Y"mcu-temp" A"MCU" ; configure sensor 4 as thermistor on pin e1temp for left stepper
      M950 F0 C"121.out2" Q500                     ; create fan 0 on pin out2 on toolboard and set its frequency
      M106 P0 S1 H1 T45                            ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"121.out1"		                     ; create fan 1 on pin out1 on toolboard (blower)
      M106 P1 S0 H-1                               ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"out6"                         	 ; create fan 2 on pin out6
      M106 P2 S0.3 H3:4 L0.15 X1 B0.3 T30	         ; set fan 2 value. link to MCU/Drivers temps
      M563 P0 D0 H1 F1                             ; define tool 0
      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      ;M591 D0 P3 C"io3.in" S1 R30:130 L24.66 E4.0 		; Duet3D rotating magnet sensor for extruder drive 0 is connected to io3.in, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length
      ;M591 D0 S0											;disable filament monitor - doesn't work properly with SBC :-(
      m591 D0 P2 C"121.io2.in" S1 					;simple trianglelabs filament sensor on toolboard IO2
      M950 S0 C"121.io0.out"                          ; create servo pin 0 for BLTouch
      M558 P9 C"121.io0.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds removed ^ from io7.in
      G31 P500 X45 Y-40 Z1.40               		; set Z probe trigger value, offset and trigger height (increase z number to move nozzle closer to bed)
      ;M557 X50:243 Y50:230 S20                   ; define mesh grid - removed to see if cause
      ;mcu temp offset
      M912 P0 S-2.7								; 2.7C offset from PT100 at RT 4/7/2020
      M572 D0 S0.020								;set pressure advance
      T0					; select first hot end
      M568 A0				;set tool heater to off (added 19Mar22 to try and stop faults)
        What firmware did you update to?
        Can you share the results of sending M122 and M122 B121 and M98 P"config.g"?
        Did you use M500 to save the tuned results?
        General_kaosundefined 2 Replies Last reply Reply Quote 0
          General_kaos @Phaedrux
          @phaedrux
          Thanks for the reply.
          Running 3.4 on both the Duet 3 & Toolboard.
          I copied the results to config.g as opposed to saving with M500
          m122
          RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (SBC mode)
          Board ID: 08DJM-956L2-G43S8-6J1FL-3S46L-1S2AD
          Used output buffers: 1 of 40 (12 max)
          Static ram: 151000
          Dynamic ram: 65900 of which 292 recycled
          Never used RAM 133480, free system stack 200 words
          Tasks: SBC(ready,0.5%,467) HEAT(notifyWait,0.0%,149) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.8%,92) MAIN(running,91.6%,923) IDLE(ready,0.0%,30), total 100.0%
          Owned mutexes: HTTP(MAIN)
          Last reset 01:11:04 ago, cause: software
          Last software reset at 2022-03-21 20:46, reason: User, GCodes spinning, available RAM 133480, slot 2
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
          Error status: 0x00
          Step timer max interval 134
          MCU temperature: min 28.8, current 29.1, max 32.5
          Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 11.9, current 12.0, max 12.1, under voltage events: 0
          Events: 2 queued, 2 completed
          Driver 0: standstill, SG min 0, mspos 904, reads 20206, writes 15 timeouts 0
          Driver 1: standstill, SG min 0, mspos 680, reads 20207, writes 15 timeouts 0
          Driver 2: standstill, SG min 0, mspos 872, reads 20207, writes 15 timeouts 0
          Driver 3: standstill, SG min 0, mspos 536, reads 20207, writes 15 timeouts 0
          Driver 4: standstill, SG min 0, mspos 872, reads 20207, writes 15 timeouts 0
          Driver 5: standstill, SG min 0, mspos 8, reads 20211, writes 11 timeouts 0
          Date/time: 2022-03-21 21:57:25
          Slowest loop: 28.01ms; fastest: 0.03ms
          === Storage ===
          Free file entries: 10
          DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Segments left: 0
          Movement lock held by null
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === Filament sensors ===
          Extruder 0 sensor: ok
          === CAN ===
          Messages queued 38394, received 87404, lost 0, boc 0
          Longest wait 3ms for reply type 6053, peak Tx sync delay 277, free buffers 49 (min 48), ts 21323/21322/0
          Tx timeouts 0,0,0,0,0,0
          === SBC interface ===
          Transfer state: 4, failed transfers: 0, checksum errors: 0
          RX/TX seq numbers: 35829/35829
          SPI underruns 0, overruns 0
          State: 5, disconnects: 0, timeouts: 0, IAP RAM available 0x2b880
          Buffer RX/TX: 0/0-0, open files: 0
          === Duet Control Server ===
          Duet Control Server v3.4.0
          Code buffer space: 4096
          Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
          Full transfers per second: 39.16, max time between full transfers: 65.1ms, max pin wait times: 39.6ms/9.7ms
          Codes per second: 0.02
          Maximum length of RX/TX data transfers: 2988/584
          M122 b121
          Diagnostics for board 121:
          Duet TOOL1LC rev 1.1 or later firmware version 3.4.0 (2022-03-15 09:00:04)
          Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
          All averaging filters OK
          Never used RAM 2556, free system stack 88 words
          Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,61) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.0%,57) MAIN(running,91.9%,351) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0%
          Last reset 01:11:44 ago, cause: software
          Last software reset data not available
          Driver 0: pos 0, 409.0 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 42, reads 55071, writes 12, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x01, steps req 0 done 0
          Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
          Peak sync jitter 4/9, peak Rx sync delay 214, resyncs 0/0, no step interrupt scheduled
          VIN voltage: min 23.7, current 24.1, max 24.1
          MCU temperature: min 36.6C, current 39.0C, max 44.1C
          Last sensors broadcast 0x00000002 found 1 18 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 88247, send timeouts 0, received 38761, lost 0, free buffers 37, min 37, error reg 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
          Accelerometer: LIS3DH, status: 00
          I2C bus errors 0, naks 3, other errors 0
          Interrupt 5726621 to 0us, poll 4 to 1236us
          Driver 0: ok
            @phaedrux said in Heater 1 fault: monitor 0 was triggered:
            M98 P"config.g
            M98
            Imgur
              Error: unterminated string
              That would seem to indicate that you're missing a quote mark somewhere in your config.g which may be causing chaos.
                I can't spot it, maybe you see it?
                but your config is a bit messy. I suggest you make a backup of it, and then create a fresh config using the online tool and manually adjust it to match your config leaving it as organized and clean as possible. Then let's see if we can be rid of the string error.
                https://configtool.reprapfirmware.org/Start
                Even just having a basic config for testing here would be helpful even if it didn't get updated completely for your setup.
                General_kaosundefined 1 Reply Last reply Reply Quote 0
                  @phaedrux Thanks for the pointer - I'll try that tomorrow and see if it fixes it (& let you know).
                  I can't see a missing ", but not easy to spot!
                    Phaedrux Moderator @General_kaos
                    @general_kaos said in Heater 1 fault: monitor 0 was triggered:
                    It could also be a case of a bad character. Or a command that was expecting a quoted string and not getting it.
                    That makes me think that perhaps your PID values aren't actually getting executed.
                      @phaedrux I realise it's probably just because I mistyped the command first time! Missing " in the console entry of M98 - the repeat above is green.
                        @phaedrux It actually faults the moment I activate the heater - you can see here it isn't even being told to heat up.
                        Imgur
                        • deckingmanundefined
                          deckingman @General_kaos
                          @general_kaos There are a bunch of M307 commands in your config.g. Most are commented out with a semicolon except the last one which I assume is the active one. However, while it does not have the semicolon, it is indented. So I'm wondering if it's the indentation that is causing the problem? Or perhaps there is a hidden character showing as an indent?
                          General_kaosundefined 1 Reply Last reply Reply Quote 1
                            Ah yes, of course, now it's obvious.
                            Can you send M307 H0 and M307 H1 and compare the results it shows to what you have entered in your config.g to confirm they are actually being applied?
                            My recommendation to start with a clean config still stands.
                              General_kaos @deckingman
                              @deckingman Thanks Ian - I tried that, but removing the indent did not fix it. New Config G does though.
                                @phaedrux
                                M307 showed the values being loaded:
                                22/03/2022, 17:48:35: M307 h0: Heater 0: heating rate 0.350, cooling rate 0.158, dead time 31.25, max PWM 1.00, mode PID
                                Predicted max temperature rise 180°C
                                PID parameters: heating P16.3 I0.110 D357.0, steady P16.3 I0.211 D357.0
                                22/03/2022, 17:48:38: M307 h1: Heater 1: heating rate 4.800, cooling rate 0.546, dead time 1.38, max PWM 1.00, mode PID, calibrated at 23.8V
                                Predicted max temperature rise 500°C
                                PID parameters: heating P26.9 I1.612 D26.0, steady P26.9 I4.921 D26.0
                                So onto a new config via the configurator, which worked and still works after copying across all the specific settings for my printer.
                                I am at a loss what was wrong, but it seems to work now. Thanks for your help.
                                ; Configuration file for Duet 3 (firmware version 3.3)
                                ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Mar 22 2022 17:23:42 GMT+0000 (Greenwich Mean Time)
                                G90                                              ; send absolute coordinates...
                                M550 P"Duet 3"                                   ; set printer name
                                M669 K1                                          ; select CoreXY mode
                                M569 P0.0 S0                                     ; physical drive 0.0 goes backwards
                                M569 P0.1 S1                                     ; physical drive 0.1 goes forwards
                                M569 P0.2 S1                                     ; physical drive 0.2 goes forwards
                                M569 P0.3 S0                                     ; physical drive 0.3 goes backwards
                                M569 P0.4 S0                                     ; physical drive 0.4 goes backwards
                                M569 P121.0 S0                                   ; physical drive 121.0 goes backwards
                                M584 X0.0 Y0.1 Z0.2:0.3:0.4 E121.0               ; set drive mapping
                                M92 X200.00 Y200.00 Z1600.00 E397.00             ; set steps per mm
                                M574 X1 S1 P"io2.in"                             ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io2.in
                                M574 Y1 S1 P"121.io1.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin 121.io1.in
                                ;M574 Z1 S2                                       ; configure Z-probe endstop for low end on Z
                                M558 P9 C"121.io0.in" H10 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
                                G31 P500 X45 Y-40 Z1.4                           ; set Z probe trigger value, offset and trigger height
                                M557 X50:250 Y50:250 S20                         ; define mesh grid
                                M950 H0 C"out0" T0                               ; create bed heater output on out0 and map it to sensor 0
                                M307 H0 R0.350 K0.158:0.000 D31.25 E1.35 S1.00 B0 ;PID tune bed heater 21mar22
                                M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 ;e3D thermistor settings
                                M950 H1 C"121.out0" T1                           ; create nozzle heater output on 121.out0 and map it to sensor 1
                                M143 H1 S300                                     ; set temperature limit for heater 1 to 300C
                                M307 H1 R4.880 K0.553:0.843 D1.23 E1.35 S1.00 B0 V23.8 ;PID tune w/ e£D thermistor set 23Mar22
                                M950 F0 C"121.out2" Q500                         ; create fan 0 on pin 121.out2 and set its frequency
                                M106 P0 S0 H1 T45                                ; set fan 0 value. Thermostatic control is turned on
                                M950 F1 C"121.out1"                              ; create fan 1 on pin 121.out1 and set its frequency
                                M106 P1 S1 H-1                                   ; set fan 1 value. Thermostatic control is turned off
                                M950 F2 C"out6" Q500                             ; create fan 2 on pin out6 and set its frequency
                                ;M106 P2 S0.25 H1 T30                             ; set fan 2 value. Thermostatic control is turned on
                                M106 P2 S0.3 H3:4 L0.15 X1 B0.3 T30				 ;electronics fan linked to MCU/drivers
                                ;filament sensor
                                M591 D0 P2 C"121.io2.in" S1 					 ;simple trianglelabs filament sensor on toolboard IO2
                                T0                                               ; select first tool
                                • General_kaosundefined General_kaos has marked this topic as solved
