    BLTouch issue Duet 3 Mini
    Using Duet Controllers
    475
    • asimitabiundefined
      asimitabi
      I have a problem with my BLTouch sensor.
      I have wired the sensor as follows on the i02-PIN:
      +5V - Red
      OUT - Orange
      GND - Black
      IN - White 3.3V - NONE
      (Brown cable is not connected at this moment)
      I have entered the following in the config.g file:
      M950 S0 C "io2.out"
      M558 P9 C "io2.in" H5 F240 T10800 A5
      G31 P25 X-28.00 Y-13.00 Z0.90
      My homez.g looks like this:
      ; BLTouch
      M280 P0 S160
      M280 P0 S90
      G91
      G1 H2 Z5 F6000
      G90
      G1 X250 Y250 F10000
      G30
      ; lift Z after probing
      G91
      G1 Z20 F100
      G90
      When I run Home Z, there is no error message and the bed moves towards the sensor, but the PIN does not move out.
      When sending M280 signals for Deployprobe or retractprobe nothing happens.
      When starting the printer, however, the PIN moves in and out 2 times.
      Have I done something wrong or forgotten something?
      Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.3RC2 (2021-05-11)
      Thanks a lot!
      • jumpedwithbothfeetundefined
        jumpedwithbothfeet
        @asimitabi Its been along time since ive used a bl touch, but I`m pretty sure you will need the brown wire connected to make it work as its the ground to the servo, have a read through this 🙂
        https://docs.duet3d.com/en/User_manual/Troubleshooting/BLTouch_troubleshooting
        6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
        asimitabiundefined 1 Reply Last reply Reply Quote 1
          Phaedrux Moderator @asimitabi
          @asimitabi said in BLTouch issue Duet 3 Mini:
          3.3RC2
          You should also update your firmware to 3.3 final and then 3.4 final.
            asimitabi @jumpedwithbothfeet
            @jumpedwithbothfeet I already tried to connect it to GND on another Pin of the board but then when I try to home z it says the probe is already triggered at the start even if its not. I will try to find a solution in this but on my Duet 2 Wifi everything is working normal with the BLTouch (another printer). I did everything like it is described here: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
            I will also update the firmware if this will make a difference 🙂
            Edit: Im on the latest firmware now (3.4) but still the same problem.
            Where should I plug in the brown cable? I think GND on one of the io pins in the near of i02 should work?
              droftarts administrators @asimitabi
              @asimitabi This is the current documentation page: https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_connecting#bltouch
              Remove the space between the C and pin name on both commands. If I send it with the space, I get an error, without it works fine:
              M950 S0 C"io3.out" ; this is accepted
              M950 S0 C "io3.out" ; this generates following error
              Error: M950: expected string expression
              You can also check your config.g by sending M98 P"config.g". It will probably show the same error.
              Generally you should not need to send M280 commands to control the BLTouch in homez.g.
              Please post your deployprobe.g and retractprobe.g.
              asimitabiundefined 1 Reply Last reply Reply Quote 0
                asimitabi @droftarts
                @droftarts In the config file I have it without the space sorry I got this wrong here but it is fine in the actual file.
                M98 is showing:
                M98 P"config.g"
                Error: Height map file 0:/sys/heightmap.csv not found
                HTTP is enabled on port 80
                FTP is disabled
                TELNET is disabled
                Warning: Heater 0 predicted maximum temperature at full power is 346°C
                Warning: Heater 1 predicted maximum temperature at full power is 527°C
                Warning: Macro file config-override.g not found
                So this should be fine regarding the BLTouch.
                My Deployprobe.g:
                M280 P0 S10       ; Deploy the BLTouch pin
                My Retractprobe.g:
                M280 P0 S90           ; Retract the BLTouch pin
                Thanks!
                  @asimitabi In that case, I'd suspect a continuity problem on the white servo control wire. Check it's connected to the right pin on the connector, too.
                    @droftarts I double checked it now its connected and there is no cable/connection problem.
                    Here is a photo of the i02 pin:
                    Also:
                    The z-Probe status is "1000" all the time
                    Gixxerfastundefined 1 Reply Last reply Reply Quote 0
                    • Gixxerfastundefined
                      Gixxerfast @asimitabi
                      @asimitabi To me it looks like you have it connected to io4.
                      Or am I looking at the wrong picture ?
                      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                      Ender 3 Pro with BTT SKR-2 + RRF
                      asimitabiundefined 1 Reply Last reply Reply Quote 3
                        asimitabi @Gixxerfast
                        @gixxerfast holy sh*t I am so dumb where can I give back my engineering degree?
                        Thank you guys and sorry for that...with the two large plugs, I apparently looked a pin row later...
                        Thanks again and regards! 🙂
                          @asimitabi 🙂
                          Also make sure to have a look in here (or newer docs preferably)
                          // https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Hardware_overview#Section_IO_port_pin_capabilities
                          https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview
                          I guess you want the pwm capability.
