    OK, I give up!
    Firmware installation
    • sheski3
      sheski3 last edited by
      I generated a post on this forum: "How to load firmware using only a SD card" because I cannot connect to my Duet boards. I have done the following:
      1. Used four different boards; one brand new Duet 2 WIFI (just received), two older Duet 2 WIFI that bricked as a result of attempted firmware updates, one Duet 3 mini 5+ (never installed)
      2. Three different computers; a Lenovo laptop (windows 10), A self-built gaming computer (Windows 11, Intel 12th gen processor, 64 Gb RAM, new socket lga 1700 motherboard), an older windows 10 Asus gaming laptop (windows 10).
      3. At least a dozen USB cables.
      4. Unsuccessfully attempting to install Duet drivers, at least a dozen times on all computers without any "successfully installed" message. None of my computers will successfully install these drivers.
      5. Attempted to connect to the original Ender 5 plus Marlin board. Successfully connected, new com port automatically created without problems.
      Both of the Duet 2 WIFI boards previously controlled Ender 3 printers until I attempted to upgrade the firmware. The Ender 5 plus works when I use the original Ender Marlin board.
      I think that because of recent OS updates, the drivers will not load.
      Any further suggestions?
      Jerry
      jumpedwithbothfeet 1 Reply Last reply Reply Quote 0
      • jumpedwithbothfeet
        jumpedwithbothfeet @sheski3 last edited by
        @sheski3 have you been through this?
        https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
        Voron Trident based (4Z) - too much to list!
        sheski3 1 Reply Last reply Reply Quote 0
        • sheski3
          sheski3 @jumpedwithbothfeet last edited by
          @jumpedwithbothfeet Thanks for the recommendation. That was what started it all. I went through the configuration tool and added it to the provided sim card. I put the card into the board and tried to open it. No way to connect through the USB. I tried that several times, and I listed all the other things I tried.
          Thanks,
          Jerry
          jumpedwithbothfeet 2 Replies Last reply Reply Quote 0
            @sheski3 does your windows PC not recognise the USB being plugged in at all? nothing showing in the device manager? to show what com port you are using?
              jumpedwithbothfeet @sheski3 last edited by jumpedwithbothfeet
              @sheski3 have you been through this as well -
              https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
              this is from the old website.
              @Phaedrux I couldn't find reference to the info above on the new website specifically Bossa has it been incorporated or is this procedure not recommended any more do you know?
              #EDIT wrong link added now changed!
              • sheski3
                @jumpedwithbothfeet The computer does not recognize a USB cable attached to a Duet board. Otherwise, the USB works great. That's why I think its the Duet driver not being loaded.
                  Phaedrux Moderator @jumpedwithbothfeet last edited by
                  @jumpedwithbothfeet said in OK, I give up!:
                  Yes.
                  https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware
                  @sheski3 said in OK, I give up!:
                  It's not possible to "brick" a Duet with a firmware update. As long as you can establish a USB connection you can reflash the firmware.
                  I'm not sure why you abandoned that post to start a new one.
                  https://forum.duet3d.com/topic/27888/duet-2-wifi-firmware-install-using-sd-card-only/12?_=1648530588022
                  I'm going to lock this thread and we can continue in your original thread. My last post there goes unanswered.
                  • Locked by  Phaedrux Phaedrux
