    Min and max axis end-stop connections
    • bernardomattiucci
      bernardomattiucci last edited by
      Hi, I'm back after a while to ask a clarification about endstops and related connections.
      On the Duet 2 wifi, each endstop connector has 3 contacts (+3.3v, signal and gnd + shielding).
      So 3 endstops = 3 cables of (3+1) wires = 9 + 1 pin
      I would like to know if this is essential or if the gnd and +3.3v can be merged.
      The problem is that I use an external totem pole for electronics and need to sort out the huge amount of cables and connectors that I am currently using to connect everything to the printer. And I wanted to reduce, if possible, the number of connectors.
      Wanting to install endstops for both min and max of each axis, and having 4 independent Z motors, in addition to the 2 sensors for the filament, I would get in total: 14 3+1 pin cables. (that is 42 wires and 14 shields)
      To reduce the number of connectors and especially wires, I wanted to know if I could use 14 signal + 3.3v + gnd + shield pins, for a total of just 16+1 pins.
      Thanks
      Bernardo
      jay_s_uk droftarts 2 Replies Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @bernardomattiucci last edited by
        @bernardomattiucci what type of endstops are you planning to use?
        bernardomattiucci 1 Reply Last reply Reply Quote 0
        • droftarts
          droftarts administrators @bernardomattiucci last edited by
          @bernardomattiucci You can only have one endstop per motor in RRF. Either min or max, not both. M208 sets the axis length, and a soft limit once the axis has homed.
          You can have two endstops, but only one will be used for homing. The second can be used as a trigger for the axis moving too far. However, if your axis is moving beyond the limits set by M208, you've got other problems.
          bernardomattiucci 1 Reply Last reply Reply Quote 1
          • bernardomattiucci
            bernardomattiucci @jay_s_uk last edited by
            @jay_s_uk optical, similar to this2041-Fine-Corsa-Ottico-Per-stampanti-3D-e-CNC-Endstop.webp
            • bernardomattiucci
              bernardomattiucci @droftarts last edited by
              @droftarts
              not a problem.
              I only need to provide both endstops because the printer can be mounted in different ways and only after the assembly you can decide which endstop to assign to the minimum limit
              • droftarts
                @bernardomattiucci I'd think sharing 5V and GND shouldn't be a problem, but check the current draw of 12x optical sensors (plus the filament sensors) is not higher than the connector specification (3A for KK, I think), or the limits of the 5V regulator. See https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#operating-limits and https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#operating-limits
                Duet 2 5V current limit - 2.0A total on 5V and 3.3v, including the internal current consumption (around 200-300mA), any PanelDue or other display, and any endstops/Z probes that draw significant power.
                DueX 5V current limit - (supplied by connected Duet 2) 1A total on PWM pins and fans (when internal 5V is selected)
                Or use external 5V power supply on DueX.
