    How to be able to reach DWC from outside homenetwork
    Duet Web Control
    • Topenga
      Topenga last edited by
      Hi guys,
      May somebody tell me how to set the DWC or rather how to realise the DWC reachable secured from outside the own home network?
      Many thanks
      Dan
      o_lampe markz 2 Replies Last reply Reply Quote 0
      • o_lampe
        o_lampe @Topenga last edited by
        @topenga
        VPN comes to my mind (Virtual Private Network). With an SBC, there are similar tools (SAMBA?), but I haven't tried it myself.
        Do you really want to control the printer or just check? Maybe an IP-Camera would be better suited then?
        • Topenga
          @o_lampe,
          Many thanks for your replay.
          O.k. VPN does that mean that I have to buy software to be able "tunnel" my data through the www?
          What about speed? Is there any significant performance lose?
          To to your question:
          Honestly it makes just sence to observe the print process trough the cam and maybe start a print and stop the process when problems occures.
          I guess that just that will be necessary
          Many thanks in advance
          • markz
            markz @Topenga last edited by
            @topenga The usual approach is to alter your firewall/router so that the DWC port is forwarded to the outside world as a different port.
            1. Find out your home network public IP address by going to Whatsmyip.com or similar web sites. This may randomly change depending on your provider.
            2. Forward port 80 of the DWC to port ? (say 8324) of the home network. - this is a security concern so I'd unforward it when you're finished
            3. You may need to enable CORS on the DWC -- M586 C"*"
            4. From outside, browse to my-public-ip:8324
            Topenga 1 Reply Last reply Reply Quote 0
            • Topenga
              Topenga @markz last edited by
              @markz many thanks for that suggestion/information. Will try that as well how to easy and fast after ending observation of the printer to ensure the port again.
              Will let you inform how it works
              Many thanks
              Dan
