    Solved Duet 0.6 temp problem
    duet temperature sensor
    210
    • SM180
      SM180 last edited by
      Hello and excuse me for my poor english (I write from Italy).
      I have a problem with my old Ormerod 2 (528.2), equiped with a Duet 0.6: I finally decided to update firmware (now 1.26.1) and web interface (1.22.6)..... but when I restarted the printer, bed and hotend show 2000° (open circuit) !
      I test the thermistors (both values are 122k) and also wires appear ok. Pheraps a bad config.g or a vssa fuse problem?
      This is my config heaters section:
      M305 P0 T10000 B3988 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      Thanks
        Did you make any other changes recently?
        If you revert firmware version does it go back to normal?
        SM180 1 Reply Last reply Reply Quote 0
        • SM180
          SM180 @Phaedrux last edited by SM180
          @phaedrux Unfortunatly I didn't save my old config file😵, so I can't verify the old configuration solves the problem.....
          No other changes was made.
          dc42 droftarts 2 Replies Last reply Reply Quote 0
            dc42 administrators @SM180 last edited by
            @sm180 do you know what firmware version you were using before the upgrade?
            Please post your whole config.g file.
            • droftarts
              droftarts administrators @SM180 last edited by
              @sm180 Some Duet 0.6 had 1k ohm series resistors, but that would only make the temperature read around 60C at room temperature (see https://reprapltd.com/reprappro/documentation/ormerod-2/commissioning/index.html#Setting_the_temperatures_correctly). And I don't think Ormerods were shipped with those boards.
              I'd guess a config.g error. Please post your config.g
              You can test the temperature inputs with resistors; I have these in my troubleshooting drawer, to plug straight onto the temperature input pins:
              SM180 1 Reply Last reply Reply Quote 1
              • SM180
                SM180 @dc42 last edited by
                @dc42 I'm not sure about the previsious version, pherhaps 1.21....; this is my config.g (I try to change the thermistore value with 3950, but nothing changes)
                config.g
                • SM180
                  SM180 @droftarts last edited by SM180
                  @droftarts My Duet appears like a "1k ohm" type - resistor R21 and R19 are marked "01b".
                  ....so I have to change the R4700 value! For 1k ohm Duet is it "R1000"?
                  • SM180
                    SM180 @SM180 last edited by
                    @sm180 said in Duet 0.6 temp problem:
                    Ok, I put "R1000" in config.g and..... IT WORKS!!!!
                    Thanks to the forum and nice printing !
                    • Topic has been marked as a question  dc42 dc42
                    • Topic has been marked as solved  dc42 dc42
