    RGB LED SK6812 vs Mini?
    282
    • Chriss
      Chriss last edited by
      Hi *,
      I try to run 3 SK6812 RGBNW LEDs via the Neopixel port on my Mini5+ without any success. H hope that somebody can help me here. (Fw: 3.4)
      I have measure +5V on the newpixels so I guess that the jumpering for the 5V supply is correct.
      I tried things like that:
      M150 X3
      M150 R255 B255 P255 S20 X3
      To turn on the leds but without success, the neopixels remain dark. I tried X1 and some other parameters but nothing has changed.
      Any ideas?
      Cheers, Chriss
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @Chriss last edited by
        @chriss You may need F0 on the second M150 after the X3 command is set.
        https://docs.duet3d.com/User_manual/Reference/Gcodes#m150-set-led-colours
        Chriss 1 Reply Last reply Reply Quote 0
        • Chriss
          Chriss @Stephen6309 last edited by
          @stephen6309 No change unfortunately. 😞
          Stephen6309 2 Replies Last reply Reply Quote 0
          • Stephen6309
            @chriss On my Mini and 6HC I used a separate 5vdc power supply. The mini may not have enough power to power them.
            • Stephen6309
              @chriss The Mini needs an external 5vdc to power the neopixel.
              https://docs.duet3d.com/en/User_manual/Connecting_hardware/IO_Neopixel_DotStar
              Chriss 1 Reply Last reply Reply Quote 1
              • Chriss
                @stephen6309
                My understanding is that the Mini5+ can deliver 3A. I guess that this would be enough for one neopixel I'm playing with at the moment...
                  dc42 administrators @Chriss last edited by
                  @chriss said in RGB LED SK6812 vs Mini?:
                  The Mini5+ is limited to 1A total from the 5V rail including the internal current draw.
                  From https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview#description-of-connections:
                  This is to connect and power NeoPixel LED strips (DotStar LED strips are not supported) . Connect the DO pin to Neopixel DI. External 5V must be supplied to the "EXT 5V" header to power the NeoPixel array, they cannot be powered from the onboard regulator.
                  • Chriss
                    Chriss @dc42 last edited by
                    Got it.. I had the hope that I can drive 3 tiny LEDs without a external source... well well....
                      @chriss if it's just 3 LEDs then you could pick up +5V from one of the IO connectors and feed it into the 5V_EXT input.
                      • Chriss
                        @dc42 said in RGB LED SK6812 vs Mini?:
                        Ahhhhhh... that's a very, very good idea... I need to check for a free 5V pin on the IO ports..... I guess that I need to feed GND too.
                          dc42 administrators @Chriss last edited by dc42
                          @chriss no, just the 5V. The GND on the Neopixel connector will be sufficient.
                          • Chriss
                            @dc42 Thanks!
