    Delta - Nozzle crashing into bed
    451
    • malkem
      malkem last edited by malkem
      Hi guys,
      I've updated my reprapfirmware from 2.05 to 3.4 yesterday. I have noticed that it is necessary to set up the configuration again. Therefore I used the provided config tool.
      My printer:
      • Delta (Tevo Little Monster)
      • Duet 2 WiFi
      • smart effector
      I dont know, what I'am doing wrong but since the update my Nozzle keeps crashing into the bed after auto calibration.
      My prints always starts with pre heating the bed (70 °C) and hotend (120 °C) followed by auto calibration (G32)
      config.g (I took the values I had in the old config.g)
      M558 P8 R0.4 C"zprobe.in+zprobe.mod" H18 F240 T4000
      G31 P50 X0 Y0 Z-0.07
      M557 R130 S10
      bed.g (the same as in version 2.05)
      G28 ; home all towers
      ; Probe the bed at 12 peripheral and 0 halfway points, and perform 8-factor auto compensation
      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
      G30 P0 X0.00 Y113.04 Z-99999 H0
      G30 P1 X74.67 Y88.99 Z-99999 H0
      G30 P2 X123.50 Y21.78 Z-99999 H0
      G30 P3 X112.58 Y-65.00 Z-99999 H0
      G30 P4 X44.46 Y-122.16 Z-99999 H0
      G30 P5 X-44.46 Y-122.16 Z-99999 H0
      G30 P6 X-112.58 Y-65.00 Z-99999 H0
      G30 P7 X-123.50 Y21.78 Z-99999 H0
      G30 P8 X-74.67 Y88.99 Z-99999 H0
      G30 P9 X0.00 Y50.00 Z-99999 H0
      G30 P10 X47.75 Y27.57 Z-99999 H0
      G30 P11 X56.29 Y-32.50 Z-99999 H0
      G30 P12 X0.00 Y-65.00 Z-99999 H0
      G30 P13 X-56.29 Y-32.50 Z-99999 H0
      G30 P14 X-47.75 Y27.57 Z-99999 H0
      G30 P15 X5 Y0 Z-99999 S8 ;G30 P15 X0 Y0 Z-99999 S8
      Start G-Code in prusa-slicer
      M558 P8 R0.4 C"zprobe.in+zprobe.mod" H8.5 F240 T4000
      M109 S120
      G28
      G32 ; auto calibration
      ;G29 S1 ; heightmap.csv
      G1 X0 Y0 Z100; lift nozzle
      G92 E0; resets the extruder
      M104 S[first_layer_temperature]
      M109 S[first_layer_temperature]
      G1 X0 Y0 Z10; lower nozzle
      Is there something wrong in my configuration?
      regards
      • blt3dp
        blt3dp last edited by
        In your start gcode, you don't really need do do M558 again as you already have that in config.g
        I'm assuming the M665 in your config is the same as it was before? Specifically the H parameter for homed height? If that were off, it may think it's farther away from the bed than it is.
        Also in your start gcode, you'll want a G30 between the G28 and G32 lines. That will set the 0 position.
        My 3D Printing YouTube Channel
        Better Living Through 3D Printing
        Follow me on Instagram and Twitter
        Instagram
        Twitter
        malkem 1 Reply Last reply Reply Quote 0
        • malkem
          malkem @blt3dp last edited by
          @blt3dp
          Hi and thanks for the fast reply.
          They are the same
          M665 L400.350 R172.703 H511.873 B155.0 X-0.022 Y-0.040 Z0.000
          M666 X-0.599 Y-0.539 Z1.138 A0.04 B0.33
          I've just put the G30 between G28 and G32.
          So after homing with G28 my printer starts to single probe from the very top.
          It takes about 5 minutes to get the nozzle to the bottom 😁
          Why is the single probe necessary before auto calibration (G32)?
          blt3dp 1 Reply Last reply Reply Quote 0
          • blt3dp
            blt3dp @malkem last edited by
            @malkem G30 gets the Z0 position. You could add something like G0 X0 Y0 Z10 F1800 before the g30 just to move the nozzle down towards the bed a little faster.
            Instagram
            Twitter
            • malkem
              @blt3dp
              I dont get it. I put the G30 between G28 and G32, the result is the same. As soon as the printer starts to print it crashes into the bed, not by much but I can hear the knock.
              Would it help to decrease the Z-value in G31 P50 X0 Y0 Z-0.07?
              fcwilt 1 Reply Last reply Reply Quote 0
              • fcwilt
                fcwilt @malkem last edited by
                @malkem said in Delta - Nozzle crashing into bed:
                @blt3dp
                The larger the Z Trigger Height value the closer the nozzle ends up to the bed when Z is set to 0.
                So make the value smaller could help with your problem.
                • malkem
                  malkem @fcwilt last edited by malkem
                  @fcwilt
                  Tried it out to decrease Z to -2 (G31 P50 X0 Y0 Z-2).
                  My printer doesn't care anymore. He lower the nozzle always to the same height, what is likely Z0.
                  I remember increasing/decreasing the G31 Z value helped me in version 2.05.
                  Any other ideas?
                  Maybe the whole config.g will help?
                  config.g
                  ; Configuration file for Duet WiFi (firmware version 3.3)
                  ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Apr 11 2022 12:41:54 GMT+0200 (Mitteleuropäische Sommerzeit)
                  G90                                                  ; send absolute coordinates...
                  M83                                                  ; ...but relative extruder moves
                  M550 P"TLM"                                          ; set printer name
                  M665 L400.350:400.350:400.350 R172.703 H511.873 B155.0 X-0.022 Y-0.040 Z0.000                          ; Set delta radius, diagonal rod length, printable radius and homed height
                  M666 X0 Y0 Z0                                        ; put your endstop adjustments here, or let auto calibration find them
                  M552 S1                                              ; enable network
                  M586 P0 S1                                           ; enable HTTP
                  M586 P1 S0                                           ; disable FTP
                  M586 P2 S0                                           ; disable Telnet
                  M569 P0 S1                                           ; physical drive 0 goes forwards
                  M569 P1 S1                                           ; physical drive 1 goes forwards
                  M569 P2 S1                                           ; physical drive 2 goes forwards
                  M569 P3 S1                                           ; physical drive 3 goes forwards
                  M584 X0 Y1 Z2 E3                                     ; set drive mapping
                  M350 X16 Y16 Z16 E16 I1                              ; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z80.00 E815.00                     ; set steps per mm
                  M566 X540.00 Y540.00 Z540.00 E240.00                 ; set maximum instantaneous speed changes (mm/min)
                  M203 X24000.00 Y24000.00 Z24000.00 E6000.00          ; set maximum speeds (mm/min)
                  M201 X7500.00 Y7500.00 Z7500.00 E3000.00             ; set accelerations (mm/s^2)
                  M906 X1600 Y1600 Z1600 E1000 I30                     ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                              ; Set idle timeout
                  M208 Z0 S1                                           ; set minimum Z
                  M574 X2 S1 P"xstop"                                  ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
                  M574 Y2 S1 P"ystop"                                  ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                  M574 Z2 S1 P"zstop"                                  ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
                  M558 P8 R0.4 C"zprobe.in+zprobe.mod" H18 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
                  G31 P50 X0 Y0 Z-2                                 ; set Z probe trigger value, offset and trigger height
                  M557 R130 S10                                        ; define mesh grid
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B3950       ; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" T0                                ; create bed heater output on bedheat and map it to sensor 0
                  M307 H0 B0 S1.00                                     ; disable bang-bang mode for the bed heater and set PWM limit
                  M307 H0 R1.501 K0.636:0.000 D1.85 E1.35 S1.00 B0 ; PID parameter
                  M140 H0                                              ; map heated bed to heater 0
                  M143 H0 S100                                         ; set temperature limit for heater 0 to 100C
                  M308 S1 P"e0temp" Y"thermistor" T100000 B3950        ; configure sensor 1 as thermistor on pin e0temp
                  M950 H1 C"e0heat" T1                                 ; create nozzle heater output on e0heat and map it to sensor 1
                  M307 H1 B0 S1.00                                     ; disable bang-bang mode for heater  and set PWM limit
                  M307 H1 R2.755 K0.408:0.372 D5.79 E1.35 S1.00 B0 V24.0	; PID parameter
                  M143 H1 S260                                         ; set temperature limit for heater 1 to 260C
                  M950 F0 C"fan0" Q500                                 ; create fan 0 on pin fan0 and set its frequency
                  M106 P0 S0 H-1                                       ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"fan1" Q500                                 ; create fan 1 on pin fan1 and set its frequency
                  M106 P1 S1 H1 T125                                   ; set fan 1 value. Thermostatic control is turned on
                  M950 F2 C"fan1" Q500                                 ; create fan 2 on pin fan1 and set its frequency
                  M106 P2 S1 H-1                                       ; set fan 2 value. Thermostatic control is turned off
                  M563 P0 D0 H1 F0                                     ; define tool 0
                  G10 P0 X0 Y0 Z0                                      ; set tool 0 axis offsets
                  G10 P0 R0 S0                                         ; set initial tool 0 active and standby temperatures to 0C
                  config-override.g
                  ; config-override.g file generated in response to M500 at 2022-04-12 20:28
                  ; Delta parameters
                  ; Heater model parameters
                  • fcwilt
                    @malkem
                    You don't need to run a print to verify that things are OK.
                    Move the probe to the center of the bed. Execute G30. When done it should end up at appx Z=16.
                    Then jog down until the nozzle is just touching the bed. Check the Z position in the DWC. It should be close to 0 if all is well.
                      Have you actually tried to measure your probe trigger height yet?
                      https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing#calibrate-the-z-probe-trigger-height
                      Also, just in case, can you send M122 and M98 P"config.g" and post the results?
                      • malkem
                        malkem @Phaedrux last edited by malkem
                        @phaedrux
                        Hi and thanks for the reply!
                        Here the results
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
                        Board ID: 08DGM-956GU-DJMSN-6JKD2-3SN6T-TVNRD
                        Used output buffers: 3 of 24 (13 max)
                        Static ram: 23868
                        Dynamic ram: 73840 of which 176 recycled
                        Never used RAM 14196, free system stack 184 words
                        Tasks: NETWORK(ready,13.0%,232) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) MAIN(running,85.7%,440) IDLE(ready,1.3%,30), total 100.0%
                        Owned mutexes: WiFi(NETWORK)
                        Last reset 00:01:23 ago, cause: power up
                        Last software reset at 2022-04-14 23:32, reason: User, GCodes spinning, available RAM 14296, slot 2
                        Error status: 0x00
                        Step timer max interval 0
                        MCU temperature: min 19.8, current 25.1, max 25.3
                        Supply voltage: min 24.2, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                        Events: 0 queued, 0 completed
                        Driver 0: standstill, SG min n/a
                        Driver 1: standstill, SG min n/a
                        Driver 2: standstill, SG min n/a
                        Driver 3: standstill, SG min n/a
                        Driver 4: standstill, SG min n/a
                        Driver 5:
                        Driver 6:
                        Driver 7:
                        Driver 8:
                        Driver 9:
                        Driver 10:
                        Driver 11:
                        Date/time: 2022-04-15 11:46:34
                        Cache data hit count 2901757074
                        Slowest loop: 15.73ms; fastest: 0.19ms
                        === Storage ===
                        Free file entries: 10
                        SD card longest read time 1.2ms, write time 0.0ms, max retries 0
                        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                        === MainDDARing ===
                        === AuxDDARing ===
                        Segments left: 0
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Code queue is empty
                        === Network ===
                        Slowest loop: 161.06ms; fastest: 0.00ms
                        HTTP sessions: 1 of 8
                        - WiFi -
                        Network state is active
                        WiFi firmware version 1.26
                        WiFi MAC address 5c:cf:7f:76:68:64
                        WiFi Vcc 3.36, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 24408
                        WiFi IP address 192.168.178.33
                        WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
                        Clock register 00002002
                        Socket states: 4 0 0 0 0 0 0 0
                        M98 P"config.g"
                        HTTP is enabled on port 80
                        FTP is disabled
                        TELNET is disabled
                        Error: bad grid definition: Too many grid points; suggest increase spacing to 13.0mm
                        Error: Pin 'fan1' is not free
                        Error: Fan number 2 not found
                        @phaedrux said in Delta - Nozzle crashing into bed:
                        I've done this in the past but I will give it another try.
                        I haven't change any hardware components.
                        • malkem
                          malkem @malkem last edited by malkem
                          Just measured the Z trigger height. It is -0.15
                          I've set the Z value to -2 so the nozzle should be far above the bed, am I right?
                            Phaedrux Moderator @malkem last edited by
                            Yes. -2mm is pretty extreme. That would make it think that the nozzle is 2mm below the bed surface when the probe triggers.
                            So tell me this, set your G31 Z trigger height correctly to -0.15 and then if you do a G28 to home the towers and then a G30 to probe the bed to set Z0, if you then send G1 Z0 does the nozzle end up just touching the bed?
                            • malkem
                              @phaedrux
                              Good morning phaedrux
                              I just did how you said and the nozzle was not crashing into the bed.
                              The space between nozzle and bed was just enough to slide in the sheet of paper I used to determine the Z trigger height.
                              I've send G32 after G30 and went again to Z0 and nothing has changed, it was enough space to slide in the sheet of paper.
                              This part seems working fine.
                              So what the hell is the problem of my printer?
                              I'm close to toss him out the window 😠
                              • malkem
                                I'm running out of ideas.
                                Should I downgrade? Is it even possible?
                                In my old config.g (v2.05) I've used P1 instead of P8 "M558 P1 H18 F240 R0.4 T4000"
                                Could it change anything?
                                I took a look into the gcode file, there is also nothing suspicious in my opinion.
                                ; generated by PrusaSlicer 2.4.1+win64 on 2022-04-16 at 18:16:02 UTC
                                ; external perimeters extrusion width = 0.50mm
                                ; perimeters extrusion width = 0.50mm
                                ; infill extrusion width = 0.46mm
                                ; solid infill extrusion width = 0.45mm
                                ; top infill extrusion width = 0.40mm
                                ; support material extrusion width = 0.35mm
                                ; first layer extrusion width = 0.70mm
                                M107
                                M190 S60 ; set bed temperature and wait
                                ;TYPE:Custom
                                ;M558 P1 H8.5 F240 R0.4 T4000
                                M558 P8 R0.4 C"zprobe.in+zprobe.mod" H3 F240 T6000
                                M109 S120
                                G28
                                G1 X0 Y0 Z8.5 F6000
                                G30
                                M104 S210
                                M109 S210
                                G21 ; set units to millimeters
                                G90 ; use absolute coordinates
                                M82 ; use absolute distances for extrusion
                                G92 E0
                                ;M572 D0 S0.05; linear advanced PLA-NX2
                                M107
                                ;LAYER_CHANGE
                                ;Z:0.35
                                ;HEIGHT:0.35
                                G1 Z.35 F27000
                                G1 E-2.8 F2400
                                G92 E0
                                G1 Z.55 F27000
                                G1 X0 Y14.575
                                G1 Z.35
                                G1 E2.8 F2400
                                ;TYPE:Skirt/Brim
                                ;WIDTH:0.7
                                G1 X-43.737 Y14.575 E6.49863
                                G1 X-44.622 Y14.439 E6.57429
                                G1 X-45.393 Y14.072 E6.64657
                                G1 X-46.033 Y13.478 E6.72039
                                G1 X-46.457 Y12.732 E6.79294
                                G1 X-46.657 Y11.769 E6.87613
                                G1 X-46.546 Y10.734 E6.96417
                                G1 X-46.132 Y9.713 E7.05727
                                G1 X-45.438 Y8.762 E7.15689
                                G1 X-22.591 Y-14.091 E9.88954
                                G1 X-21 Y-14.75 E10.03515
                                G1 X21 Y-14.75 E13.58686
                                G1 X22.591 Y-14.091 E13.73247
                                G1 X45.633 Y8.986 E16.4902
                                G1 X46.078 Y9.619 E16.5556
                                G1 X46.402 Y10.284 E16.6182
                                G1 X46.598 Y10.965 E16.67807
                                G1 X46.661 Y11.635 E16.73506
                                G1 X46.584 Y12.315 E16.79292
                                G1 X46.377 Y12.92 E16.84695
                                G1 X46.047 Y13.461 E16.90053
                                G1 X45.613 Y13.908 E16.95323
                                G1 X44.75 Y14.397 E17.03707
                                G1 X43.737 Y14.575 E17.12405
                                G1 X.06 Y14.575 E20.81758
                                G1 X.06 Y13.95 F27000
                                G1 F2400
                                G1 X-43.722 Y13.95 E24.52001
                                G1 X-44.426 Y13.846 E24.58014
                                G1 X-45.043 Y13.554 E24.63786
                                G1 X-45.533 Y13.103 E24.69422
                                G1 X-45.878 Y12.498 E24.7531
                                G1 X-46.035 Y11.694 E24.82235
                                G1 X-45.925 Y10.831 E24.89594
                                G1 X-45.559 Y9.97 E24.97506
                                G1 X-44.963 Y9.169 E25.0595
                                G1 X-22.149 Y-13.649 E27.78808
                                G1 X-21 Y-14.125 E27.89325
                                G1 X21 Y-14.125 E31.44496
                                G1 X22.149 Y-13.649 E31.55013
                                G1 X45.101 Y9.324 E34.29624
                                G1 X45.779 Y10.41 E34.40454
                                G1 X45.961 Y10.973 E34.45455
                                G1 X46.034 Y11.532 E34.50226
                                G1 X45.996 Y12.068 E34.54771
                                G1 X45.849 Y12.571 E34.592
                                G1 X45.597 Y13.018 E34.63538
                                G1 X45.24 Y13.405 E34.67995
                                G1 X44.547 Y13.806 E34.74759
                                G1 X43.725 Y13.95 E34.81815
                                G1 X.12 Y13.95 E38.50562
                                G1 E35.70562
                                G92 E0
                                G1 Z.55 F27000
                                G1 X-20.161 Y-1.329
                                G1 Z.35
                                G1 E2.8 F2400
                                ;TYPE:Perimeter
                                G1 X-20.429 Y-.989 E2.83663
                                G1 X-20.751 Y-.714 E2.87243
                                G1 X-21.128 Y-.502 E2.90899
                                G1 X-21.53 Y-.372 E2.94472
                                G1 X-21.957 Y-.321 E2.98107
                                G1 X-22.364 Y-.351 E3.01556
                                G1 X-22.781 Y-.465 E3.05212
                                G1 X-23.169 Y-.66 E3.08883
                                G1 X-23.502 Y-.92 E3.12457
                                G1 X-23.784 Y-1.248 E3.16116
                                G1 X-23.991 Y-1.614 E3.19668
                                G1 X-24.124 Y-2.012 E3.23219
                                G1 X-24.179 Y-2.443 E3.26895
                                G1 X-24.147 Y-2.876 E3.3057
                                G1 X-24.034 Y-3.283 E3.34141
                                G1 X-23.84 Y-3.669 E3.37791
                                G1 X-23.581 Y-4 E3.41346
                                G1 X-23.264 Y-4.276 E3.44898
                                G1 X-22.888 Y-4.49 E3.48555
                                G1 X-22.488 Y-4.624 E3.52129
                                G1 X-22.059 Y-4.679 E3.55783
                                G1 X-21.638 Y-4.649 E3.59351
                                G1 X-21.219 Y-4.535 E3.63025
                                G1 X-20.831 Y-4.339 E3.66702
                                G1 X-20.498 Y-4.08 E3.70269
                                G1 X-20.217 Y-3.753 E3.73914
                                G1 X-20.009 Y-3.387 E3.77478
                                G1 X-19.875 Y-2.986 E3.81052
                                G1 X-19.821 Y-2.544 E3.84817
                                G1 X-19.854 Y-2.122 E3.88399
                                G1 X-19.966 Y-1.716 E3.91955
                                G1 X-20.134 Y-1.383 E3.95117
                                G1 X-20.691 Y-1.666 F27000
                                ;TYPE:External perimeter
                                G1 F2400
                                G1 X-20.882 Y-1.424 E3.97729
                                G1 X-21.11 Y-1.229 E4.00268
                                G1 X-21.38 Y-1.077 E4.02882
                                G1 X-21.665 Y-.985 E4.05414
                                G1 X-21.971 Y-.949 E4.0802
                                G1 X-22.258 Y-.97 E4.10451
                                G1 X-22.556 Y-1.051 E4.13066
                                G1 X-22.833 Y-1.191 E4.15685
                                G1 X-23.069 Y-1.375 E4.18218
                                G1 X-23.271 Y-1.609 E4.20835
                                G1 X-23.418 Y-1.869 E4.23357
                                G1 X-23.512 Y-2.152 E4.25879
                                G1 X-23.551 Y-2.459 E4.28502
                                G1 X-23.528 Y-2.769 E4.31124
                                G1 X-23.448 Y-3.057 E4.33655
                                G1 X-23.309 Y-3.333 E4.36265
                                G1 X-23.126 Y-3.568 E4.3879
                                G1 X-22.9 Y-3.764 E4.41312
                                G1 X-22.632 Y-3.917 E4.43929
                                G1 X-22.348 Y-4.012 E4.46461
                                G1 X-22.041 Y-4.051 E4.49075
                                G1 X-21.743 Y-4.03 E4.51602
                                G1 X-21.444 Y-3.949 E4.54224
                                G1 X-21.167 Y-3.809 E4.56848
                                G1 X-20.931 Y-3.625 E4.59375
                                G1 X-20.73 Y-3.392 E4.61981
                                G1 X-20.583 Y-3.131 E4.64514
                                G1 X-20.488 Y-2.847 E4.67046
                                G1 X-20.449 Y-2.53 E4.69748
                                G1 X-20.472 Y-2.231 E4.72288
                                G1 X-20.552 Y-1.943 E4.74814
                                G1 X-20.664 Y-1.72 E4.76925
                                G1 X-20.549 Y-1.392 F27000
                                G1 E1.96925 F2400
                                G92 E0
                                • fcwilt
                                  @malkem
                                  Why did you change to probe type 8?
                                  I would think the strain gauge would output an analog signal.
                                  • malkem
                                    @fcwilt
                                    I changed it back to P1, it didn't help. Got the same results.
                                    If I do it manually G28 -> G30 -> G32 and move the nozzle to Z0, there is a gap between bed and nozzle, just how we would expect.
                                    If I upload a gcode file and start to print, the DWC shows that the nozzle is moving to the first layer height to Z.35. But the nozzle is actually flat on the bed.
                                    • fcwilt
                                      @malkem
                                      Well in the print file you have G28 then G30 then G32 then G29.
                                      Remember that G29 is going to change the Z position based on the X/Y position.
                                      Also for the height map to work correctly you need to set the Z=0 Datum before creating the height map and before loading the height map. Moreover the X/Y position used for setting the Z=0 Datum must always be the same. I use the center of the bed which for me is at X=0 Y=0.
                                      I don't have a delta so I am not sure what G32 does, exactly, but I think you should still have a G30 at your reference point before you do the G29.
                                      And did you set the Z=-0 Datum before creating the height map?
                                      • malkem
                                        @fcwilt
                                        Hi and thanks for your time helping me out here 👍
                                        heightmap and G29 was never a problem before. I've also tried without G29.
                                        I downgraded to version 2.05 and my printer works again.
                                        I dont know if this is a bug or just me doing something wrong.
                                        If you guys want me to try something out, I will do it. But for now I'll stay on version 2.05.😁
