    Flsun Cube printer update
    • Maxsky
      Maxsky last edited by
      I have a Flsun cube Mks Gen L v1.0 3d printer and I want to change the motherboard, I would like to know if a Duet2 wifi with 7" touchscreen or a Duet 3 Mainboard 6HC with 7" touchscreen is better for me.
      Thank you very much
      oliof 1 Reply Last reply Reply Quote 0
      • oliof
        oliof @Maxsky last edited by
        @maxsky I would go for a duet3 mini.
        <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
        Maxsky 1 Reply Last reply Reply Quote 0
        • Maxsky
          Maxsky @oliof last edited by
          @oliof Motherboard Duet 3 6HC with 7" touchscreen is not good for what I want to do?
          I'm about to buy it, it helps me put the printer to work and earn some money with it and that's why I'm looking for something that gives me a precise finish.
          oliof jay_s_uk 2 Replies Last reply Reply Quote 0
          • oliof
            @maxsky 6HC and PanelDue 7in will certainly bring the printer to life. The 6HC is just a lot of performance for this kind of printer which will go mostly unused. Even if you would need three motors for Z a duet 3 mini with a toolboard for the print head or the two stepper expansion board would be a better choice IMO. If you plan to connect the printer wirelessly, a Duet3 mini is even better a choice because it comes with wifi integrated while the Duet3 6HC requires either a dedicated bridging Access Point or a Raspberry Pi to run in SBC mode to get a wifi connection.
            • jay_s_uk
              jay_s_uk @Maxsky last edited by
              @maxsky i ran my flsun cube with a duet 3 mini. more than enough for that printer
