    what code to modify for z motors ,one on z and one on e1
    Config Tool
    584
    • DallasH
      DallasH last edited by
      what code to modify for 2 z motors ,one on z and one on e1 with switches on end stops and bl touch for bed probing?
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Apr 16 2022 15:16:49 GMT-0400 (Eastern Daylight Time)
      M550 P"My Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z3200.00 E420.00:3200.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X350 Y350 Z400 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
      G31 P500 X175 Y175 Z2.5 ; set Z probe trigger value, offset and trigger height
      M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
      M557 X25:325 Y25:325 S50 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      • fcwilt
        fcwilt last edited by
        @dallash said in what code to modify for z motors ,one on z and one on e1:
        Change M584 X0 Y1 Z2 E3:4 to M584 X0 Y1 Z2:4 E3
        Change M574 Z1 S1 P"zstop" to M574 Z1 S1 P"zstop + e1stop"
        But you have to be sure that the stepper designated by Z2 uses the zstop and the stepper designated by Z4 uses the e1stop.
        When you home Z each Z stepper will run until it's associated endstop is triggered.
        DallasH 1 Reply Last reply Reply Quote 0
        • DallasH
          DallasH @fcwilt last edited by
          @fcwilt . ok so i got the changes made, but when i start the duet 2 wifi and try to home , it does nothing except says files on card 0
          fcwilt 1 Reply Last reply Reply Quote 0
          • fcwilt
            fcwilt @DallasH last edited by
            So you are saying your config.g file is gone?
            • DallasH
              @fcwilt if i connect wit yat dwc comes up and everything looks correct, but when i try to home or make any commands via the panel due nothing happens except a pop up that says files on card 0. i installed the latest firmware, i also tried formatting a new sd card with the /firmware and /sys files from the zipped config all in 1 download, still behaves the same
              • fcwilt
                So you cannot connect to the DWC via a browser?
                • DallasH
                  @fcwilt no
                  • DallasH
                    DallasH @DallasH last edited by
                    @dallash always says connecting
                    • DallasH
                      @dallash i'm giving up for today. thanks
                        I suggest you start here: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
                        • DallasH
                          DallasH @Phaedrux last edited by
                          @phaedrux I cant connect even with yat now. i get this error when trying to update driversDUET ERROR.JPG
                          • DallasH
                              What OS?
                              • DallasH
                                @phaedrux win 7 ultimate, 64 bit
                                  That's a blast from the past. Does anything new show up in device manager even without the driver?
                                  • DallasH
                                    @phaedrux ok i finally got everything talking, everything works from dwc thru a wifi browser, but nothing works from the panel due, display looks fine, but if you touch home it pops up a screen that says files on card 0. i can find nothing that responds from the panel due
                                    • fcwilt
                                      Does the PanelDue have the correct firmware required by the current Duet firmware?
                                      • DallasH
                                        DallasH @fcwilt last edited by DallasH
                                        @fcwilt panel due v3.0a 5i display firmware 1.17 not sure what firmware to use with rrf 3.4! would this be correct ? (PanelDueFirmware-3.4.1-pre1-v3-5.0.bin)
                                        • fcwilt
                                          Here is some information:
                                          https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_PanelDue
                                          DallasH 1 Reply Last reply Reply Quote 1
                                          • DallasH
                                            @fcwilt I UPDATED the panel due firmware. but still have unresponsive panel due.
                                              Add this line to the beginning of your config.g M575 P1 B57600 S1
                                              And change the baud setting on your PanelDue settings to 57600 to match.
                                              • fcwilt
                                                @dallash
                                                Well it's still not connecting.
                                                First thing to check would be the wiring.
                                                How do you have it connected?
                                                • DallasH
                                                  @phaedrux AWESOME! THAT DID THE TRICK! THANKS SO MUCH!!!!
                                                  • DallasH
                                                    @fcwilt I have the ribbon cable and the 4 wire lead connected.
                                                    fcwilt 1 Reply Last reply Reply Quote 1
                                                      You should probably choose one or the other. Only use the ribbon cable if you want to use the SD card reader on the PanelDue as a second slot for loading gcodes. Otherwise the 4-wire connection is recommended.
