    what code to modify for z motors ,one on z and one on e1
    Config Tool
    1.5k
    • fcwiltundefined
      fcwilt @DallasH
      @dallash said in what code to modify for z motors ,one on z and one on e1:
      @fcwilt . ok so i got the changes made, but when i start the duet 2 wifi and try to home , it does nothing except says files on card 0
      So you are saying your config.g file is gone?
      DallasHundefined 1 Reply Last reply Reply Quote 0
      • DallasHundefined
        DallasH @fcwilt
        @fcwilt if i connect wit yat dwc comes up and everything looks correct, but when i try to home or make any commands via the panel due nothing happens except a pop up that says files on card 0. i installed the latest firmware, i also tried formatting a new sd card with the /firmware and /sys files from the zipped config all in 1 download, still behaves the same
        • fcwiltundefined
          fcwilt @DallasH
          So you cannot connect to the DWC via a browser?
          • DallasHundefined
            DallasH @fcwilt
            @fcwilt no
            • DallasHundefined
              DallasH @DallasH
              @dallash always says connecting
              • DallasHundefined
                DallasH @DallasH
                @dallash i'm giving up for today. thanks
                  I suggest you start here: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
                  • DallasHundefined
                    DallasH @Phaedrux
                    @phaedrux I cant connect even with yat now. i get this error when trying to update driversDUET ERROR.JPG
                    • DallasHundefined
                      DallasH @DallasH
                        What OS?
                        • DallasHundefined
                          DallasH @Phaedrux
                          @phaedrux win 7 ultimate, 64 bit
                            That's a blast from the past. Does anything new show up in device manager even without the driver?
                            • DallasHundefined
                              DallasH @Phaedrux
                              @phaedrux ok i finally got everything talking, everything works from dwc thru a wifi browser, but nothing works from the panel due, display looks fine, but if you touch home it pops up a screen that says files on card 0. i can find nothing that responds from the panel due
                              • fcwiltundefined
                                fcwilt @DallasH
                                Does the PanelDue have the correct firmware required by the current Duet firmware?
                                • DallasHundefined
                                  DallasH @fcwilt
                                  @fcwilt panel due v3.0a 5i display firmware 1.17 not sure what firmware to use with rrf 3.4! would this be correct ? (PanelDueFirmware-3.4.1-pre1-v3-5.0.bin)
                                  • fcwiltundefined
                                    fcwilt @DallasH
                                    Here is some information:
                                    https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_PanelDue
                                    DallasHundefined 1 Reply Last reply Reply Quote 1
                                    • DallasHundefined
                                      DallasH @fcwilt
                                      @fcwilt I UPDATED the panel due firmware. but still have unresponsive panel due.
                                        Add this line to the beginning of your config.g M575 P1 B57600 S1
                                        And change the baud setting on your PanelDue settings to 57600 to match.
                                        • fcwiltundefined
                                          fcwilt @DallasH
                                          @dallash
                                          Well it's still not connecting.
                                          First thing to check would be the wiring.
                                          How do you have it connected?
                                          • DallasHundefined
                                            DallasH @Phaedrux
                                            @phaedrux AWESOME! THAT DID THE TRICK! THANKS SO MUCH!!!!
