    what code to modify for z motors ,one on z and one on e1
    Config Tool
    1.5k
    • DallasHundefined
      DallasH @DallasH
      @dallash always says connecting
      DallasHundefined 1 Reply Last reply Reply Quote 0
      • DallasHundefined
        DallasH @DallasH
        @dallash i'm giving up for today. thanks
          I suggest you start here: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
          • DallasHundefined
            DallasH @Phaedrux
            @phaedrux I cant connect even with yat now. i get this error when trying to update driversDUET ERROR.JPG
            • DallasHundefined
              DallasH @DallasH
                What OS?
                • DallasHundefined
                  DallasH @Phaedrux
                  @phaedrux win 7 ultimate, 64 bit
                    That's a blast from the past. Does anything new show up in device manager even without the driver?
                    • DallasHundefined
                      DallasH @Phaedrux
                      @phaedrux ok i finally got everything talking, everything works from dwc thru a wifi browser, but nothing works from the panel due, display looks fine, but if you touch home it pops up a screen that says files on card 0. i can find nothing that responds from the panel due
                      • fcwiltundefined
                        fcwilt @DallasH
                        @dallash said in what code to modify for z motors ,one on z and one on e1:
                        Does the PanelDue have the correct firmware required by the current Duet firmware?
                        • DallasHundefined
                          DallasH @fcwilt
                          @fcwilt panel due v3.0a 5i display firmware 1.17 not sure what firmware to use with rrf 3.4! would this be correct ? (PanelDueFirmware-3.4.1-pre1-v3-5.0.bin)
                          • fcwiltundefined
                            fcwilt @DallasH
                            Here is some information:
                            https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_PanelDue
                            DallasHundefined 1 Reply Last reply Reply Quote 1
                            • DallasHundefined
                              DallasH @fcwilt
                              @fcwilt I UPDATED the panel due firmware. but still have unresponsive panel due.
                                Add this line to the beginning of your config.g M575 P1 B57600 S1
                                And change the baud setting on your PanelDue settings to 57600 to match.
                                • fcwiltundefined
                                  fcwilt @DallasH
                                  @dallash
                                  Well it's still not connecting.
                                  First thing to check would be the wiring.
                                  How do you have it connected?
                                  • DallasHundefined
                                    DallasH @Phaedrux
                                    @phaedrux AWESOME! THAT DID THE TRICK! THANKS SO MUCH!!!!
                                    • DallasHundefined
                                      DallasH @fcwilt
                                      @fcwilt I have the ribbon cable and the 4 wire lead connected.
                                        You should probably choose one or the other. Only use the ribbon cable if you want to use the SD card reader on the PanelDue as a second slot for loading gcodes. Otherwise the 4-wire connection is recommended.
                                        • fcwiltundefined
                                          fcwilt @DallasH
                                          Well as it turns out I overlooked something I should have mentioned - the settings that @Phaedrux mentioned.
                                          Glad to hear it is working.
                                          • DallasHundefined
                                            DallasH @Phaedrux
                                            @phaedrux ok thats why i replied about it after it was working, i will ditch the ribbon cable, could that cause the display to be a little fuzzy like not in focus. i know its pixles and no focus. but it is a little hard to read, with my old eyes.
