    Can't get Duet 2 Wifi to work with Creality CR6SE
    • quinnundefined
      quinn
      This is the setup I have been using I tried updating the firmware now the Yat can't connect to the Board. Below is the Config code.
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Apr 18 2022 09:30:20 GMT-0400 (Eastern Daylight Time)
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      M550 P"Ender 3 Pro"                                ; set printer name
      M918 P1 E4 F2000000                                ; configure direct-connect display
      M569 P0 S0                                         ; physical drive 0 goes backwards
      M569 P1 S0                                         ; physical drive 1 goes backwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S0                                         ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E93.00                   ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
      M208 X235 Y235 Z250 S0                             ; set axis maxima
      M574 X1 S1 P"xstop"                                ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop"                                ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
      M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5                                ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S150                                       ; set temperature limit for heater 0 to 150C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092      ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S275                                       ; set temperature limit for heater 1 to 275C
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1:0 T45                                ; set fan 2 value. Thermostatic control is turned on
      ; Custom settings
      M522 S1
      T0                                                 ; select first tool
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @quinn
        @quinn Here are a few links that should help you get going:
        • What to do if your Duet won't respond.
          Go through that one and see that the LEDs look the way they should.
        • HOW to use Bossa to program firmware.
        Ask questins here and people will be able to help you out.
        quinnundefined 1 Reply Last reply Reply Quote 1
        • quinnundefined
          quinn @alankilian
          @alankilian I can't get my duet now to show up in my computers com port list to run BOSSA what do I do now? I followed the guide and have everything ready to install. The duet wifi has been reset and restarted. I have BOSA open with the duet firmware 3.4.0 combined file selected and have the write options as erase all, lock, boot to flash. I just can't get the computer to see the board.
            alankilian @quinn
            @quinn
            OK, I'm not sure what state your board is, so let's go through Fallback #2 on the second link.
            Can you:
            • Disconnect Vin.
            • Connect a USB cable from the Duet to your PC
            • What LEDs are lit?
            Go to your Windows device manager and see what's listed under "Ports (COM and LPT)" and post an image of that here.
              @quinn Is this the same printer as in your post here? https://forum.duet3d.com/topic/28206/bltouch-not-working-duet-2-wifi?_=1650490637092
              If so, let's try and keep it to one post to give it a concentrated effort.
