    Can't login into rapsberry pi
    • taconiteundefined
      taconite
      Hey guys,
      I have a Raspberry Pi for an 7" touchscreen. It runs the duet image and I tried upgrading it but if failed because of to less storage (the image is running on an 8 GB card).
      But everything was working fine.
      As of today I can't login to the pi (the desktop is not running) and I can connect via VNC but can't login
      I can connect via SSH and the df command showed:
      why is the root folder 100% full? what can I do to fix that?
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
      • PaulHewundefined
        PaulHew
        the default password for a Pi is raspberry and IIRC it is the same if using the Duet builds.
        I know that Pi's now need you to create the username and password and want to enable ssh, when writing the image to the SD Card with the later releases, I learnt the hard way!
        taconiteundefined 1 Reply Last reply Reply Quote 0
        • taconiteundefined
          taconite @PaulHew
          @paulhew
          I changed the default password and can login with the new password via SSH. The past weeks I was able to login with the new password aswell. I tried rapsberry but I get an error promt
          Custom ANET A8
          • PaulHewundefined
            PaulHew
            This post is deleted!
            • PaulHewundefined
              PaulHew
              all my Pi's are headless. As you have added a screen, I suspect there is a setting that needs changing.
              P.
              • taconiteundefined
                taconite @PaulHew
                @paulhew As I said it was already working. I guess the update try did something to the image. I don't have the in-depth knowledge to know how and which files to delete to free up space
                Custom ANET A8
                  The lack of free space is preventing you from logging in.
                  See this link for some tips on how to free up space using the command line https://raspberrytips.com/raspbian-free-disk-space/
                  Honestly 8gb is not a sane size for a Pi SD card anymore. 32GB minimum.
