    BL-Touch to Alfawise U10
    970
    • Perttiundefined
      Pertti
      Hi! I have a BL-Touch Smart V3 .1 which I´m adding to my Alfawise U10. Duet WiFi (firmware version 3) is in use.
      config.g
      deployprobe.g
      retractprobe.g
      Wiring is as advised:
      Tried to test it sending M280 P0 S10 - nothing happens.
      Any ideas to the next step?
      And how to perform the bed levelling?
      Thanks!
      Pertti
      “A winner is just a loser who tried one more time.”
      George M. Moore, Jr.
        The files you've uploaded seem to be blank. Can you copy and paste the contents into a post here? Also please send M122 and M98 P"config.g" and post the results.
        Perttiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        • Perttiundefined
          Pertti @Phaedrux
          @phaedrux
          (I tried to zip all, but the file format was not allowed.)
          deployprobe.g :
          M280 P0 S10
          retractprobe.g :
          M280 P0 S90
          config.g :
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Mar 07 2022 20:17:53 GMT+0200 (Itä-Euroopan normaaliaika)
          M550 P"Alfawise U10" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P2 S0 ; physical drive 2 goes forwards
          M92 X80.00 Y80.00 Z400.00 E92 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X20000.00 Y20000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X400 Y400 Z500 S0 ; set axis maxima
          ; M574 X1 S3 ; Set X / Y endstop stall detection M574 X1 Y1 S3
          M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
          M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
          M557 X15:350 Y15:350 S20 ; define mesh grid
          M950 S0 C"exp.heater3" ; Duet 2 WiFi/Ethernet
          M558 P9 C"^zprobe.in" H5 F120 T3000 ; Duet 2 WiFi/Ethernet, DueX2/5
          M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0
          G31 X20 Y0 Z3.3 P25; offsetit
          ;Stall Detection
          ;M915 X R3 F0 H400 R4700 ; X / Y Axes M915 X Y S3 F0 H400 R4700
          ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
          M307 H0 B0 R0.086 C686.8 D1.84 S1.00 V12.5
          ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M307 H1 B0 R1.620 C208.6 D10.64 S1.00 V12.6
          Pertti
            Phaedrux Moderator @Phaedrux
            @phaedrux said in BL-Touch to Alfawise U10:
            Perttiundefined 1 Reply Last reply Reply Quote 0
            • Perttiundefined
              Pertti @Phaedrux
              @phaedrux
              21.4.2022 klo 12.39.39 M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
              Board ID: 0JD0M-9P6M2-NWNS0-7J9DD-3S86K-1A3ML
              Used output buffers: 3 of 24 (11 max)
              Static ram: 23876
              Dynamic ram: 75032 of which 12 recycled
              Never used RAM 15496, free system stack 178 words
              Tasks: NETWORK(ready,12.6%,231) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,86.6%,441) IDLE(ready,0.7%,29), total 100.0%
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:02:22 ago, cause: power up
              Last software reset at 2022-04-20 17:07, reason: User, GCodes spinning, available RAM 15496, slot 1
              Error status: 0x00
              Aux0 errors 0,0,0
              Step timer max interval 0
              MCU temperature: min 18.4, current 24.5, max 24.6
              Supply voltage: min 12.6, current 12.7, max 12.9, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: position 0, standstill, SG min/max not available
              Driver 1: position 0, standstill, SG min/max not available
              Driver 2: position 0, standstill, SG min/max not available
              Driver 5: position 0
              Driver 6: position 0
              Driver 7: position 0
              Driver 8: position 0
              Driver 9: position 0
              Driver 10: position 0
              Driver 11: position 0
              Date/time: 2022-04-21 12:39:38
              Slowest loop: 5.19ms; fastest: 0.17ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 4.0ms, write time 0.0ms, max retries 0
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 15.55ms; fastest: 0.00ms
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is active
                WiFi firmware version 1.26
                WiFi MAC address f4:cf:a2:68:47:93
                WiFi Vcc 3.35, reset reason Power up
                WiFi flash size 2097152, free heap 25520
                WiFi IP address 192.168.10.126
                WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
                Clock register 00002002
              98 P"config.g"
              Error: Bad command: 98 P"config.g"
              Pertti
                dc42 administrators @Pertti
                @pertti said in BL-Touch to Alfawise U10:
                98 P"config.g"
                You missed out the leading M.
                • Perttiundefined
                  Pertti @dc42
                  @dc42 I see... what do You mean by "missing out the leading M"?
                  Pertti
                    @pertti you ran command:
                    98 P"config.g"
                    instead of:
                    M98 P"config.g"
                    • Perttiundefined
                      Pertti @dc42
                      @dc42 Ok, I got it, thank You.
                      21.4.2022 klo 13.38.36 M98 P"config.g"
                      HTTP is enabled on port 80
                      FTP is disabled
                      TELNET is disabled
                      Pertti
                        @pertti does the BLTouch perform its self test when you power up?
                        • Perttiundefined
                          Pertti @dc42
                          Nope
                          Pertti
                            It sounds like the BLTouch is not getting power if it's not doing a self test. Does it light up?
                            • Perttiundefined
                              Pertti @Phaedrux
                              @phaedrux
                              No light. I´ll check the wires.
                              Pertti
                              • Perttiundefined
                                Pertti @Pertti
                                @pertti The BL touch wire connector was 1 step aside in the motherboard. 😖 wiring1.PNG
                                I´ll continue the experiment soon.
                                Pertti
                                • Perttiundefined
                                  Pertti @Pertti
                                  @pertti Now it gets power! At the start the Bl-touch moves back and forth . After homing it twinkles red light.
                                  I have no idea weather the BL-touch is supposed to be the z-endstop or not. Is my configuration ok?
                                  Pertti
                                  dc42undefined Lo-Fiundefined 2 Replies Last reply Reply Quote 0
                                    @pertti do M401 and M402 work to deploy and retract the probe?
                                    • Lo-Fiundefined
                                      Lo-Fi @Pertti
                                      @pertti Do you have a Z stop switch as well as the BLTouch? If not and you want to use the BL for Z homing, you'll want to change M574 Y1 S1 P"ystop" to M574 Z1 S2 in your config and define a Z homing macro.
                                      This blog post here give an excellent overview of the macros:
                                      https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
                                      Remove the M280 command in the config, that belongs in the Pin Down macro.
                                      • Perttiundefined
                                        Pertti @dc42
                                        @dc42 said in BL-Touch to Alfawise U10:
                                        M401
                                        M401 deploys an d M402 retracts the probe.
                                        Pertti
                                        • Perttiundefined
                                          Pertti @Lo-Fi
                                          @lo-fi Yes I have a remainig z endstop. I do not know is it worth saving. Less moving parts sounds good. And if I changed the bed surface thickness then it is easier to handle with z probe.
                                          Pertti
                                            Share your homeall and homez here and we can tell you if anything needs to change. In general though, to home Z with the probe you need a G30 command. And before the G30 you'd need a G1 X Y command to move the probe into position. Ideally the center of the bed.
