    White screen on Panel DUE 5i
    PanelDue
    312
    • Aodrennn
      Aodrennn last edited by
      I tried to connect my PanelDue to my Duet3 mini 5+ but there is a white screen and no response when I click on it.
      So i tried to flash the firmware from DWC but nothing, DWC tells me :" Error: M997: Aux port 0 is not enabled or not in PanelDue mode".
      I connected it with the 4 wires cable provided and also with the ribbon cable to try but nothing.
      I also try to flash the firmware with Bossa, I read the firmware and i verified it and it tells me that is ok but there s the white screen again 😕
      I don't know what can I try now ... If someone can give me some help it will be nice 😉
      Thanks in advance.
      jay_s_uk Rushmere3D 2 Replies Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @Aodrennn last edited by
        @aodrennn sounds like you're flashing the wrong file.
        what specifically is the name of the firmware file you've used?
        Aodrennn 1 Reply Last reply Reply Quote 0
        • Rushmere3D
          Rushmere3D @Aodrennn last edited by
          @aodrennn Have you added the command to the config.g?
          M575 P1 S1 B57600
          Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
          • Aodrennn
            Aodrennn @jay_s_uk last edited by
            @jay_s_uk
            I used this firmware :
            jay_s_uk 1 Reply Last reply Reply Quote 0
            • jay_s_uk
              @aodrennn is it a real paneldue or a fysetc clone?
              • Aodrennn
                Aodrennn @Rushmere3D last edited by
                @rushmere3d
                Yeah i got ths gcode in my config.g
                • Aodrennn
                  @jay_s_uk I don't think so, I bought it on E3D Online
                  • jay_s_uk
                    @aodrennn I would redownload the firmware and follow the instructions here again https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_PanelDue#firmware-update-via-usb
                    Aodrennn 2 Replies Last reply Reply Quote 0
                    • Aodrennn
                      @jay_s_uk I'll retry it, thanks 😉
                      • Aodrennn
                        @jay_s_uk There is nothing new 😕
                          And it writes and verifies successfully?
                          You've pressed the erase/reset buttons?
                          Can you show some photos of the screen showing white?
                          Can you show the bossa settings?
                          • Aodrennn
                            Aodrennn @Phaedrux last edited by
                            @phaedrux
                            • Yeah I have "Read completed successfully" and then "Verify successful".
                            • Before read the firmware with Bossa I pressed erase and reset and after I read the firlware, I repressed reset.
                            • Here is the white screen I have
                            • I don't really what did you mean with "Bossa settings" but here is my Bossa window
                              Please try flashing once more with this file
                              https://github.com/Duet3D/PanelDueFirmware/releases/download/3.4.0/PanelDueFirmware-3.4.0-5.0i.bin
                                dc42 administrators @Aodrennn last edited by
                                @aodrennn I assume that after you flashed it using Bossa, Bossa reported success? And that after that you pressed the Reset button again (not the Erase button), but the screen remained white? If so then we will replace the PanelDue, so please email warranty@duet3d.com with a link to this post.
                                • Aodrennn
                                  @phaedrux nothing better, the white screen still here 😕
                                  • Aodrennn
                                    Aodrennn @dc42 last edited by
                                    @dc42 Yeah, that's I did like 10 times ... If it works normally, the screen would become with all button like "home"... just after I pressed the reset button ? (I don't know if my sentence is correct sorry, I hope you understand what I mean).
                                    And I tell in the mail that I baught the display on E3D ? I copy E3D's support ?
                                    Thanks for your help !
                                      Phaedrux Moderator @Aodrennn last edited by
                                      @aodrennn said in White screen on Panel DUE 5i:
                                      Yes you can do that.
