    Unsolved Spurious heater faults
    Using Duet Controllers
    387
    • ibash
      ibash last edited by ibash
      Recently I started printing with ASA which requires a higher bed temperature (85c). Every single print was getting a heater fault, so I did another PID tune of the bed at 100c. Every single print still gets a heater fault.
      The only way I've found to avoid the heater faults is to preheat the bed, first to 60c or 70c then finally to my target temperature. After that I can start the print without fault.
      What diagnostic information do you need to debug this?
      Happy to try any other troubleshooting steps, I went through these before: https://docs.duet3d.com/en/User_manual/Troubleshooting/Heater_faults
      Also it always (like 100%) triggers a heater fault unless I preheat the bed manually. So these heater faults are not really spurious, but reliable 🙂
      • ibash
        Just thought of a hack for this... I might put M562 in daemon.g if there's no solution...
        • OwenD
          OwenD last edited by
          What exactly is the heater fault?
          What firmware & board?
          What kind of bed heater?
          How is the heater configured? (post config.g)
          What command are you issuing for PID?
          There have been quite a few changes to heating over the last few firmware versions.
          Without all the details it's impossible to give advice.
          However I have found that for the nozzle heater I have, the PID values I get from RRF3.4 cause excessive overshoot when initially heating, so I had to manually tweak them a bit to avoid errors from going more than 15 degrees above the target value.
          I haven't had the same issue on my bed though (240v)
          ibash 1 Reply Last reply Reply Quote 1
          • ibash
            ibash @OwenD last edited by
            @owend
            1. Heat is rising too slowly
            2. It's an aluminum bed, it's a railcore so fairly large 300x300. The printer is enclosed.
            3. Keenovo heater.
            4. See below
            5. M303 H0 S100
            Config.g:
            ;General Setup - RailCore RRF on a SBC for Duet3
            M929 S2 ; Enable Logging
            G21     ; Work in millimetres
            G90     ; Send absolute coordinates...
            M83     ; ...but relative extruder moves
            ; Stepper configuration
            M569 P0 S1 D3 ; Drive 0 X / Rear
            M569 P1 S0 D3 ; Drive 1 Y / Front
            M569 P2 S1 ; Drive 2 Z Front Left
            M569 P3 S1 ; Drive 3 Z Rear Left
            M569 P4 S1 ; Drive 4 Z Right
            M569 P5 S1 ; Drive 5 Extruder
            ;Axis configuration
            M669 K1              ; corexy mode
            M584 X0 Y1 Z2:3:4 E5 ; Map X to drive 0 Y to drive 1, Z to drives 2, 3, 4, and E to drive 5
            ;Leadscrew locations
            M671 X-15:-15:336  Y20:277:150 S7.5
            M350 X16 Y16 Z16 E16 I1          ; set 16x microstepping for axes with interpolation
            M906 X1400 Y1400 Z1200 E800 I80 ; Set motor currents (mA)
            ;M906 X1200 Y1200 Z1200 E800 I80  ; Set motor currents (mA)
            M201 X2500 Y2500 Z100 E1500      ; Accelerations (mm/s^2)
            M203 X24000 Y24000 Z900 E3600    ; Maximum speeds (mm/min)
            M566 X800 Y800 Z100 E1500        ; Maximum jerk speeds mm/minute
            M208 X288 Y305 Z338              ; set axis maxima and high homing switch positions (adjust to suit your machine)
            M208 X-10 Y0 Z0 S1               ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
            M92 X200 Y200 Z1600 E837         ; steps/mm
            ; End Stops
            M574 X1 S1 P"io1.in" ; Map the X endstop to io1.in
            M574 Y1 S1 P"io2.in" ; May the Y endstop to io2.in
            ; Thermistors
            M308 S0 P"temp0" Y"thermistor" A"bed_heat" T100000 B4240 H0 L0              ; Bed thermistor - connected to temp0
            M308 S1 P"temp1" Y"thermistor" A"e0_heat" T100000 B4725 C7.06e-8 H0 L0      ; duet3 e3d thermistor - connected to e0_heat
            ;M308 S1 P"temp1" Y"thermistor" A"e0_heat" T500000 B4723 C1.196220e-7 H0 L0 ; _RRF3_ slice thermistor
            M308 S2 P"temp2" Y"thermistor" A"keenovo" T100000 B3950 H0 L0               ; Keenovo thermistor - connected to temp2
            ;Define Heaters
            M950 H0 C"out0" T0 ; Bed heater is on out0
            M950 H1 C"out1" T1 ; Hotend heater is on out1
            ;Define Bed
            M140 H0
            M307 H0 R0.246 K0.112:0.000 D30.62 E1.35 S1.00 B0        ; Bed, with enclosure tuned at 100c
            ; M307 H0 B0 R0.238 C1055.6 D38.24 S1.00 V24.0             ; Bed, with enclosure tuned at 60c
            ; M307 H0 R0.225 K0.135:0.000 D45.28 E1.35 S1.00 B0        ; Bed, no enclosure tuned at 60c
            M307 H1 R2.489 K0.564:0.000 D6.51 E1.35 S1.00 B0 V24.0     ; Hotend with 5015 fan, with enclosure
            ; M307 H1 R2.370 K0.536:0.000 D7.36 E1.35 S1.00 B0 V24.0   ; Hotend with 5015 fan, no enclosure
            M570 S360                                                ; Hotend may be a little slow to heat up so allow it 180 seconds
            M143 S295                                                ; Set max hotend temperature
            ; Mesh bed level grid
            M557 X102.5:227.5 Y92.65:207.65 P2:2
            M950 F0 C"out4"     ; Layer fan on "out4" connector
            M106 P0 S0          ; Layer Fan
            M950 F1 C"out5"     ; Hotend fan on "out5" connector
            M106 P1 S255 H1 T50 ; enable thermostatic mode for hotend fan
            ; M106 P1 S0
            ; Filter fans
            M950 F2 C"out9"
            M106 P2 S0
            M950 F3 C"out8"
            M106 P3 S0
            ; Tool definitions
            M563 P0 D0 H1 F0 ; Define tool 0
            G10 P0 S0 R0     ; Set tool 0 operating and standby temperatures
            ; BLTouch
            ; larger probe offset = nozzle closer to the bed
            M558 P9 C"io7.in" H5 R1 F120 T6000 A5 S0.02 B1 ; define the bltouch input on io7.in
            M950 S0 C"io7.out"                             ; define the bltouch servo on io7.out
            ;G31 X2 Y38.15 Z1.38 P25                        ; set the offsets for the bltouch
            G31 X2 Y38.15 Z1.15 P25                        ; set the offsets for the bltouch
            ; Calibrate MCU Temperature
            M912 P0 S-8.7
            ; Stealthchop
            M98 P"stealthchop/config.g"
            T0 ; select first hot end
            ibash 1 Reply Last reply Reply Quote 0
            • ibash
              ibash @ibash last edited by
              cc @Phaedrux maybe?
                Can you try removing M307 H0 R0.246 K0.112:0.000 D30.62 E1.35 S1.00 B0 ; Bed, with enclosure tuned at 100c from your config.g and re-running the tuning process with M303 H0 S100 and this time take a screen shot of the tuning process after a while so we can see the graph?
                Be sure to start the tuning process from ambient temp.
                • ibash
                  ibash @Phaedrux last edited by
                  Thanks!
                  Still running the tuner, can post results when done. Just realized that my config.g has "B4240" for the bed thermistor, when I think it should be B3950. Could that be the cause?
                  • ibash
                    I think the problem is that it is using the wrong thermistor value, as per the graph the keenovo thermistor vs bed thermistor are way different when they should be the same. This is my mistake.
                    Thank you Phaedrux!
                    • Topic has been marked as a question  Phaedrux Phaedrux
                    • Topic has been marked as solved  Phaedrux Phaedrux
                    • ibash
                      Hmm, got another heater fault today despite having changed the thermistor value and retuning.
                        Are you copy and pasting the results into your config?
                        Have you tried using M500 to save them to config-override.g and then adding M501 to the end of your config to load the values at startup?
                        It seems like the values aren't actually applied. Can you send M307 H0 in the gcode console and see what values it is actually using.
                        Is it perhaps your part cooling fan coming on and causing the temp to drop? Or is the enclosure temp different during a print versus when it's tuned?
                        • ibash
                          @phaedrux
                          Yep I do copy/paste the line into config.g. It looks like the values are applied correctly too:
                          In my config.g:
                          M307 H0:
                            What does the temp graph look like when the error occurs? It seems weird that it expects a rate of 0.28 but actually saw a rate of 0. Is the thermistor not making good contact?
                            • Topic has been marked as unsolved  Phaedrux Phaedrux
                            • A Former User
                              This post is deleted!
                                Phaedrux Moderator @Guest last edited by
                                @arnold_r_clark said in Spurious heater faults:
                                never reach the same conclusion twice
                                How much variation are you seeing?
                                A Former User 1 Reply Last reply Reply Quote 0
                                • A Former User
                                  A Former User @Phaedrux last edited by
                                  • ibash
